    Mirror starts not correct
    18 Posts 5 Posters 8.3k Views 4 Watching
    • T Offline
      thedk
      Could somebody help with this fault?
      [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
      /home/pi/.pm2/logs/mm-out.log last 15 lines:
      0|mm       | Initializing new module helper ...
      0|mm       | Module helper loaded: MMM-Remote-Control
      0|mm       | Module helper loaded: MMM-Remote-Control-Repository
      0|mm       | Module helper loaded: MMM-ModuleScheduler
      0|mm       | Module helper loaded: MMM-PIR-Sensor
      0|mm       | No helper found for module: MMM-EyeCandy.
      0|mm       | Whoops! There was an uncaught exception...
      0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      /home/pi/.pm2/logs/mm-error.log last 15 lines:
      0|mm       |     at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
      0|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:551:3)
      0|mm       |     at Module.require (internal/modules/cjs/loader.js:658:17)
      0|mm       |     at require (internal/modules/cjs/helpers.js:20:18)
      0|mm       | XDG_RUNTIME_DIR (/run/user/1000) is not owned by us (uid 0), but by uid 1000! (This could e g happen if you try to connect to a non-root PulseAudio as a root user, over the native protocol. Don't do that.)
      0|mm       | TypeError: Invalid item
      0|mm       |     at Menu.insert (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu.js:109:11)
      0|mm       |     at Menu.append (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu.js:104:15)
      0|mm       |     at sorted.forEach (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu.js:171:10)
      0|mm       |     at Array.forEach (<anonymous>)
      0|mm       |     at Function.Menu.buildFromTemplate (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/menu.js:167:10)
      0|mm       |     at App.app.once (/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js:240:21)
      0|mm       |     at Object.onceWrapper (events.js:273:13)
      0|mm       |     at App.emit (events.js:187:15)
      0|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.
      Yesterday i made the update to 2.8.0 and now the mirror starts but i cant see it. I just see the startscreen.
      The Log doesnt make sence to me.
      • bheplerB Offline
        bhepler Module Developer
        That’s… well, that’s a new one.
        I hate to say it, but I would recommend a reinstall of the MagicMirror framework. This isn’t pleasant but it can be accomplished in about 30 minutes.
        First step: back up your config.js file. Copy it to your /home/pi directory or wherever. Verify that it copied properly.
        Second step: write down a list of all of your installed modules.
        3rd step: Stop the magic mirror framework. Usually this is pm2 stop all.
        4th step: Delete the magic mirror folder. rm -rf /home/pi/MagicMirror
        5th re-clone Magic Mirror manually. git clone https://github.com/MichMich/MagicMirror.git
        6th step: install Magic Mirror (this will take a few minutes):
        cd /home/pi/MagicMirror
        npm install
        7th step - Install modules: Change to the modules folder: cd /home/pi/MagicMirror/modules. For each module in your config.js file, find them on GitHub and clone the module. git clone [module url]. Be sure to follow the installation instructions for each module. Some will be easy, some will involve the npm install command, and some will be complex (MMM-FitBit).
        8th Step - copy your config.js from backup to the original location in /home/pi/MagicMirror/config.
        9th step: run the MagicMirror process and see how she rolls: pm2 start MagicMirror.
          sdetweil @bhepler
          @bhepler rename the magic mirror folder. Do not delete til u are happily running again
          • T Offline
            thedk
            A reinstall wouldnt be the Problem. It is not the first time i have to do this ^^
            But i really dont unterstand why he wont start anymore. I also had this before the update, forgot to write. From one to the other the Mirror doesnt starts just with the first start of the day. When i reboot or just unplug the Pi, the mirror starts correct
              Mykle1 Project Sponsor Module Developer @thedk
              @thedk said in Mirror starts not correct:
              I hope you’re shutting down correctly before pulling the plug on the Pi. Your SD card will likely become corrupted. Just something you should think about.
              S T 2 Replies Last reply Reply Quote 0
                sdetweil @Mykle1
                @Mykle1 one of my sd cards suddenly became read only… no fix…
                had to buy new sd card
                • T Offline
                  thedk @Mykle1
                  @Mykle1
                  I just unplug the Pi sometimes since he is not starting anymore
                  I know thats not the best way, it’s my 4th Pi ;)
                    You can’t choose “Shut Down” from the desktop? Once the shut down is complete, THEN pull the plug to power down the Pi
                      @sdetweil said in Mirror starts not correct:
                      Sux! :-(
                      • T Offline
                        thedk @Mykle1
                        @Mykle1
                        No i cant. I just can reboot or shutdown the Pi by Terminal.
                        I know i shouldnt unplug the Pi ^^
