    Blank mm after update
    48 Posts 4 Posters 18.7k Views 4 Watching
      sdetweil
      missing a required node package ‘del’
      no package.json to inform the user
        sdetweil
        warning, warning… copy and save
        MagicMirror/modules/node_modules/node_helper (folder, which contains index.js)
        then
        cd ~/MagicMirror/modules/mmm-weatherchart
        npm install del
        check for a missing
        MagicMirror/modules/node_modules/node_helper folder
        and if so, copy it back
        i opened an issue with mmm-weatherchart
        • evroomE Offline
          evroom
          @sdetweil said in Blank mm after update:
          seems odd that there would be two invocations of these modules…
          I have only one mmm-weatherchart module present.
          When disabled everything is fine.
          However, I forgot to remove the single quotes, as I just copy/pasted the config from the thread.
          Corrected it, but now I get even stronger things.
          0|mm  | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'del'
          I do not have any string with ‘del’ in my config :worried_face:
          MagicMirror version: 2.33.0
          Test environment:
          MagicMirror version: v2.33.0
            sdetweil @evroom
            @evroom see my prior most about the missing module
            • evroomE Offline
              evroom
              I was typing while you answered.
              Will have a look at it and try it out.
              Test environment:
              • evroomE Offline
                evroom
                The module is running now, but I get this error:
                0|mm  | Downloading weather map with signal: FETCH_MAP From URL: www.yr.no/place/Germany/Bavaria/Nuremberg/meteogram.png
                0|mm  | Error: ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/mmm-weatherchart/cache/map-1567097174409.png'
                pi@raspberrypi:~/MagicMirror/modules/mmm-weatherchart $ ll /home/pi/MagicMirror/modules/mmm-weatherchart/cache
                total 12
                4 drwxr-xr-x 2 pi pi 4096 Aug 29 18:49 .
                4 drwxr-xr-x 4 pi pi 4096 Aug 29 18:44 ..
                4 -rw-r--r-- 1 pi pi    6 Aug 29 18:44 .gitignore
                Then I read somewhere there is a clone of this module that is more recent, so I tried that:
                https://github.com/szech/mmm-weatherchart
                Same result: module runs but no file in the cache dir.
                When opening the URL in the browser, it does show the picture that I do not see on my screen.
                Oh boy/girl, thought it was a simple syntax thingy in config.js …
                Test environment:
                  sdetweil
                  the module doesn’t work, but doesn’t kill MagicMirror anymore…
                  • evroomE Offline
                    evroom
                    Correct.
                    I have a few questions.
                    In the original module there is no package.json file, where in the cloned one there is.
                    So, when using the original module, you should NOT use npm install, right ?
                    First of all it will no do anything useful, but it WILL delete your /home/pi/MagicMirror/modules/node_modules/node_helperdirectory and its index.js file.
                    When using the cloned module, you should run npm installin order to install the dependencies mentioned in it, right ?
                    No harm is done to the node_helper dir.
                    Or is it all BS I am telling here (and made the wrong observations) ??
                    Test environment:
                      sdetweil @evroom
                      @evroom i cloned and got no package.json
                      i cloned this
                      https://github.com/paphko/mmm-weatherchart
                        sdetweil @evroom
                        @evroom yes, to all your observations…
                        • 2 / 5
