    Magic Mirror Entryway Coat Rack with Storage
    16 Posts 5 Posters 6.2k Views 5 Watching
    • SharkbyteS Offline
      Sharkbyte
      Couldn’t afford the mirror yet but made this one for the front entryway door with calendar, weather, and time. Set it up so I can add the mirror later when I can afford one.
      Used a 32 inch lg tv with pi 3+ and connected it to google calendar.
      alt text
      Added hooks for coats, hats and shelves for other stuff
      Also has the pir sensor
      Oh and definitely have to install a shorter hdmi cord
      alt text
      Thank you
      Technically challenged all day everyday.
      So then I just go here Evolution MMA
      Of course though spending time with the son is always the best of the best!
      S Mykle1M 2 Replies Last reply Reply Quote 3
        ruff.hi
        Excellent way of getting more from your mirror. I like the idea of the coat rack.
        Is this a MM … or is it a coat rack?
        Nice!
        SharkbyteS 1 Reply Last reply Reply Quote 1
          Sharkbyte @ruff.hi
          @ruff-hi Thank you
            sdetweil @Sharkbyte
            @sharkbyte nice work!..
            make a backup of the software if u haven’t already
              Sharkbyte @sdetweil
              @sdetweil Thanks yep always backing up software
                Mykle1 Project Sponsor Module Developer @Sharkbyte
                @sharkbyte
                Classy bro! Well done. :thumbsup:
                  mmoayed
                  Hello , I want to implement this Model in my Magicmirror . Where can i find it.
                  But I also want to ask if you can help . When am installing any new model and install it in this folder
                  /home/pi/MagicMirror/modules
                  ![0_1643624184459_a77306d5-0c4c-44ad-be6a-76baf7f83bd4-image.png](Uploading 100%)
                  and after each installment, I have all new modules saved in the modules folder
                  ![0_1643624295201_1edca06c-1507-4f58-9546-0e8b788a641e-image.png](Uploading 100%)
                  The next step I go to the /home/pi/MagicMirror/config and I added the module
                  ![0_1643629217765_6ad392c8-fa9a-400e-969a-eb47262b5fd4-image.png](Uploading 100%)
                  but it is not working, i think i have missed something, can you help?
                    sdetweil @mmoayed
                    @mmoayed what does not working mean?
                    all your pics did not load
                    the pic in forum icon is 3rd from the right
                    sun over the mountain with the page corner folded
                      mmoayed @sdetweil
                      @sdetweil ,
                      Well, I don’t know why. I actully liked the model you have used and I want to do the same and in Calander to display 30 days per months .
                      I have embeded my google calander, but I do not know how to display as you have did.
                      This is the first part of my Question.
                      The second part is when I want to add more new modules out of default ones, for example, I follow the steps and installed Calander_montls , and first Install the model to this folder /home/pi/MagicMirror/modules
                      and then copy this code to config/config.js files.
                      What I noticed If I leave calender_momthly in /home/pi/MagicMirror/modules folder, I got an error when executing, but when I move it to ~/MagicMirror/modules/default it works without error or I have to give the path in the module name, but even if I do like this but there is no output.
                      How can you help to make all new modules to show output and how i can i use the same one you did .
                      BR,
                        sdetweil @mmoayed
                        @mmoayed read the links in my signature
                        practice a couple times. I didn’t write them but they help
                        every module install is the same
                        read their instructions for any extra steps
                        sometimes they fail into this problem
