    MMM-RandomBackground, Background from local folder
    28 Posts 15 Posters 28.8k Views 18 Watching
    • U
      Ultimatum22 Module Developer @Guest
      @Sean You are correct about ARM architecture, didn’t do my research properly. I did a quick search and it seems like a hazzle indeed. This seems to be a kind of solution, http://mitchtech.net/dropbox-on-raspberry-pi-via-sshfs/
      I agree about the space but if you have a decent sdcard, like 32gb you can store plenty of photo’s and change them once in a while. I have set up a shared directory with samba to the photo directory directly. I just put my photo’s in here and restart the pi.
      Would be nice if google photo’s introduces an api, I use it for photo backup at the moment.
      ? 1 Reply Last reply
        A Former User @Ultimatum22
        @Ultimatum22 said in Random background from local folder:
        Maybe this could be another solution. But it still needs ‘REMOTE HOST’ server. anyway, I have a NAS in my house, so I could use this.
        Yes. It could be so.
        We both agree this could be the ultimate final solution.
        Anyway, last weekends, I tried to test Dropbox API. I think I can make Dropbox Wallpaper module in a few days. But that could be for just a shallow nitch purpose. Usually, using local storage is the better way. However, for my family and @nobita, It could be alternates. I’ll leave mention about that in my module.
        • R
          radu022003
          Hello, I have just starting using this module. I find it very useful and seems to work very good… as long as the pictures are copied on the SD card.
          My ideea is to use the pictures that are already on my NAS. I did tried to mount the NAS on the expected folder /home/pi/MagicMirror/modules/MMM-RandomBackground/photos/. But the module seems not to be able to work with such a big amount of data, arround 30k files.
          I also observed that if i delete the pictures from “photos” folder the slideshow is keep running, which leads me to the Ideea that the module is loading the files in RAM or something similar, if it is so, that I can understand why is it not working with 30k files.
          Is there any option to use this module in my desired setup?
          thanks
            A Former User @radu022003
            @radu022003
            Well, maybe a little amount of pics loading on demands would be answer.
            My last MMM-GooglePhotos loads only one photo from Google Photos when it is needed.
            K 1 Reply Last reply
            • K
              kivlow @Guest
              Hello :]
              Im new to magic mirror - i want to make digital photo frame on my p3 and raspbian. So i use magicmirror but i not know how to make that MM see my photos i set imagepath to fotos but notching is displayed :[
              Ultimatum22 wrote somting about windows share but i dont know what to do :/
              Regards Kamil
              p.s. i try MMM-BackgroundSlideshow, MMM-ImageFileWatcher and MMM-ImageSlideshow all not show my pictures on local folder in magicmirror :/ what to do.
              Mykle1M 1 Reply Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @kivlow
                @kivlow
                Where MMM-ImageSlideshow is concerned, if your config entry looks like this . . .
                            disabled: f,
                            module: 'MMM-ImageSlideshow',
                            position: 'middle_center',
                                imagePaths: ['modules/MMM-ImageSlideshow/images'],
                                slideshowSpeed: 10000,
                                fixedImageWidth: 800,
                                randomizeImageOrder: true,
                … then your image files belong in this directory
                  sdetweil
                  For folders outside the MagicMirror directory tree, I use a link ( ln command) to my Nas server share
                  The image showing modules are using the built-in web server for file access, and it’s root is ~/MagicMirror. And cannot see outside that folder tree.
                  • elmatttE
                    elmattt
                    hello,
                    it doesn’t seem to work for me, install ok, but not pictures showed, only a loading text …
                    i put 2 jpg pictures in a “photos” folder in the MMM-RandomBackground folder…
                    does i need to name picture specifically ??
                    EDIT : npm install… it’s ok :D
