    MMM-Buienalarm
    10 Posts 4 Posters 3.5k Views 4 Watching
    • lavolp3L Offline
      lavolp3 Module Developer
      Description:
      For all you dutch and german people out there, I have created a module that is inspired by the app Buienalarm. It is based on the modules MMM-rainfc and MMM-rain-forecast. Thanks to @cirdan and @spoturdeal for their groundwork.
      I have created this since I wanted the rain forecast to be more prominent on the mirror.
      This module implements chart.js for a nicer graph and
      Screenshots:
      Download:
      [card:lavolp3/MMM-Buienalarm]
      Features:
      • uses Buienradar API, works in Netherlands and parts of Western Germany
      • line or bar graph possible
      • rain icons for light, medium, heavy rain as orientation help
      • flexible sizes, color
      Any ideas or corrections welcome and appreciated!
      Version 1.0
      Initial release
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        MajorC Project Sponsor
        I tried the module today with the default confit and it only shows “no data” / “Keine Daten!”.
        I use: lat: 52.15 and lon: 5.55.
        Any ideas?
        Update: Sorry, I took a while, but now I see some data.
        Christian
          Update 2:
          I changed lat and lon from default to my coordinates
          lat: 52.55,
          lon: 13.45,
          and get no data anymore.
          • lavolp3L Offline
            lavolp3 Module Developer @MajorC
            @MajorC said in MMM-Buienalarm:
            lat: 52.55,
            lon: 13.45,
            Is that Berlin?
            The current master branch uses Buienradar (NL) and does not work east of, let’s say Dortmund.
            You could try to switch to the ‘climacell’ branch
            git fetch --all
            git checkout climacell
            git pull
            You’d need a climacell api key.
            https://www.climacell.co/weather-api/
            I have not completed the Readme yet in that branch. Will do over the next days.
              Yes, that is Berlin.
              I am happy to give cimacell a test if the readme file is online and I know what to do.
              Thank you
              • lavolp3L Offline
                @MajorC Then you can just wait.
                I guess I’ll push the climacell change to the master branch later since there are already some modules out there that use Buienradar.
                • T Offline
                  Tinus
                  Hi all,
                  Unfortunately, the module no longer seems to work. If I enable it in my config, the dashboard is not loaded anymore. Same yields for the MMM-rainfc module. I really liked their simplicity.
                  But after updating npm, Node and Magicmirror I can not use these modules anymore.
                  Any ideas on why this happens?
                  MagicMirror 2.18.0
                  Node v16.13.2
                  npm v8.4.0
                    sdetweil @Tinus
                    @tinus see this
                    • T Offline
                      Tinus @sdetweil
                      @sdetweil Thanks Sam, output confirms that it is missing ‘request’.
                      Tried to install it through npm, but as with many other npm installations I get stuck at:
                      5b886eab-132c-45d7-9253-b7158b5b82b5-image.png .
                      If I interrupt this installation by ctrl+c I get some output that things went wrong at Node.js playwright… Unfortunately, I can not reproduce that because after several tries it somehow succeeded.
                      Any idea where this ‘playwright’ error comes from? Can not find anything about it on the forums.
                        sdetweil @Tinus
                        @tinus playwrite is for mm testing.
                        but you used the wrong command
                        in the module folder do
                        npm install request --save
                        all the other stuff is things u can’t do anything about ( and we can’t suppress the messages)
                        to redo the mm npm insta with developer tools do
                        npm install --only=prod
                        in the MagicMirror folder
