    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 238.4k Views 39 Watching
    • JalibuJ Offline
      Jalibu Module Developer @Leijoh
      @leijoh said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
      Maybe the almighty might be able to help me out a little?
      i cant seem to be able to standard a header?
      Hi @Leijoh,
      you can rely on the almighty! There indeed was a problem with the header setting which was fixed in the latest 2.3.0 release.
      @martinloidolt said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
      I want to ask you if it is possible to show the whole depot and not just the growth?
      Furthermore it would be nice to have the option to disable the color.
      Hi @MartinLoidolt,
      I picked up both of your feature requests and put them in the latest 2.3.0 release, too.
      • L Offline
        Leijoh @Jalibu
        @jalibu said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
        Hi @Leijoh,
        The ALMIGHTY has provided! Thanks alot:)
        • G Offline
          gpaquin
          Hello Everyone!
          I’m currently trying to install and use this module but when I start it, it says “undefined” and I have no clue of what’s going on… I follow exactly the instruction but… I can’t make it work. Am I missing something?
          Thank You!
          JalibuJ 1 Reply Last reply Reply Quote 0
          • JalibuJ Offline
            Jalibu Module Developer @gpaquin
            @gpaquin please send me a PN to provide more information
              morphisto
              Hi, is it possible to increase the font size? Often I have wear no glasses if I`m in my bath room after showering - and I need a bigger font size without glasses…
              uros76U 1 Reply Last reply Reply Quote 0
              • uros76U Offline
                uros76 @morphisto
                @morphisto said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
                You can do that with CSS.
                https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works
                  morphisto @uros76
                  @uros76 I know how css works - but i cannot find the right class in the Jast Module to change the font size. Therefore I asked the developer if there is a chance to to it?
                  S JalibuJ 2 Replies Last reply Reply Quote 0
                    sdetweil @morphisto
                    @morphisto see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1622084388280
                    you can discover what you need to know
                    • JalibuJ Offline
                      Jalibu Module Developer @morphisto
                      @morphisto
                      you should be fine by just adding
                      .jast-wrapper {
                      --size: 2.0rem;
                      to your custom css
                        morphisto @Jalibu
                        –size: 2.0rem;
                        Thank You!
                        • JalibuJ Offline
                          Dear user of this module,
                          so far, the wording around the portfolio function was incorrect/misleading, as I incorrectly used the German term “Depot” for that.
                          In the latest version the translation should be clearer.
                          Attention: Due to the renaming, configuration properties have also changed. Temporarily old AND new properties are supported, but in future versions I will only support the new ones. So, please update your config.
                            doscas @Jalibu
                            @Jalibu
                            Hi, Just installed this. What a great addition to my MagicMirror. Congrats!
                            I’m running on top of a background with pictures and I would like to have the letters fading when disappearing on the horizontal mode (guess it could be the same for the vertical mode).
                            Instead of “seeing” an invisible line where all the letters just disappear, I believe a little fade option would be a design touch that would elevate this module a lot.
                            I’m not sure I can achieve it with CSS only without damaging the view of the background picture.
                            Thank you.
                            • I Offline
                              ItsDonJ
                              I love the idea of that Ticker but sadly if i try to use it, i also only get an “Undefined” error message on my mirror. Any idea why so? For the moment i tried it with the BASF and SAP-Stocks like in the example.
                              • JalibuJ Offline
                                Jalibu Module Developer @ItsDonJ
                                @itsdonj
                                Please check your symbols. The “undefined” error comes when there are invalid symbols in your list
                                • uros76U Offline
                                  uros76
                                  @Jalibu thanks for your continuos work on this module. It’s awesome and I use it on few MM deployments. Virtual beer sent your way :)
                                  Perhaps you know, is there a way to pull a list of stocks into a config.js file, from a different file? I am no expert in JS but maybe there is a way to pull some of the config elements from a different file?
                                  • JalibuJ Offline
                                    Jalibu Module Developer @uros76
                                    Hi @uros76,
                                    thank you for the beer :-)
                                    What do you mean with “different file”? Should that be a central/remote file which should be loaded over the internet from different mirrors or just another local file on the same system?
                                    Prost!
                                    uros76U S 2 Replies Last reply Reply Quote 0
                                    • uros76U Offline
                                      uros76 @Jalibu
                                      @jalibu welcome :)
                                      Preferably the other file with defined stocks would be on the same system.
                                      I kind of get it how to make this work with python scripts but I have no clue if it’s possible with JS.
                                      • JalibuJ Offline
                                        @uros76 either you prepare/autogenerate the config.js in a preflight with the stocks of your file before you start the mirror or I am afraid that it won’t work without programming efforts in the module.
                                        Can you explain me the use case?
                                        • uros76U Offline
                                          uros76 @Jalibu
                                          @jalibu I am making a small MM project, based on rpi 3 and a small screen. This will be used by my friends who are occasionally trading with crypto and stocks.
                                          Rather than teaching them how to edit a list of monitored stocks in the config.js (which could lead to catastrophic failure) I would prefer them to edit an independent shared file with the list of stocks only. This way we avoid breaking the core MM system and have the flexibility to change the list of stocks daily if needed.
                                          I like the idea of autogenerating the config file. Will have a look into it if I can do it with python script. If you come up with some other solution let me know.
                                          Thanks again
                                          • JalibuJ Offline
                                            @uros76 why don’t you use @sdetweil 's Config Edit Tool MMM-Config?
                                            MMM-Jast has full support for it.
                                            uros76U 1 Reply Last reply Reply Quote 1
                                            • 4 / 9
