    Won't restart/stuck at prompt
    16 Posts 5 Posters 7.2k Views 5 Watching
      motdog
      I had to unplug my mirror and shut it down for the 1st time in months. When I plugged it back in I get to the prompt & that’s it. I have tried pm2 restart mm. No luck. Went into MM folder and tried npm start & that didn’t work
      On pi 3b+ with the new version of MM installed. I set up pm2 when I created the mirror.
      Any thoughts before I start over from scratch
        sdetweil @motdog
        @motdog do
        pm2 logs
          motdog @sdetweil
          @sdetweil OK. I’ll have to remove the pi from my mirror & hook up to a tv so I can try to get the info. Ive got screen rotated and its hard to read through the mirror.
            sdetweil @motdog
            @motdog ssh into mirror
              motdog @sdetweil
              @sdetweil when I connect via VNC I see something that says can’t currently display desktop
                sdetweil @motdog
                @motdog one of the reasons I don’t use vnc
                  motdog @sdetweil
                  This post is deleted!
                    motdog
                    @sdetweil said in Won't restart/stuck at prompt:
                    pm2 logs
                    Is this what you were looking for?
                      sdetweil @motdog
                      @motdog sadly this looks like an SD card corruption. Bad file header loading library
                        motdog @sdetweil
                        @sdetweil well that gives me a weekend project then. Is the card reusable with a wipe or do I need to buy a new one?
                        • mumblebajM Offline
                          mumblebaj Module Developer @motdog
                          @motdog Probably easier and cheaper to buy a new card. There are some tools out there that you can use to check for bad sectors. But again it is probably cheaper and easier to buy a new one.
                            motdog @mumblebaj
                            @mumblebaj Thanks, thats what I figured
                            • L Offline
                              lxne Project Sponsor @motdog
                              @motdog It is always a good idea to make a backup of a running system so you can clone it onto a new sd in case.
                              https://beebom.com/how-clone-raspberry-pi-sd-card-windows-linux-macos/
                                In addition to having a img backup, it’s always a good idea to backup the config file and custom css file.
                                To avoid card corruptions, always SSH into the RPi and perform a sudo shutdown instead of just pulling the plug.
                                S M 2 Replies Last reply Reply Quote 1
                                  sdetweil @retroflex
                                  @retroflex i had one card suddenly go read-only…
                                    motdog @retroflex
                                    @retroflex I used the shutdown from MMM-remotecontrol to shut it down. 8 did have a backup of config & css on laptop so it was just reinstalling modules for the most part
