    MMM-SystemStats (cpu temp/load, fre ram ...)
    74 Posts 36 Posters 81.2k Views 35 Watching
    • lavolp3L
      lavolp3 Module Developer @BKeyport
      @BKeyport I think this sound more like a change you could do to your own version instead of a general change for the module.
      You could insert e.g.
      this.stats.cpuTemp = payload.cpuTemp + " / " + (payload.cpuTemp * 9 / 5 + 32).toFixed(1) + "°F";
      into line 62
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • BKeyportB
        BKeyport Module Developer @lavolp3
        @lavolp3 that’s not working, just get NaN… I think that’s because the string’s already got the “°C” at that point.
        On another point, how do you link back to the code and highlight like that?
        lavolp3L 2 Replies Last reply Reply Quote 0
        • lavolp3L
          @BKeyport said in MMM-SystemStats (cpu temp/load, fre ram ...):
          You can get a direct link by clicking on the line in github.
          • lavolp3L
            ah the parsefloat is missing.
            How about
            this.stats.cpuTemp = payload.cpuTemp + " / " + (parseFloat(payload.cpuTemp) * 9 / 5 + 32).toFixed(1) + "°F";
            • BKeyportB
              @lavolp3 That did it, thank you.
              • uros76U
                uros76
                Excellent module, works great.
                I do have a question. I don’t see all the icons :/ how can I fix this?
                • BKeyportB
                  BKeyport Module Developer @uros76
                  @uros76 The icons are straight from font awesome, and part of the base package, from what I understand. Not having icons might be indicative of a weak connection to the 'net.
                  • V
                    v4r23
                    missing stats
                    Any idea what’s going wrong that it shows:
                    loading …
                    • BKeyportB
                      BKeyport Module Developer @v4r23
                      @v4r23 If you followed the install completely, reboot the system. It’s the one step that fixed it for me.
                        MajorC Project Sponsor
                        is there a good way to shrink the font size and the icon size?
                        I tried
                        .MMM-SystemStats {
                        Font-size: 70%;
                        but now there are a lot of space between each line.
                        Or if I use
                        transform: scale(0.90, 0.90);
                        than the module is moved into the middle of the screen.
                        Thank you
                          UPDATE:
                          I included into the custom.css
                           * MMM-SystemStats
                          .MMM-SystemStats table {
                                  width: 350px;
                                  color: #666;
                                  font-size: 20px;
                          .MMM-SystemStats td {
                              line-height: 20px;
                          that works for me. Not sure if that was the right way. But hey, its fine.
                          BKeyportB 1 Reply Last reply Reply Quote 1
                          • BKeyportB
                            BKeyport Module Developer @MajorC
                            @MajorC That’s the recommended way, actually. CSS should be the place you make LOOK customizations.
                            Good job.
                            • BKeyportB
                              I’m having a heck of a time with the module freezing after a set amount of time. I believe the problem is that it’s freezing due to getting invalid data from my sensor. Is there anyone around that can help me fix it to where it checks the data, so the module continues to work?
                              Thanks much!
                                MajorC Project Sponsor @BKeyport
                                @BKeyport how long is “a set amount of time”?
                                Have you tried https://github.com/MichMich/mmm-systemtemperature
                                • BKeyportB
                                  I just realized I got my modules mixed up. This one works perfectly.
                                    joey @BKeyport
                                    I was having the same issue, and rebooting fixed it for me. That surprised me, since I have been able to add modules on the fly (ie., without rebooting) so far. However, since MMM-SystemStats has system calls, I guess that is the difference.
                                    • H
                                      harney
                                      Is there any way to add a second drive stat for an SSD. I run my server of an SSD, but would like to add the second SSD to the stats
                                      Cheers.
                                      Great module
                                      • StoffbeuteluweS
                                        Stoffbeuteluwe Project Sponsor @harney
                                        Hi i try mmm-systemtemperature but it shows (loading…) anybody the same problem?
                                          JohnWick128
                                          Thanks for the information, It was very helpful.
                                            digied
                                            Hi! MMM-SystemStats is working fine, but Free RAM shows: NaN%. How can I fix this?
                                            • 4 / 4
