MMM-TPG
The ‘MMM-TPG’ is a module for users of the TPG (Transport publics de Genève) on Magic Mirror 2.
It’s using data from tpg.ch (link to opendata section)[card:aluini/MMM-tpg]
I just got my token and tried out the module, unfortunately it does not return any data but does not crash the app either. There seems to be a dicrippency between the module config file as example and the app itself. does the module need to be referd as MMM-tpg or tpg. Trien both without success. I did have to remove the updateInterval and maxDepartures for the modules to be read.
Any Ideas ? -
@Maxzovirax
It needs to be ‘MMM-tpg’Please post your config file for this, but replace your key with some rubbish :)
Thank you for coming back to me so quickly. Here is the config bit for MMM-tpg:
I should mention that I tried most of the combinations possible with commas etc. I have lots of modules running, but as soon as I uncomment this one the screen loads but I have no module. A strange side-effect is that
MMM-remote-control returns No Module loaded… module should be loaded before MMM-sonos-
Hope this helps{ module: 'MMM-tpg', position: 'top_right', header: 'TPG - Cornavin', config: { params: { stopCode: 'CVIN', // Which stop would you like to have displayed? key: 'xxxMyTokenxxx' // Add your tpg opendata key } } },Connecting socket for: MMM-horoscope
Starting NodeHelper for MMM-horoscopemodule.MMM-tpg sould start here in the config.js file
Connecting socket for: MMM-Sonos
Sonos helper started …
Starting module: newsfeed
Connecting socket for: MMM-Remote-Control
Starting node helper for: MMM-Remote-Control -
I should add that when I uncomment the module I get the following two lines on the console after the
Launching application line.
ERROR! Could not find main module js file.
ERROR! Could not find main module js file. -
@Maxzovirax Sounds like your module is not installed in
~/MagicMirror/modules/MMM-tpg. Did you probably installed it in~/MagicMirror/modules/default/MMM-tpg? -
@strawberry-3.141
Funny you should be the one replying to me, I have the same issue (as for MMM-tpg) with MMM-soccer that I looked at for a friend, I see you are involved in that too, I was planning on looking into that after this one. …
I will look at you suggestion this evening if possible. cheers -
Hello again, just checked and the module is in the modules directory under MMM-tpg, so it is in the correct place…
Hello,
How do you get your key & your stop code ? because i can’t find it on tpg website : https://www.tpg.ch/fr/open-data
any ideas ?
