    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 82.4k Views 35 Watching
    • lavolp3L
      lavolp3 Module Developer @Fifin404
      @Fifin404 @chinesesich The issue seems to be the change in version of Font Awesome icons.
      Try changing line 122 in MMM-SystemStats.js
              c2.innerHTML = `< i class="fa ${sysData[item].icon} fa-fw"></i>`;
      to
              c2.innerHTML = `< i class="fas ${sysData[item].icon} fa-fw"></i>`;
      ONLY change the “fa” to “fas”.
      The rest can stay the same.
      Don’t copy my input! I neede to put in a space for it to be viewable.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • LordyL
        Lordy
        How can you only display individual parameters?
        I just want to see “Free memory” for example.
        Thank you very much in advance
        lavolp3L 1 Reply Last reply
        • lavolp3L
          lavolp3 Module Developer @Lordy
          @Lordy
          if you mean free RAM, try this out in your custom.css
          .MMM-SystemStats tr {
            display: none;
          .MMM-SystemStats tr:nth-child(3n+0) {
            display: table-row;
          For free disk space it would be
            display: none;
          .MMM-SystemStats tr:nth-child(5n+0) {
            display: table-row;
          No guarantees!! I haven’t tried it!!
          LordyL 1 Reply Last reply
          • LordyL
            Lordy @lavolp3
            @lavolp3 said in MMM-SystemStats (cpu temp/load, fre ram ...):
            display: none;
            display: table-row;
            Thanks, it helped me.
            How do I do this with “CPU_TEMP”?
            lavolp3L 2 Replies Last reply
            • lavolp3L
              @Lordy try tr:nth-child(6n+1)
              You have 5 children in the table element, which are the 5 table rows.
              nth-child counts every “nth” children from 0.
              So if you have nth-children(3n+0) it takes the 3rd 6th 9th. Only the 3rd is there so voila.
              nth-children(6n+1) SHOULD count the 1st, 7th, 13th children, of these only the 1st is available. So, hopefully again, voila.
                getDom: function() {
                  var self = this;
                  var wrapper = document.createElement('table');
                  var sysData = {
                    cpuTemp: {
                      text: 'CPU_TEMP',
                      icon: 'fa-thermometer',
                    sysLoad: {
                      text: 'SYS_LOAD',
                      icon: 'fa-tachometer',
                    freeMem: {
                      text: 'RAM_FREE',
                      icon: 'fa-microchip',
                    upTime: {
                      text: 'UPTIME',
                      icon: 'fa-clock-o',
                    freeSpace: {
                      text: 'DISK_FREE',
                      icon: 'fa-hdd-o',
              • lavolp3L
                @Lordy I’m honestly amazed it worked.
                • LordyL
                  Lordy @lavolp3
                  @lavolp3
                  Now I understand it.
                  It also works that “tr:nth-child(5n+1)”.
                  With the background knowledge, it is clear to me.
                  Nice Weekend
                  • BKeyportB
                    BKeyport Module Developer
                    • BKeyportB
                      BKeyport Module Developer @BenRoe
                      @BenRoe Hey, ben - love your module - would like to see a “quick” change if possible. Could you update the module to show both imperial and metric for CPU temp? This is only needed because I’m in a backwards country that hasn’t adopted sensable measurements, and it would be nice to have both temps on screen at the same time, so I can compare easily with others on how cool my system is.
                      Thanks!
                      • lavolp3L
                        lavolp3 Module Developer @BKeyport
                        @BKeyport I think this sound more like a change you could do to your own version instead of a general change for the module.
                        You could insert e.g.
                        this.stats.cpuTemp = payload.cpuTemp + " / " + (payload.cpuTemp * 9 / 5 + 32).toFixed(1) + "°F";
                        into line 62
                        BKeyportB 1 Reply Last reply
                        • BKeyportB
                          BKeyport Module Developer @lavolp3
                          @lavolp3 that’s not working, just get NaN… I think that’s because the string’s already got the “°C” at that point.
                          On another point, how do you link back to the code and highlight like that?
                          • lavolp3L
                            @BKeyport said in MMM-SystemStats (cpu temp/load, fre ram ...):
                            You can get a direct link by clicking on the line in github.
                            • lavolp3L
                              ah the parsefloat is missing.
                              How about
                              this.stats.cpuTemp = payload.cpuTemp + " / " + (parseFloat(payload.cpuTemp) * 9 / 5 + 32).toFixed(1) + "°F";
                              • BKeyportB
                                @lavolp3 That did it, thank you.
                                • uros76U
                                  uros76
                                  Excellent module, works great.
                                  I do have a question. I don’t see all the icons :/ how can I fix this?
                                  • BKeyportB
                                    BKeyport Module Developer @uros76
                                    @uros76 The icons are straight from font awesome, and part of the base package, from what I understand. Not having icons might be indicative of a weak connection to the 'net.
                                    • V
                                      v4r23
                                      missing stats
                                      Any idea what’s going wrong that it shows:
                                      loading &hellip;
                                      • BKeyportB
                                        BKeyport Module Developer @v4r23
                                        @v4r23 If you followed the install completely, reboot the system. It’s the one step that fixed it for me.
                                        J 1 Reply Last reply
                                          MajorC Project Sponsor
                                          is there a good way to shrink the font size and the icon size?
                                          I tried
                                          .MMM-SystemStats {
                                          Font-size: 70%;
                                          but now there are a lot of space between each line.
                                          Or if I use
                                          transform: scale(0.90, 0.90);
                                          than the module is moved into the middle of the screen.
                                          Thank you
                                            UPDATE:
                                            I included into the custom.css
                                             * MMM-SystemStats
                                            .MMM-SystemStats table {
                                                    width: 350px;
                                                    color: #666;
                                                    font-size: 20px;
                                            .MMM-SystemStats td {
                                                line-height: 20px;
                                            that works for me. Not sure if that was the right way. But hey, its fine.
                                            • 3 / 4
