    Something I'm working on ...
    Scheduled Pinned Locked Moved Announcements
    39 Posts 12 Posters 41.8k Views 12 Watching
    • strawberry 3.141S Offline
      Are you fine with using your api endpoint http://beta.magicmirror.builders/api/module for mobile app or remote control?
      • MichMichM Offline
        MichMich
        @strawberry-3-141 Feel free to use it, BUT …
        • Keep in mind the URL will change in the future.
        • I can’t promise it will stay the same.
        • Keep in mind that it will only give you a subset of the modules. (user query paramaters limit and offset to get more)
        If it turns out external API usage will be too heavy, I might limit the access using API keys.
          roramirez Core Contributors
          Its great. With this, I was thinking is possible create a installer system, its somethings i was thinking from time ago.
          Using the API and the parameters of configuration per every module its possible create the section of module for add into the config.js
          Easy module development with MagicMirror Module Template
          • MichMichM Offline
            MichMich
            By the way, this project is in a horrible raw early alpha stage … buttt, if someone is interested to contribute, the source code is available here: https://github.com/MichMich/MagicMirror-Website/tree/develop
            Be advised: the code needs a lot of refactoring and misses a lot of commenting.
            The frontend is a SPA based on Vue.js and a bit of Vuex. The Backend/Api is based on Laravel.
            If you clone the repo, take the following steps to get it up and running:
            • Run: composer install
            • Run npm install
            • Create an environment configuration: cp .env.example .env
            • Run php artisan key:generate`
            • Modify the database and github settings in the .env file. (You need to create a github app for testing.)
            • Run php artisan migrate --seed to setup the database.
            If you make any changes to /resources/assets/js or /resources/assets/sass, make sure to run gulp to compile.
              Jopyth Moderator @roramirez
              @roramirez Installer system is a great idea, however this is something that @strawberry-3-141 will implement as a mobile app, from what I hear plus I am building something like this into my remote control (a website - currently on the develop branch). So maybe have a look at it, before you start something completely new. Although, if there is a good reason for building this again or in a different way, count me in.
              Helpful sticky: How to troubleshoot
              • yawnsY Offline
                yawns Moderator
                Very nice, MichMich. I like the integration with github pulling almost all data and as such removing the need to enter description and all that over and over again. I added my modules
                  Thanks @MichMich the information. I will take a look of code :)
                  Hi @Jopyth , do you know where I can find some code or design about the @strawberry-3-141 app?
                  I think we can bootstrap a app for install apps (modules) into a MagicMirror with API provider by modules section of web. The idea it’s most like a packages manager + configuration.
                  • MichMichM Offline
                    MichMich
                    If you work on such an installer. Make sure it’s based on the module infrastructure where possible. That we you can develop and test is, without the need of directly integrating it in mm2. If It’s fully up and running and tested, we can integrate it by adding it to the list of default modules.
                    • CatoC Offline
                      Cato Module Developer
                      @MichMich I noticed that format of table markdown is not optimal. The rows should be alternating color. A good example that current format is bad is here: http://beta.magicmirror.builders/module/29/motioneye. Notice that it’s difficult to see what configuration value belongs to which description…
                      • LukeCodewalkerL Offline
                        LukeCodewalker Module Developer
                        Hey,
                        another problem with tables:
                        if you use html-tables in your GitHub README.md it’s not displayed the right way.
                        Example: http://beta.magicmirror.builders/module/33/soccerlivescore
                        MichMichM 1 Reply Last reply Reply Quote 0
                        • 4 / 4
