    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 78.8k Views 35 Watching
    • LordyL Offline
      Lordy @lavolp3
      @lavolp3 said in MMM-SystemStats (cpu temp/load, fre ram ...):
      .MMM-SystemStats tr {
      display: none;
      .MMM-SystemStats tr:nth-child(5n+0) {
      display: table-row;
      Thanks, it helped me.
      How do I do this with “CPU_TEMP”?
      lavolp3L 2 Replies Last reply Reply Quote 0
      • lavolp3L Offline
        lavolp3 Module Developer @Lordy
        @Lordy try tr:nth-child(6n+1)
        You have 5 children in the table element, which are the 5 table rows.
        nth-child counts every “nth” children from 0.
        So if you have nth-children(3n+0) it takes the 3rd 6th 9th. Only the 3rd is there so voila.
        nth-children(6n+1) SHOULD count the 1st, 7th, 13th children, of these only the 1st is available. So, hopefully again, voila.
          getDom: function() {
            var self = this;
            var wrapper = document.createElement('table');
            var sysData = {
              cpuTemp: {
                text: 'CPU_TEMP',
                icon: 'fa-thermometer',
              sysLoad: {
                text: 'SYS_LOAD',
                icon: 'fa-tachometer',
              freeMem: {
                text: 'RAM_FREE',
                icon: 'fa-microchip',
              upTime: {
                text: 'UPTIME',
                icon: 'fa-clock-o',
              freeSpace: {
                text: 'DISK_FREE',
                icon: 'fa-hdd-o',
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • lavolp3L Offline
          @Lordy I’m honestly amazed it worked.
          LordyL 1 Reply Last reply Reply Quote 0
          • LordyL Offline
            Lordy @lavolp3
            @lavolp3
            Now I understand it.
            It also works that “tr:nth-child(5n+1)”.
            With the background knowledge, it is clear to me.
            Nice Weekend
            • BKeyportB Offline
              BKeyport Module Developer
              • BKeyportB Offline
                BKeyport Module Developer @BenRoe
                @BenRoe Hey, ben - love your module - would like to see a “quick” change if possible. Could you update the module to show both imperial and metric for CPU temp? This is only needed because I’m in a backwards country that hasn’t adopted sensable measurements, and it would be nice to have both temps on screen at the same time, so I can compare easily with others on how cool my system is.
                Thanks!
                • lavolp3L Offline
                  lavolp3 Module Developer @BKeyport
                  @BKeyport I think this sound more like a change you could do to your own version instead of a general change for the module.
                  You could insert e.g.
                  this.stats.cpuTemp = payload.cpuTemp + " / " + (payload.cpuTemp * 9 / 5 + 32).toFixed(1) + "°F";
                  into line 62
                  • BKeyportB Offline
                    BKeyport Module Developer @lavolp3
                    @lavolp3 that’s not working, just get NaN… I think that’s because the string’s already got the “°C” at that point.
                    On another point, how do you link back to the code and highlight like that?
                    • lavolp3L Offline
                      @BKeyport said in MMM-SystemStats (cpu temp/load, fre ram ...):
                      You can get a direct link by clicking on the line in github.
                      • lavolp3L Offline
                        ah the parsefloat is missing.
                        How about
                        this.stats.cpuTemp = payload.cpuTemp + " / " + (parseFloat(payload.cpuTemp) * 9 / 5 + 32).toFixed(1) + "°F";
                        • BKeyportB Offline
                          @lavolp3 That did it, thank you.
                          • uros76U Offline
                            uros76
                            Excellent module, works great.
                            I do have a question. I don’t see all the icons :/ how can I fix this?
                            • BKeyportB Offline
                              BKeyport Module Developer @uros76
                              @uros76 The icons are straight from font awesome, and part of the base package, from what I understand. Not having icons might be indicative of a weak connection to the 'net.
                              • V Offline
                                v4r23
                                missing stats
                                Any idea what’s going wrong that it shows:
                                loading …
                                • BKeyportB Offline
                                  BKeyport Module Developer @v4r23
                                  @v4r23 If you followed the install completely, reboot the system. It’s the one step that fixed it for me.
                                    MajorC Project Sponsor
                                    is there a good way to shrink the font size and the icon size?
                                    I tried
                                    .MMM-SystemStats {
                                    Font-size: 70%;
                                    but now there are a lot of space between each line.
                                    Or if I use
                                    transform: scale(0.90, 0.90);
                                    than the module is moved into the middle of the screen.
                                    Thank you
                                      UPDATE:
                                      I included into the custom.css
                                       * MMM-SystemStats
                                      .MMM-SystemStats table {
                                              width: 350px;
                                              color: #666;
                                              font-size: 20px;
                                      .MMM-SystemStats td {
                                          line-height: 20px;
                                      that works for me. Not sure if that was the right way. But hey, its fine.
                                      BKeyportB 1 Reply Last reply Reply Quote 1
                                      • BKeyportB Offline
                                        BKeyport Module Developer @MajorC
                                        @MajorC That’s the recommended way, actually. CSS should be the place you make LOOK customizations.
                                        Good job.
                                        • BKeyportB Offline
                                          I’m having a heck of a time with the module freezing after a set amount of time. I believe the problem is that it’s freezing due to getting invalid data from my sensor. Is there anyone around that can help me fix it to where it checks the data, so the module continues to work?
                                          Thanks much!
                                            MajorC Project Sponsor @BKeyport
                                            @BKeyport how long is “a set amount of time”?
                                            Have you tried https://github.com/MichMich/mmm-systemtemperature
                                            • 3 / 4
