    Autorestart
    15 Posts 6 Posters 5.7k Views 6 Watching
    • C Offline
      cornusandu
      Good morning,
      I have setup in crontab to autorestart raspbian 2 times a week . Can I add a command in crontab to shut down magic mirror before restart? Pm2stop? Thank you for your help in advance
      • BKeyportB Offline
        BKeyport Module Developer
        Assuming you have PM2 set up per instructions:
        #       min     hour    day     Mon      wkd    command
                 15      2       *       *        *      sudo reboot
                 13      2       *       *        *      pm2 stop mm
        • C Offline
          cornusandu
          not working:
          46 11 * * mon,fri root pm2 stop mm
          30 6 * * mon,fri root reboot
          (With root works the reboot but not pm2 stop mm)
          46 11 * * mon,fri pm2 stop mm (also without root pm2 stop mm is not working)
            sdetweil @cornusandu
            @cornusandu create a little script
            pm2 stop ?? (id or name)
            shutdown -r now
            but you shouldn’t have to shutdown MM manually
            • FoziF Offline
              Fozi Project Sponsor
              For executing a reboot you need sudo privileges for the crontab. Try this
              Open crontab with root privileges (sudo):
              $ sudo crontab -e
              Add the cronjob:
              # - reboots the MM everyday at 1:05 and 13:05
              # - redirects stdout and stderror to dev/null
              5 1,13 * * * sudo reboot >dev/null 2>&1
              Save and exit crontab.
              Please note the ‚sudo‘ before ‚crontab -e’ and don‘t forget ‚sudo‘ before ‚reboot‘.
                sdetweil @Fozi
                @Fozi don’t use reboot…
                it is violent… use shutdown -r (restart)
                to close the file system properly
                FoziF 1 Reply Last reply Reply Quote 0
                • FoziF Offline
                  Fozi Project Sponsor @sdetweil
                  @sdetweil why violent? As far as I know reboot is an alias for shutdown -r and does exactly the same. At least that is info I found in multiple posts on stackexchange. Could you elaborate a bit on that? Just eager to understand the difference and to avoid a mistake in the future.
                    sdetweil @Fozi
                    @Fozi i wasn’t aware of that… seems to me reboot always was forced hard…
                    so… maybe you are right…
                    • FoziF Offline
                      @sdetweil no, it‘s not a hard shutoff. You can easily check the activity on the SD card when executing reboot before it powers off. Means it stops obviously process and writes necessary data to the card first, just like shutdown.
                      • C Offline
                        cornusandu
                        Thank you guys. It works now. I have a secondary issue. The calendar have on top a title , I called it “my calendar” , how can I increase the font size only if the title ? The events I already increased them but the title of the module is very small
                          Mykle1 Project Sponsor Module Developer @cornusandu
                          @cornusandu said in Autorestart:
                          Assuming the default calendar module, add this to your custom.css file and adjust accordingly…
                          .calendar .module-header {
                            color: yellow;
                            text-align: center;
                            font-size: 34px;
                          • C Offline
                            cornusandu @Mykle1
                            @Mykle1 thank you very much
                              thank you very much
                              I’m guessing that worked for you. Cool. Enjoy your experience.
                                Ben4x4 @Mykle1
                                @Mykle1 Similar issue but how can i increase the font size of the dates? Thanks
                                  Mykle1 Project Sponsor Module Developer @Ben4x4
                                  @Ben4x4
                                  The dates? As in Thanksgiving and Christmas?
                                  .calendar .title.bright {
                                    font-size: 24px;
                                  Keep in mind that the calendar module makes use of a table, including cells and line heights. If you make the text too large it will get ugly in a hurry. You might want to try zoom for the entire module. Just a thought.
