    Warn-App NINA
    25 Posts 9 Posters 11.6k Views 11 Watching
      MajorC Project Sponsor @Fozi
      I have to strongly disagree with you on this point. The NINA app has worked for me several times and has been proven to work fast and accurately. Even with GPS-based locations (e.g. on business trips) it warned me about events on the move.
      Of course the whole system, not the app, failed during the warning day. But it wasn’t the app’s fault, there were several cascading effects.
      Nevertheless, big fires in my area, airplane bomb discoveries, all this has worked very well, fast and reliable during the last years.
      Therefore my clear PRO for the app and also for finally releasing the API. Via “Ask the State” they tried this before, unfortunately without success.
      Translated with www.DeepL.com/Translator (free version)
      • FoziF Offline
        Fozi Project Sponsor @MajorC
        @MajorC I don’t blame the app but the whole backend, which is unreliable. When I lived in Munich a few years ago two WWII bombs were found on a construction ground near our house within two months. We got noticed by the police when they rang on our door and requested our evacuation. Both times no warnings from Nina and we had to leave immediately without any possibility to pack some stuff for our 14 months old daughter. Then the shooting at McDonalds. I work about 500 m away, the notification came 3 hours later and the situation that evening was chaotic. Followups? Forget it! But if the system collapses already under dry-run conditions, then it is no wonder that in an real emergency the system would fail, too. Such systems have to work 100% reliable under all circumstances. If they don’t, they are useless and people like me start to lose trust. And over the last years obviously nothing improved. I fully agree that we need a warning system, but Nina unfortunately lost a lot of trust for me. The tweets from the local police departments are by far more reliable, accurate, trustworthy and faster.
        • U Offline
          ueffchen
          the simplest is to create your own custom RSS Feed on NINA such as RSS and put it in the newsfeed. This won’t give you the whole text, but this would anyway be very long and in my view too much to display on the MM
          • cowboysdudeC Offline
            cowboysdude Module Developer @Feedy88
            @feedy88 Oh there’s always a way
            • JalibuJ Offline
              Jalibu Module Developer
              @v0rtex @MajorC
              Is there still a need for this?
              I just stumbled upon the Nina API (i.e. https://warnung.bund.de/api31/dashboard/082210000000.json for Heidelberg)
              It should be very easy to implement a client module for MagicMirror
                MajorC Project Sponsor @Jalibu
                @jalibu that would be very cool to see on the mirror.
                • JalibuJ Offline
                  Hier mal ein erster Entwurf: https://github.com/jalibu/MMM-NINA
                  An der Optik müssen wir noch Arbeiten ;-)
                  Bin hier für Vorschläge (Mockups, etc) offen.
                  FoziF 1 Reply Last reply Reply Quote 1
                    santicoia
                    Hallo @Jalibu
                    Habe dein Modul installiert und den AGS auf meine Region angepasst. Bekomme eine Fehlermeldung und config:check ergibt unexpected token ags Colume 13.
                            module: "MMM-NINA",
                            position: "top_bar",
                                updateIntervalInSeconds: 120,
                                maxAgeInHours: 6,
                                showNoWarning: true
                                ags: "034570022022",
                    Nun habe ich entdeckt, dass es für meinen Ort unterschiedliche Angaben im Netz gibt. Unter deinem Link erhalte ich die oben eingefügte Zahl. Unter diesem Link sieht der AGS so aus 03457022. Es fehlt also scheinbar eine 0 oder bei deinem Link wäre eine zuviel. Hab ich natürlich getestet, aber egal wie eingetragen, es funzt nicht.
                    Daraufhin hab ich deine Beispiel-Config von Github eingetragen und erhalte nach wie vor den selben Fehler… unexpected token ags.
                    Wo liegt mein Fehler? Bin für jegliche Hilfe dankbar und danke schon mal fürs Lesen.
                    Grüße
                    Sandra
                    JalibuJ 1 Reply Last reply Reply Quote 0
                    • JalibuJ Offline
                      Jalibu Module Developer @santicoia
                      Hallo @santicoia ,
                      herzlich willkommen in der Community und danke für dein Interesse an meinen Modulen.
                      In deiner config.js fehlt ein Komma nach showNoWarning:true
                      Wenn man das ergänzt, dann funktioniert es bei mir wunderbar :-)
                        santicoia @Jalibu
                        @jalibu
                        vielen Dank für die schnelle Hilfe. Peinlich, dabei hatte ich bestimmt 10 Mal drüber geguckt. Aber zu meiner Entlastung, das Komma fehlt auch in deinem Beispiel auf Github ;)
                        • JalibuJ Offline
                          @santicoia said in Warn-App NINA:
                          @jalibu
                          @MajorC hat es dankenswerterweise eben schon gefixt :-)
                            @jalibu das war easy, das musste ich schnell abstauben :-)
                            • FoziF Offline
                              Fozi Project Sponsor @Jalibu
                              @jalibu Ich habe das Modul mal am Wochenende installiert und es funktioniert. D.h., wenn ich eine Warnung auf mein Handy bekomme, sehe ich sie auch im Modul.
                              Vorschlag:
                              • Wenn keine Warnungen anliegen, sollte lediglich “Keine Warnungen” als Nachricht erscheinen in #666 statt grün und ohne Haken davor. Das würde besser zu MMM-DWDWarweather Modul passen ☺.
                              • In der config würde ich noch die header: option angeben, die man sich nach Wunsch benennen kann. Ausserdem hat man dann auch eine schöne Headline über dem Modul.
                              JalibuJ M 2 Replies Last reply Reply Quote 0
                              • JalibuJ Offline
                                Jalibu Module Developer @Fozi
                                Servus @fozi,
                                könntest du hierzu auch Issues auf Github anlegen? Dann wirds nicht in Vergessenheit geraten.
                                • FoziF Offline
                                  @jalibu Klar, ist schon erledigt.
                                    @fozi said in Warn-App NINA:
                                    Vorschlag:
                                    Schnelle Lösung über custom.css:
                                     * MMM-NINA
                                    .MMM-NINA .nina-wrapper .nina-alert.severity-Fine{
                                      color: #666;
                                    • FoziF Offline
                                      @majorc Besten Dank! Das fiel mir auch kurz nach meinem letzt Post auch ein (hätte ich auch eher drauf kommen können). Die Meldung selbst hbe ich so gelassen und stattdessen das property noWarningText: im MMM-DWD-Warnweather angepasst. Jetzt muss ich nur noch das Häkchen loswerden ☺
                                      • JalibuJ Offline
                                        @sdetweil please mark this topic as “solved”.
                                        => Module Forum Thread https://forum.magicmirror.builders/topic/15429/mmm-nina
                                          sdetweil @Jalibu
                                          @jalibu sorry not clear
                                          you said this topic
                                          then linked another
                                          you can only select one of the posts in a topic as the one that resolves it
                                          • JalibuJ Offline
                                            Jalibu Module Developer @sdetweil
                                            @sdetweil said in Warn-App NINA:
                                            you said this topic
                                            then linked another
                                            This topic was a request for NINA support. As I now added a module for that, this request topic could be marked as “solved” :-)
