    MMM-Advent - Advent Candle
    Scheduled Pinned Locked Moved Fun & Games
    adventcandlemodule
    3 Posts 3 Posters 4.6k Views 3 Watching
    • J
      Jopyth Moderator
      Description:
      This module for the MagicMirror shows a candle, which burns turn towards a specified date (e.g. as an advent candle).
      Screenshot:
      Three example candles
      Download:
      [card:Jopyth/MMM-Advent]
      [1.0.2] - 2016-12-04
      Changed
      • Configuration options:
        • start and end can be an array of timestamps now
        • if they are, multiple candles are created side by side, one for each element in both arrays (length of both arrays should match)
        • Example for four red candles, lightning up at each advent sunday (disable animation with enableAnimation: false, if the flicker does not look nice):
              module: "MMM-Advent",
              position: "bottom_center",
                  marks: 0,
                  candleColor: "#EE1111",
                  start: ["2016-11-27 14:00:00", "2016-12-04 14:00:00", "2016-12-11 14:00:00", "2016-12-18 14:00:00"],
                  end: ["2016-12-24 22:00:00", "2016-12-24 22:00:00", "2016-12-24 22:00:00", "2016-12-24 22:00:00"]
      [1.0.1] - 2016-11-22
      Added
        • enableAnimation - set to false to disable flame animation, default is true
        • fontCSS - link to a custom font stylesheet, default is https://fonts.googleapis.com/css?family=Dosis
        • fontColor - the color of the marks on the candle, default is #000000 (black)
        • candleColor - the color of the candle, default is #FFFFFF (white)
        • font - the font used (probably depends on the fontCSS option, default is 'Dosis', sans-serif
      Changed
      • Value are applied through a css stylesheet
      • Default font is a bold version of Dosis
      • Default candle height is 425
      Fixed
      • If flame is shown before the start time, it does no longer hover way above the candle
      Removed
      • Loading of pumpkin font
      [1.0.0] - 2016-11-20
      Initial release of the Advent module.
      Helpful sticky: How to troubleshoot
      Reply Quote 3
      • J
        justindp2006
        Trying to use this module and it works on the web browser remotely viewing the “mirror” but on the LCD itself there is no candle. Any ideas?
        • H
          Hacksaw
          module: “MMM-Advent”,
          position: “bottom_center”,
          marks: 0,
          candleColor: “#EE1111”,
          start: [“2018-12-02 14:00:00”, “2018-12-09 14:00:00”, “2018-12-16 14:00:00”, “2018-12-23 14:00:00”],
          end: [“2018-12-24 22:00:00”, “2018-12-24 22:00:00”, “2018-12-24 22:00:00”, “2018-12-24 22:00:00”]
