    How do you switch on / off, wake up yours?
    15 Posts 12 Posters 21.1k Views 16 Watching
      arbeyukay
      I’m in the final stages of construction and happy with the basic installation of hardware and software. My Pi sits inside a frame with a monitor, and I can vnc in to it.
      What I’m interested in, is everyone’s methods for switching on / off and waking up etc.
      Do you leave it switched on all the time? (not my preferred choice as noone is in the house during the day and that seems a little wasteful)
      If not, how do you wake up your screen or Pi? PIR sensor, camera, some kind of switch, remote access?
      FallandeGubbeF 1 Reply Last reply Reply Quote 0
      • Y Offline
        yawns Moderator
        I intend to use a PIR sensor “almost hidden” in the frame.
          arbeyukay
          Thanks yawns, which module will you be using - MMM-PIR-Sensor?
          Out of interest, do you know if it’s possible to set the time the hdmi stays live for, or is it purely based on whether there’s any movement detected?
          • L Offline
            lolobyte
            I’m using a motion cam behind the mirror with mmal motion software running outside the mm2 as a surveillance cam!
            If there is a motion in the front of the mirror the cam turns the mm2 panel on.
            After some time without motion the sw will deactivate the panel.
              Shockwave
              I just use a cron job to put the screen to sleep at 11pm and turn it back on at 7am. My schedule is routine enough that this works well for me.
              crontab -e
              00 23 * * * /home/pi/monitor-off.sh >/dev/null # JOB_ID_1
              0 7 * * * /home/pi/monitor-on.sh >/dev/null # JOB_ID_2
              monitor-off.sh
              #!/bin/bash
              vcgencmd display_power 0
              # export DISPLAY=:0.0
              # xset dpms force off
              monitor-on.sh
              #!/bin/bash
              vcgencmd display_power 1
              # export DISPLAY=:0
              # xset dpms force on
              # xset s reset
              P F 2 Replies Last reply Reply Quote 6
                schlachtkreuzer6 @lolobyte
                @lolobyte a question :) is the cam on all the time? i´m interested to use the pi cam as a surveillance cam (something like an ip cam) und using a mm module for motion detection (wake up the screen etc.)
                • L Offline
                  lolobyte @schlachtkreuzer6
                  @schlachtkreuzer6
                  yea, all ways on.
                  If the cam recognize some motion in the front, the monitor is starting.
                  After a chosen delay time the monitor is switched off.
                  • FallandeGubbeF Offline
                    FallandeGubbe @arbeyukay
                    @arbeyukay I combined the Magic mirror with this feature and have a USB cam to detect any motion in front of mirror, if no motion the monitor is shut down. Works just fine!
                    https://maxkorlaar.com/post/?i=43&lang=en
                    • cowboysdudeC Offline
                      MMM-ModuleScheduler
                      https://github.com/ianperrin/MMM-ModuleScheduler
                      It works awesome!!!
                        AAPS
                        I personally use remote control to turn my display on. I also am thinking of using motion detection, but I probably need help. https://forum.magicmirror.builders/topic/52/pir-sensor-put-your-mirror-to-sleep-if-not-used/30
                          pugsly @Shockwave
                          @Shockwave
                          I use the same times but instead of changing the display power I use the built in tvservice app
                          0 23 * * * /opt/vc/bin/tvservice -o
                          0 6 * * * /opt/vc/bin/tvservice -p
                          • H Offline
                            Hein-Jan
                            I’m with cowboysdude,
                            MMM-ModuleScheduler combined with MMM-Remote-Control.
                            Scheduler sends MonitorOn and Off’s to Remote.
                            Works like a dream!
                              Burner911
                              I used a similar method to schedule a cron job to control a transistor placed over the push button of my tv. This lets me power the TV on and off instead of using the HDMI CEC method used for computer monitors.
                                I use MMM-ModuleScheduler for my mirror in the bathroom BUT my 32" Control Center I use:
                                https://github.com/fewieden/MMM-voice
                                Works like a charm ;)
                                • F Offline
                                  fox @Shockwave
                                  @shockwave said in How do you switch on / off, wake up yours?:
                                  crontab -e
                                  monitor-off.sh
                                  #!/bin/bash
                                  monitor-on.sh
                                  #!/bin/bash
                                  # export DISPLAY=:0
                                  # xset s reset
                                  Great !
                                  I will give it a try
                                  Issues With MMM-WatchDog known?
                                  https://forum.magicmirror.builders/post/29827
                                  Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
