    Keyboard
    Scheduled Pinned Locked Moved Upcoming Features
    13 Posts 6 Posters 7.0k Views 5 Watching
    • P Offline
      pana507
      Did anyone find a way to insert a virtual keyboard?
      • brobergB Offline
        broberg Project Sponsor
        There is multiple virtual/on-screen keyboards for linux,
        Maybe :
        https://www.youtube.com/watch?v=bmLh92UNMX4
        • P Offline
          pana507
          Thanks for the help, but I need to know how I integrate it into a module so that I can select it as an option within my magic mirror
            sdetweil @pana507
            @pana507 you can also add the npm for virtual keyboard and add it to your module
            https://www.npmjs.com/package/virtual-keyboard
            there are others
            do google search
            node js virtual keyboard
            L 1 Reply Last reply Reply Quote 1
            • P Offline
              pana507
              @sdetweil said in Keyboard:
              there are others
              do google search
              Thank you, I will do the tests and tell you how it went
              Cheers
              • P Offline
                pana507
                Hi
                I tried to install the virtual keyboard, but when I started the keyboard the whole MagicMirror was interrupted.
                Could you give me lights on this or recommend a virtual keyboard already tested in MM
                S lavolp3L 3 Replies Last reply Reply Quote 0
                  sdetweil @pana507
                  @pana507 i have not seen any implementations with a vk
                    sdetweil @pana507
                    @pana507 when u started the keyboard??? how did u do that?
                    I installed, and so far nothing is different
                    • lavolp3L Offline
                      lavolp3 Module Developer @sdetweil
                      @sdetweil What a great coincidence that I’m currently working on a module for which I need a virtual keyboard as well.
                      What have you installed?
                      I have again stranded with the problem of not being able to properly include an npm module into the main .js file.
                      Is this only possible via the getScripts function?
                      I have installed the module “simple-keyboard” using npm and included it like this:
                          getStyles: function () {
                              return [
                                  this.file('node_modules/simple-keyboard/build/css/index.css')
                      Then called the keyboard class as instructed by the authors like this:
                          start: function () {
                              this.keyboard = new Keyboard({
                                  onChange: input => this.onChange(input),
                                  onKeyPress: button => this.onKeyPress(button)
                      Didn’t work. “Keyboard is not defined”
                      @pana507 what have you done to install a keyboard.
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                        sdetweil @lavolp3
                        @lavolp3 u need getScripts to load the Keyboard js
                        • lavolp3L Offline
                          lavolp3 Module Developer @pana507
                          @pana507 @sdetweil So, yay I got it working!
                          Guess I’ll need to write some kind of tutorial, not too easy but here a few first steps:
                          • Install “simple-keyboard” in your module via npm
                          • Bind it into the JS
                                  return [
                              getScripts: function () {
                                  return [
                                      this.file('node_modules/simple-keyboard/build/index.js')
                          • Create a div in your DOM building function. Something like that:
                                    const kb = document.createElement("div");
                                    kb.className = "simple-keyboard";
                                    container.appendChild(kb);
                          The class is important!
                          Then, AFTER the DOM element is created, you can create the keyboard class. I did this as soon as a text field was clicked on. With this method I can make sure that the DOM is created already:
                                    input.addEventListener("focus", event => {
                                        if (!this.keyboard) {
                                            var Keyboard = window.SimpleKeyboard.default;
                                        this.keyboard.keyboardDOM.classList.add("show-keyboard");
                          I guess this can be shortened but I keep the running system for now.
                          You can see there are a lot of other functions (this.onChange, this.onKeyPress…)
                          Basically they are designed to hide the keyboard if I klick anywhere else and show it if I click on the input field. I have the concept from here:
                          https://franciscohodge.com/projects/simple-keyboard/demos/show-hide-demo/
                          Simple-keyboard is well documented for npm including lots of sample code, so with a bit of knowledge you’ll find your way around eventually.
                          Still need to test it on the raspi itself and for all it’s function.
                          • L Offline
                            lally james @sdetweil
                            https://www.npmjs.com/package/virtual-[keyboard](https://spacebarcounter.info/click-counter/)
                            there are others
                            do google search
                            thanks for sharing man i was also planning to add the npm for the keyboard
                              sdetweil @lavolp3
                              @lavolp3 said in Keyboard:
                              I know it’s 2 years later, but that is what the MM notification DOM-OBJECTS-CREATED means… .
