    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 82.0k Views 35 Watching
      MajorC Project Sponsor
      UPDATE:
      I included into the custom.css
       * MMM-SystemStats
      .MMM-SystemStats table {
              width: 350px;
              color: #666;
              font-size: 20px;
      .MMM-SystemStats td {
          line-height: 20px;
      that works for me. Not sure if that was the right way. But hey, its fine.
      BKeyportB 1 Reply Last reply
      • BKeyportB
        BKeyport Module Developer @MajorC
        @MajorC That’s the recommended way, actually. CSS should be the place you make LOOK customizations.
        Good job.
        • BKeyportB
          I’m having a heck of a time with the module freezing after a set amount of time. I believe the problem is that it’s freezing due to getting invalid data from my sensor. Is there anyone around that can help me fix it to where it checks the data, so the module continues to work?
          Thanks much!
          M 1 Reply Last reply
            MajorC Project Sponsor @BKeyport
            @BKeyport how long is “a set amount of time”?
            Have you tried https://github.com/MichMich/mmm-systemtemperature
            • BKeyportB
              I just realized I got my modules mixed up. This one works perfectly.
                joey @BKeyport
                @BKeyport said in MMM-SystemStats (cpu temp/load, fre ram ...):
                @v4r23 If you followed the install completely, reboot the system. It’s the one step that fixed it for me.
                I was having the same issue, and rebooting fixed it for me. That surprised me, since I have been able to add modules on the fly (ie., without rebooting) so far. However, since MMM-SystemStats has system calls, I guess that is the difference.
                • H
                  harney
                  Is there any way to add a second drive stat for an SSD. I run my server of an SSD, but would like to add the second SSD to the stats
                  Cheers.
                  Great module
                  StoffbeuteluweS 1 Reply Last reply
                  • StoffbeuteluweS
                    Stoffbeuteluwe Project Sponsor @harney
                    Hi i try mmm-systemtemperature but it shows (loading…) anybody the same problem?
                      JohnWick128
                      Thanks for the information, It was very helpful.
                        digied
                        Hi! MMM-SystemStats is working fine, but Free RAM shows: NaN%. How can I fix this?
                        • BKeyportB
                          BKeyport Module Developer @digied
                          @digied Did you reboot? Seems to cure a lot of the problems.
                          • N
                            Nneuland @BenRoe
                            @BenRoe
                            Hi Ben! Love the module!
                            Couple questions. My “Avail Space” portion of this module isn’t giving any values. Do you have any idea why this might be? I also am having trouble with the header not showing. My system load peaks around 2, but I’m reading that with a quad core raspi 4b, this is normal.
                            Any input would be greatly appreciated.
                            Thanks,
                            Nick
                            • 4 / 4
