    MMM-Gas Still Working?
    18 Posts 6 Posters 6.3k Views 5 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @sifuhall
      @sifuhall said in MMM-Gas Still Working?:
      @mykle1
      For some reason mine isn’t working. I don’t see any errors with npm start dev and my config.sys checks out with npm run config:check
      Could you try for zipcode 40391 and see if that works for you? Maybe there are just no results?
      I sure will when i get home from work. I will post back.
        @sifuhall Here is what I am getting:
            dist: '2.5 miles',
            address: '39 S Maple St Winchester KY 40391',
            ppg: '¤3.60'
            dist: '2.56 miles',
            address: '4 W Washington St Winchester KY 40391',
            ppg: '¤3.55'
            name: 'Clarks Pump N Shop #81',
            dist: '2.58 miles',
            address: '201 N Main St Winchester KY 40391',
            ppg: '¤3.55'
            dist: '3.69 miles',
            address: '105 April Way Dr Winchester KY 40391',
            ppg: '¤3.59'
            name: 'Murphy Express #8605 (discount Available)',
            dist: '3.85 miles',
            address: '120 Codella Dr Winchester KY 40391',
            ppg: '¤3.38'
            dist: '3.9 miles',
            address: '108 Rolling Hills Ln Winchester KY 40391',
            ppg: '¤3.64'
            name: 'Kroger Fuel Center #8402 (discount Available)',
            dist: '4.29 miles',
            address: '1661 Bypass Rd Winchester KY 40391',
            ppg: '¤3.40'
            dist: '4.42 miles',
            address: '1480 W Lexington Ave Winchester KY 40391',
            ppg: '¤3.53'
            name: 'Fas Mart #5262',
            dist: '4.56 miles',
            address: '5400 Revilo Rd Winchester KY 40391',
            ppg: '¤3.56'
            name: 'Apple Market #526',
            dist: '4.63 miles',
            address: '570 Van Meter Rd Winchester KY 40391',
            ppg: '¤3.56'
        That is in the terminal window…
        For the results with your zip code. I see no front end errors
        here are the results for that…
        0: {name: 'Murphy Express #8605 (discount Available)', dist: '3.85 miles', address: '120 Codella Dr Winchester KY 40391', ppg: '¤3.38'}
        1: {name: 'Kroger Fuel Center #8402 (discount Available)', dist: '4.29 miles', address: '1661 Bypass Rd Winchester KY 40391', ppg: '¤3.40'}
        2: {name: 'Speedway #8256', dist: '4.42 miles', address: '1480 W Lexington Ave Winchester KY 40391', ppg: '¤3.53'}
        3: {name: 'Shell', dist: '2.56 miles', address: '4 W Washington St Winchester KY 40391', ppg: '¤3.55'}
        4: {name: 'Clarks Pump N Shop #81', dist: '2.58 miles', address: '201 N Main St Winchester KY 40391', ppg: '¤3.55'}
        5: {name: 'Fas Mart #5262', dist: '4.56 miles', address: '5400 Revilo Rd Winchester KY 40391', ppg: '¤3.56'}
        6: {name: 'Apple Market #526', dist: '4.63 miles', address: '570 Van Meter Rd Winchester KY 40391', ppg: '¤3.56'}
        7: {name: 'Shell', dist: '3.69 miles', address: '105 April Way Dr Winchester KY 40391', ppg: '¤3.59'}
        8: {name: 'Speedway #9600', dist: '2.5 miles', address: '39 S Maple St Winchester KY 40391', ppg: '¤3.60'}
        9: {name: 'Hardys Bp', dist: '3.9 miles', address: '108 Rolling Hills Ln Winchester KY 40391', ppg: '¤3.64'}
        length: 10
        [[Prototype]]: Array(0)
        Please post your config so I can look at that.
        sifuhallS 1 Reply Last reply Reply Quote 0
        • sifuhallS Offline
          sifuhall @cowboysdude
          @cowboysdude
          			module: 'MMM-Gas',
          			position: 'top_left',
          				zip : "40391",
          				typeGas: "", //can be "mid-grade", "premium", or "diesel".  Leave blank for regular gas prices
          				sortBy: "price",	//can be "distance" or "price"
          				items: "10",	//number of gas stations to display
          				distance: false  //to hide distance column
          sifuhallS karsten13K cowboysdudeC 3 Replies Last reply Reply Quote 0
          • sifuhallS Offline
            sifuhall @sifuhall
            @sifuhall
            Just an FYI this is the output of my npm start dev
            > magicmirror@2.18.0 start
            > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
            [23.02.2022 17:38.54.232] [LOG]   Starting MagicMirror: v2.18.0
            [23.02.2022 17:38.54.235] [LOG]   Loading config ...
            [23.02.2022 17:38.54.973] [LOG]   Starting node_helper for module [MMM-MyScoreboard]
            [23.02.2022 17:38.55.215] [LOG]   Starting node helper: MMM-json
            [23.02.2022 17:38.55.216] [LOG]   Started node_helper.js for MMM-DailyBibleVerse.
            [23.02.2022 17:38.58.075] [INFO]  [MMM-DynamicWeather] Getting Holiday data
            [23.02.2022 17:38.58.101] [INFO]  [MMM-DynamicWeather] Getting Weather API data
            [23.02.2022 17:38.58.284] [LOG]   Notification: MMM_JSON_REQUEST Payload: {
                url: 'http://192.168.1.50:8079',
                refreshInterval: 300000,
                styleRules: [],
                values: [ [Object], [Object], [Object], [Object], [Object] ]
              identifier: 'module_7_MMM-json'
            [23.02.2022 17:38.58.295] [LOG]   MMM-DailyBibleVerse node helper received a socket notification: START - Payload: NIV
            [23.02.2022 17:38.58.602] [DEBUG] Response {
              [Symbol(Body internals)]: {
                body: PassThrough {
                  _readableState: [ReadableState],
                  _events: [Object: null prototype],
                  _eventsCount: 5,
                  _maxListeners: undefined,
                  _writableState: [WritableState],
                  allowHalfOpen: true,
                  [Symbol(kCapture)]: false,
                  [Symbol(kCallback)]: null
                stream: PassThrough {
                  _eventsCount: 5,
                boundary: null,
                disturbed: false,
                error: null
              [Symbol(Response internals)]: {
                type: 'default',
                url: 'http://192.168.1.50:8079/',
                status: 200,
                statusText: 'OK',
                headers: {
                  connection: 'close',
                  'content-type': 'text/html; charset=UTF-8',
                  date: 'Wed, 23 Feb 2022 22:38:58 GMT',
                  server: 'nginx',
                  'transfer-encoding': 'chunked'
                counter: 0,
                highWaterMark: 16384
            [23.02.2022 17:38.58.778] [INFO]  [MMM-DynamicWeather] Received successful Weather API data
            [23.02.2022 17:38.59.204] [INFO]  [MMM-DynamicWeather] Received successful Holiday data
            [23.02.2022 17:38.59.254] [LOG]   {"votd":{"text":"“Do not those who plot evil go astray? But those who plan what is good find love and faithfulness.”","content":"Do not those who plot evil go astray? But those who plan what is good find love and faithfulness.","display_ref":"Proverbs 14:22","reference":"Proverbs 14:22","permalink":"https:\/\/www.biblegateway.com\/passage\/?search=Proverbs%2014:22&version=NIV","copyright":" ","copyrightlink":"https:\/\/www.biblegateway.com\/versions\/index.php?action=getVersionInfo&vid=31&lang=2","audiolink":"https:\/\/www.biblegateway.com\/audio\/mclean\/niv\/Prov.14.22","day":"23","month":"02","year":"2022","version":"New International Version","version_id":"NIV","merchandising":""}}
            • karsten13K Offline
              karsten13 @sifuhall
              @sifuhall
              try items: 10,
                mid-grade
                I can come up with possibly 2 problems…
                Either npm install wasn’t run in the MMM-Gas module directory OR
                if you copied the example config from github quotes do not copy correctly.
                So go in and wherever there is a quote ’ or " delete them and from your own keyboard redo them ’ or "…
                Let me know.
                  Mykle1 Project Sponsor Module Developer @sifuhall
                  I tested your zip code and the typeGas options. Everything seems to work fine. I’m sure cowboysdude will get you sorted
                  I see he a;ready left some suggestions. Follow those and see what you get
                    sdetweil @cowboysdude
                    @cowboysdude but the quotes would be a mm config.js syntax error. so that’s not it
                    • strawberry 3.141S Offline
                      @sifuhall I just tried it with your config and it didn’t show up either.
                      I then noticed that the repository is called MMM-GAS, but the files and config are MMM-Gas. After renaming the directory of the module to MMM-Gas it was working fine.
                      If you followed the git clone command in the read me file it already has the correct directory name, but if you know how to clone a repo or copied the git clone command provided by Github itself then you probably have the same issue.
                      sifuhallS cowboysdudeC 2 Replies Last reply Reply Quote 2
                      • sifuhallS Offline
                        sifuhall @strawberry 3.141
                        @strawberry-3-141
                        That fixed it! Thank you!
                        I copied and pasted the clone command from Github and had no idea why it would not work.
                        Thanks again!
