    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 82.4k Views 35 Watching
    • lavolp3L
      lavolp3 Module Developer @BKeyport
      @BKeyport said in MMM-SystemStats (cpu temp/load, fre ram ...):
      that’s not working, just get NaN… I think that’s because the string’s already got the “°C” at that point.
      ah the parsefloat is missing.
      How about
      this.stats.cpuTemp = payload.cpuTemp + " / " + (parseFloat(payload.cpuTemp) * 9 / 5 + 32).toFixed(1) + "°F";
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      BKeyportB 1 Reply Last reply
      • BKeyportB
        BKeyport Module Developer @lavolp3
        @lavolp3 That did it, thank you.
        • uros76U
          uros76
          Excellent module, works great.
          I do have a question. I don’t see all the icons :/ how can I fix this?
          • BKeyportB
            BKeyport Module Developer @uros76
            @uros76 The icons are straight from font awesome, and part of the base package, from what I understand. Not having icons might be indicative of a weak connection to the 'net.
            • V
              v4r23
              missing stats
              Any idea what’s going wrong that it shows:
              loading …
              • BKeyportB
                BKeyport Module Developer @v4r23
                @v4r23 If you followed the install completely, reboot the system. It’s the one step that fixed it for me.
                J 1 Reply Last reply
                  MajorC Project Sponsor
                  is there a good way to shrink the font size and the icon size?
                  I tried
                  .MMM-SystemStats {
                  Font-size: 70%;
                  but now there are a lot of space between each line.
                  Or if I use
                  transform: scale(0.90, 0.90);
                  than the module is moved into the middle of the screen.
                  Thank you
                    UPDATE:
                    I included into the custom.css
                     * MMM-SystemStats
                    .MMM-SystemStats table {
                            width: 350px;
                            color: #666;
                            font-size: 20px;
                    .MMM-SystemStats td {
                        line-height: 20px;
                    that works for me. Not sure if that was the right way. But hey, its fine.
                    • BKeyportB
                      BKeyport Module Developer @MajorC
                      @MajorC That’s the recommended way, actually. CSS should be the place you make LOOK customizations.
                      Good job.
                      • BKeyportB
                        I’m having a heck of a time with the module freezing after a set amount of time. I believe the problem is that it’s freezing due to getting invalid data from my sensor. Is there anyone around that can help me fix it to where it checks the data, so the module continues to work?
                        Thanks much!
                        M 1 Reply Last reply
                          MajorC Project Sponsor @BKeyport
                          @BKeyport how long is “a set amount of time”?
                          Have you tried https://github.com/MichMich/mmm-systemtemperature
                          • BKeyportB
                            I just realized I got my modules mixed up. This one works perfectly.
                              joey @BKeyport
                              I was having the same issue, and rebooting fixed it for me. That surprised me, since I have been able to add modules on the fly (ie., without rebooting) so far. However, since MMM-SystemStats has system calls, I guess that is the difference.
                              • H
                                harney
                                Is there any way to add a second drive stat for an SSD. I run my server of an SSD, but would like to add the second SSD to the stats
                                Cheers.
                                Great module
                                StoffbeuteluweS 1 Reply Last reply
                                • StoffbeuteluweS
                                  Stoffbeuteluwe Project Sponsor @harney
                                  Hi i try mmm-systemtemperature but it shows (loading…) anybody the same problem?
                                    JohnWick128
                                    Thanks for the information, It was very helpful.
                                      digied
                                      Hi! MMM-SystemStats is working fine, but Free RAM shows: NaN%. How can I fix this?
                                      • BKeyportB
                                        BKeyport Module Developer @digied
                                        @digied Did you reboot? Seems to cure a lot of the problems.
                                        • N
                                          Nneuland @BenRoe
                                          @BenRoe
                                          Hi Ben! Love the module!
                                          Couple questions. My “Avail Space” portion of this module isn’t giving any values. Do you have any idea why this might be? I also am having trouble with the header not showing. My system load peaks around 2, but I’m reading that with a quad core raspi 4b, this is normal.
                                          Any input would be greatly appreciated.
                                          Thanks,
                                          Nick
                                          • 4 / 4
