    System Temperature
    7 Posts 5 Posters 1.8k Views 5 Watching
    • N Offline
      Newtothis
      Hi
      I was just wondering what temperature’s everyone has their mirrors running at?
      prior to today, I was using the raspberry pi official case which came with my kit and it was running at roughly 50°C -60°C, bought a new case with fans attached and it’s now running at roughly 35°C -40°C with the same set up of modules.
      Does anyone know what would be the optimal temperature to have the mirror running on?
        Mykle1 Project Sponsor Module Developer @Newtothis
        @Newtothis said in System Temperature:
        I don’t think there is an optimal running temperature, per se, but in this case I would say that cooler is always better. Like you, my Pi mirror runs below 40°C. Unlike you, I have no case for the Pi. However, I do have a small fan sitting above the Pi.
        There has been considerable discussion on the temperature question. Heat is the enemy but if I remember correctly the Pi is stable up to 80°C, give or take a few degrees.
        • lavolp3L Offline
          lavolp3 Module Developer
          @Mykle1 said in System Temperature:
          I agree and think below 60-70°C you don’t have to worry about a thing.
          From 80°C on there is a throttling function integrated.
          I had the early Raspberry Pi4 running idle at 90°C.
          That was scary.
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          • N Offline
            Newtothis @lavolp3
            @lavolp3 @Mykle1
            Thanks for the info!
            That gives me piece of mind. I was worried about overloading it but I’m quite far from doing anything like that now with the case.
            Out of interest, did it affect the performance at 90°C?
            lavolp3L ? 2 Replies Last reply Reply Quote 0
            • lavolp3L Offline
              lavolp3 Module Developer @Newtothis
              @Newtothis
              I didn’t check. I didn’t do anything with it, had only raspbian installed.
              I read only later that you can read out performance data.
              With a firmware upgrade it got much better, now running at around 60-70°C. The Pi4 is quite warm compared to the earlier models
              • ? Offline
                A Former User @Newtothis
                @Newtothis
                Over 90 RPI will be slow or halted or rebooted.
                And always be careful of a fire accident, your magic mirror might be assembled with many flammable materials - wood, paper, plastic, and dust.
                  dazza120
                  81 up is when it starts to throttle but can still clock full speed at 81 for a couple of seconds when I was bench testing my Pi4
