    MMM-TPG
    genevatpgswitzerlandpublic transport
    9 Posts 5 Posters 5.7k Views 5 Watching
      Maxzovirax
      I should add that when I uncomment the module I get the following two lines on the console after the
      Launching application line.
      ERROR! Could not find main module js file.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @Maxzovirax
        @Maxzovirax Sounds like your module is not installed in ~/MagicMirror/modules/MMM-tpg. Did you probably installed it in ~/MagicMirror/modules/default/MMM-tpg?
          Maxzovirax @strawberry 3.141
          @strawberry-3.141
          Funny you should be the one replying to me, I have the same issue (as for MMM-tpg) with MMM-soccer that I looked at for a friend, I see you are involved in that too, I was planning on looking into that after this one. …
          I will look at you suggestion this evening if possible. cheers
            Maxzovirax
            Hello again, just checked and the module is in the modules directory under MMM-tpg, so it is in the correct place…
            • W Offline
              wirdman
              How do you get your key & your stop code ? because i can’t find it on tpg website : https://www.tpg.ch/fr/open-data
              any ideas ?
