    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 232.9k Views 39 Watching
    • JalibuJ Offline
      Jalibu Module Developer @morphisto
      @morphisto
      you should be fine by just adding
      .jast-wrapper {
      --size: 2.0rem;
      to your custom css
        morphisto @Jalibu
        @jalibu said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
        –size: 2.0rem;
        Thank You!
        • JalibuJ Offline
          Dear user of this module,
          so far, the wording around the portfolio function was incorrect/misleading, as I incorrectly used the German term “Depot” for that.
          In the latest version the translation should be clearer.
          Attention: Due to the renaming, configuration properties have also changed. Temporarily old AND new properties are supported, but in future versions I will only support the new ones. So, please update your config.
            doscas @Jalibu
            @Jalibu
            Hi, Just installed this. What a great addition to my MagicMirror. Congrats!
            I’m running on top of a background with pictures and I would like to have the letters fading when disappearing on the horizontal mode (guess it could be the same for the vertical mode).
            Instead of “seeing” an invisible line where all the letters just disappear, I believe a little fade option would be a design touch that would elevate this module a lot.
            I’m not sure I can achieve it with CSS only without damaging the view of the background picture.
            Thank you.
            • I Offline
              ItsDonJ
              I love the idea of that Ticker but sadly if i try to use it, i also only get an “Undefined” error message on my mirror. Any idea why so? For the moment i tried it with the BASF and SAP-Stocks like in the example.
              JalibuJ 1 Reply Last reply Reply Quote 0
              • JalibuJ Offline
                Jalibu Module Developer @ItsDonJ
                @itsdonj
                Please check your symbols. The “undefined” error comes when there are invalid symbols in your list
                • uros76U Offline
                  uros76
                  @Jalibu thanks for your continuos work on this module. It’s awesome and I use it on few MM deployments. Virtual beer sent your way :)
                  Perhaps you know, is there a way to pull a list of stocks into a config.js file, from a different file? I am no expert in JS but maybe there is a way to pull some of the config elements from a different file?
                  • JalibuJ Offline
                    Jalibu Module Developer @uros76
                    Hi @uros76,
                    thank you for the beer :-)
                    What do you mean with “different file”? Should that be a central/remote file which should be loaded over the internet from different mirrors or just another local file on the same system?
                    Prost!
                    uros76U S 2 Replies Last reply Reply Quote 0
                    • uros76U Offline
                      uros76 @Jalibu
                      @jalibu welcome :)
                      Preferably the other file with defined stocks would be on the same system.
                      I kind of get it how to make this work with python scripts but I have no clue if it’s possible with JS.
                      • JalibuJ Offline
                        @uros76 either you prepare/autogenerate the config.js in a preflight with the stocks of your file before you start the mirror or I am afraid that it won’t work without programming efforts in the module.
                        Can you explain me the use case?
                        uros76U 1 Reply Last reply Reply Quote 0
                        • uros76U Offline
                          uros76 @Jalibu
                          @jalibu I am making a small MM project, based on rpi 3 and a small screen. This will be used by my friends who are occasionally trading with crypto and stocks.
                          Rather than teaching them how to edit a list of monitored stocks in the config.js (which could lead to catastrophic failure) I would prefer them to edit an independent shared file with the list of stocks only. This way we avoid breaking the core MM system and have the flexibility to change the list of stocks daily if needed.
                          I like the idea of autogenerating the config file. Will have a look into it if I can do it with python script. If you come up with some other solution let me know.
                          Thanks again
                          • JalibuJ Offline
                            @uros76 why don’t you use @sdetweil 's Config Edit Tool MMM-Config?
                            MMM-Jast has full support for it.
                            uros76U 1 Reply Last reply Reply Quote 1
                            • uros76U Offline
                              uros76 @Jalibu
                              @jalibu I completely forgot about this one. I will disable the rest and just allow Jast module to be editable. This could also work, thanks
                                sdetweil @Jalibu
                                @jalibu you could pull a json list of stocks from a file, like compliments does
                                and do it on some timed cycle, hourly, daily.
                                @uros76 one could also try using my MMM-Config module, which presents a form for config.js, where user could + to add, - to remove
                                see
                                https://github.com/sdetweil/MMM-Config
                                then the user could change via their phone or ipad/laptop…
                                • uros76U Offline
                                  uros76 @sdetweil
                                  @sdetweil excellent, yes that’s what I am trying now. Thanks
                                    I submitted a PR for jast to improve the form for the stocks list
                                      mweth
                                      Great module and I think this is a simple request. I would like for the ticker to only change to red or green if the stock moves by more than 5%. In VerticalStockList.njk, I changed the code as follows (and added a “same” color in the CSS, but it did not do anything. Super bonus points if I can make a movement of more than 7% show an image.
                                      {{ utils.getStockName(stock) }}: {% if utils.getStockChange(stock) > 3 %} {% set colorClass = “high” %} {% elif utils.getStockChange(stock) < 3 %} {% set colorClass = "low " %} {% else %} {% set colorClass = “same” %}
                                        MasonR1209
                                        Hey, I wanted to know if it’s possible to make a static always there Portfolio Value… that changes as the stocks listed change in price, but is always shown, and have the stocks ticker above / below the portfolio value, and not scroll to the portfolio value as it would be permanently shown… e.g
                                        Scrolling stocks ticker
                                        Portfolio Value: xxxx
                                        Possibly also add a static always shown portfolio change value / change percentage that isn’t included in the scroll.
                                        I would opt for the Static option for all as you can in the config but it takes up too much room on the mirror and I was wondering if what i’ve stated is configurable? Thanks
                                        ALSO. Having issues with the default module of ‘currentweather’. This MMM-Jast module makes my currentweather module disappear. It loads, then as soon as MMM-Jast loads, currentweather disappears. As soon as I remove MMM-Jast from the config, then currentweather works again.
                                        • JalibuJ Offline
                                          Jalibu Module Developer @MasonR1209
                                          @masonr1209 please open two issues on GitHub on that. I’ll check them when I have more time again
                                            Jo 0
                                            how can I format the Output Numbers?
                                            like 34,265.37$ or
                                            34.265,37$ according the settings.
                                            • 4 / 9
