    new update/upgrade script, ready for testing
    328 Posts 27 Posters 706.0k Views 24 Watching
      bobwilliams
      yes PI zero WH
      pi@raspberrypi:~ $ uname -m
      armv6l
        sdetweil @bobwilliams
        @bobwilliams
        ok, lets try this
        cd ~/MagicMirror
        npm install --arch=armv71 electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
          bobwilliams
          ok it started … in my opinion this is a long process
            @bobwilliams yes, but only 5 minutes
              bobwilliams
              but no, it seems to have accelerated … at first he thought for a long time for some reason
                bobwilliams
                sent by mail
                mistakes again
                  @bobwilliams yes, I see… working
                    @sdetweil weird…
                    ok, my fault… number 1 and l (lowercase letter L ) looks close to the same
                    lets try again
                    cd ~/MagicMirror
                    npm install --arch=armv7l electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
                    notice the 7l the char after 7 is taller than the number
                    and with number 71 it is not taller
                      bobwilliams
                      Yes, I also did not pay attention
                        @bobwilliams you shouldn’t have to!.. there is arm6 L and B (lowercase) and arm7 L and B (lowercase)
                        there is no arm 7 1… and the darned download website agrees!!
                        but my upgrade script used number, instead of letter… (and there is no electron 3.013 for arm6 L), but there IS for arm7 L
                        and my 1st instructions to you used number instead of letter…
                          bobwilliams
                          pi@raspberrypi:~/MagicMirror $ npm install --arch=armv7l electron@3.0.13 | tee -a ~/MagicMirror/installers/upgrade.log
                          electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
                          node install.js
                          Downloading tmp-13770-1-SHASUMS256.txt-3.0.13
                          [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
                          npm WARN acorn-jsx@5.0.2 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
                          npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                          • electron@3.0.13
                            added 5 packages from 6 contributors and audited 3475 packages in 652.83s
                            found 28 vulnerabilities (1 low, 1 moderate, 26 high)
                            run npm audit fix to fix them, or npm audit for details
                            @bobwilliams woohoo!!!..
                            now try to start mirror
                              bobwilliams
                              this site can’t be reached
                              localhost refused to connect
                                @bobwilliams can I see your start script?
                                  bobwilliams
                                  Yes, where do I need to look for him? ))))
                                    @bobwilliams how do you start mirror? pm2, or something else
                                    if pm2, pm2 show 0, and there is a script path,
                                    mine is /home/odroid/MagicMirror/installers/mm.sh
                                      @sdetweil and if it is pm2, then show pm2 logs --lines=100
                                      (will have to ctrl-c to get out)
                                        bobwilliams
                                        in mm.sh file
                                        cd ~ / MagicMirror
                                        DISPLAY =: 0 npm start
                                        pi@raspberrypi:~ $ pm2 logs mm
                                        [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                                        did not quite understand how this is done
                                          @bobwilliams ok… do
                                          pm2 stop 0
                                          then
                                          cd ~/MagicMirror
                                          npm start
                                          you should get a bunch of messages
                                            bobwilliams
                                            magicmirror@2.9.0 start /home/pi/MagicMirror
                                            sh run-start.sh
                                            • 6
                                            • 7
                                            • 8
                                            • 16
                                            • 17
                                            • 6 / 17
