Develop module with API
42 Posts 6 Posters 13.1k Views 6 Watching
    Mykle1 Project Sponsor Module Developer @htilburgs
    @htilburgs said in Develop module with API:
    mptFajr.innerHTML = "Fajr : " + MPT.Fajr;
    Is this correct? MPT.Fajr above? Not mpt.Fajr?
    S 1 Reply Last reply Mar 19, 2019, 11:47 PM Reply Quote 0
      sdetweil @Mykle1
      @Mykle1 it’s not json format. Same problem as your PC stats
      • H Offline
        htilburgs
        @Mykle1, @sdetweil ,
        Looking at the website from the API Prayer Times API, the result are all displayed in JSON
        The API has several endpoints to assist developers. Note that all the endpoints return JSON and are available over http and https.
        I’ve looked at the code again and it should be MPT.Fajr.
        I’ve made the module public on github, so you can take a look if you like.
        MMM-MyPrayerTime
        Meanwhile I’m trying to solve it…
        (still trying to learn JS, but not afraid to ask) ☺
        ? 1 Reply Last reply Mar 20, 2019, 7:43 AM Reply Quote 0
        • ? Offline
          A Former User @htilburgs
          @htilburgs
          I don’t know what you exactly want,
          but ,
          Instead
          var MPT = this.MPT[Keys[this.activeItem]];
          Use this;
          var MPT = this.MPT
          You can get above picture.
          • H Offline
            htilburgs
            @Sean,
            This is what I want. Thanx for the quick reply!
            Can you tell me what is the difference in the code?
            This was an example from the MMM-UFO where information is rotated.
            Because I don’t need it, I’m going to cleanup.
            ? 1 Reply Last reply Mar 20, 2019, 8:15 AM Reply Quote 0
            • ? Offline
              @htilburgs
              Well, I don’t know what exactly you’ve tried, so difficult to tell what was wrong.
              But,
              You’ve already gotten timings from response of API in node_helper.js, and transfered it to your main module.
              var result = JSON.parse(body).data.timings;
              So your this.MPT might have this object structure;
                    "Fajr":"04:06",
                    "Sunrise":"05:35",
                    "Dhuhr":"11:39",
              So, All you need is just refer it like this.MPT.Fajr.
              • H Offline
                htilburgs
                @Sean,
                Thank you for explaining and pointing me out.
                I understand what was the issue. I’ve cleaned up the code and removed the caroussel part (and unneeded variables), because I don’t use that.
                Added the possibility for showing or not showing some items.
                Up to the next part… HTML Markup
                • H Offline
                  htilburgs
                  Strugling with formatting. When I use the basic code, I got the result I like but it’s not displayed nice. I like to have 3 columns.
                  		var MPT = this.MPT;
                  		// Creating the div's for your data items
                  		var top = document.createElement("div");
                  		top.classList.add("list-row");
                  		// Fajr from data
                  		var mptFajr = document.createElement("div");
                  		mptFajr.classList.add("small", "bright", "Fajr");
                  		mptFajr.innerHTML = "Fajr : " + MPT.Fajr + " الفجر";
                  		wrapper.appendChild(mptFajr);
                  		// Sunrise from data
                  		if (this.config.showSunrise != false) {
                  		    var mptSunrise = document.createElement("div");
                  		    mptSunrise.classList.add("small", "bright", "Sunrise");
                  		    mptSunrise.innerHTML = "Sunrise : " + MPT.Sunrise + " شروق الشمس";
                  		    wrapper.appendChild(mptSunrise);
                  		// Dhuhr from data
                  		var mptDhuhr = document.createElement("div");
                  		mptDhuhr.classList.add("small", "bright", "Dhuhr");
                  		mptDhuhr.innerHTML = "Duhr : " + MPT.Dhuhr + " الظهر";
                  		wrapper.appendChild(mptDhuhr);
                  		// Asr from data
                  		var mptAsr = document.createElement("div");
                  		mptAsr.classList.add("small", "bright", "Asr");
                  		mptAsr.innerHTML = "Asr : " + MPT.Asr + " العصر";
                  		wrapper.appendChild(mptAsr);
                  		// Sunset from data
                  		if (this.config.showSunset != false) {
                  		    var mptSunset = document.createElement("div");
                  		    mptSunset.classList.add("small", "bright", "Sunset");
                  		    mptSunset.innerHTML = "Sunset : " + MPT.Sunset + " غروب الشمس";
                  		    wrapper.appendChild(mptSunset);
                  		// Maghrib from data
                  		var mptMaghrib = document.createElement("div");
                  		mptMaghrib.classList.add("small", "bright", "Maghrib");
                  		mptMaghrib.innerHTML = "Maghrib : " + MPT.Maghrib + " المغرب";
                  		wrapper.appendChild(mptMaghrib);
                  		// Isha from data
                  		var mptIsha = document.createElement("div");
                  		mptIsha.classList.add("small", "bright", "Isha");
                  		mptIsha.innerHTML = "Isha : " + MPT.Isha + " العشاء";
                  		wrapper.appendChild(mptIsha);
                  		// Midnight from data
                  		if (this.config.showMidnight != false) {
                  		    var mptMidnight = document.createElement("div");
                  		    mptMidnight.classList.add("small", "bright", "Midnight");
                  		    mptMidnigh
                  alt text
                  Now I trying for several hours to figure out how to create table, columns, rows…
                  I’ve changed the code part to
                  		var MPT = this.MPT;
                  		var logs = document.createElement("table");
                  		var callWrapper = document.createElement("tr");
                  		callWrapper.classList.add("small");
                  		// Fajr
                  		var FajrTextCell = document.createElement("td");
                  		FajrTextCell.className.add = "xsmall bright fajrtext";
                  		FajrTextCell.innerHTML = "Fajr";
                  		callWrapper.appendChild(FajrTextCell);
                  		var FajrTimeCell = document.createElement("td");
                  		FajrTimeCell.className = "xsmall bright fajrtime";
                  		FajrTimeCell.innerHTML = MPT.Fajr;
                  		callWrapper.appendChild(FajrTimeCell);
                  		var FajrArabCell = document.createElement("td");
                  		FajrArabCell.className = "xsmall bright fajrarab";
                  		FajrArabCell.innerHTML = "الفجر";
                  		callWrapper.appendChild(FajrArabCell);
                  		logs.appendChild(callWrapper);
                  		wrapper.appendChild(logs);
                  		return wrapper;
                  The result for 1 item is nice
                  alt text
                  But when I repeat this for the other items, no rows are created and everything is on the same row.
                  		var MPT = this.MPT;
                  //Table Test
                  		// Fajr
                  		// Sunrise
                  		var SunriseTextCell = document.createElement("td");
                  		SunriseTextCell.className.add = "xsmall bright sunrisetext";
                  		SunriseTextCell.innerHTML = "Sunrise";
                  		var SunriseTimeCell = document.createElement("td");
                  		SunriseTimeCell.className = "xsmall bright fajrtime";
                  		SunriseTimeCell.innerHTML = MPT.Sunrise;
                  		callWrapper.appendChild(SunriseTimeCell);
                  		var SunriseArabCell = document.createElement("td");
                  		SunriseArabCell.className = "xsmall bright sunrisearab";
                  		SunriseArabCell.innerHTML = "شروق الشمس";
                  		callWrapper.appendChild(SunriseArabCell);
                  		return wrapper;
                  alt text
                  Any help to get me on the right track again?
                  ? 1 Reply Last reply Mar 20, 2019, 9:07 PM Reply Quote 0
                  • ? Offline
                    @htilburgs
                    Insert “tr” element after each row.
                    • H Offline
                      htilburgs
                      Don’t I do this with this?
                      S ? 2 Replies Last reply Mar 20, 2019, 9:29 PM Reply Quote 0
                      • 2 / 5
                      2 / 5
