    MMM-TPG
    genevatpgswitzerlandpublic transport
    9 Posts 5 Posters 5.7k Views 5 Watching
    • aluiniA Offline
      aluini
      The ‘MMM-TPG’ is a module for users of the TPG (Transport publics de Genève) on Magic Mirror 2.
      It’s using data from tpg.ch (link to opendata section)
      [card:aluini/MMM-tpg]
      Preview of MMM-TPG
        Maxzovirax
        I just got my token and tried out the module, unfortunately it does not return any data but does not crash the app either. There seems to be a dicrippency between the module config file as example and the app itself. does the module need to be referd as MMM-tpg or tpg. Trien both without success. I did have to remove the updateInterval and maxDepartures for the modules to be read.
        Any Ideas ?
        • yawnsY Offline
          yawns Moderator @Maxzovirax
          @Maxzovirax
          It needs to be ‘MMM-tpg’
          Please post your config file for this, but replace your key with some rubbish :)
            Maxzovirax
            Thank you for coming back to me so quickly. Here is the config bit for MMM-tpg:
            I should mention that I tried most of the combinations possible with commas etc. I have lots of modules running, but as soon as I uncomment this one the screen loads but I have no module. A strange side-effect is that
            MMM-remote-control returns No Module loaded… module should be loaded before MMM-sonos-
            Hope this helps
            		module: 'MMM-tpg',
            		position: 'top_right',
            		header: 'TPG - Cornavin',
            			params: {
            			stopCode: 'CVIN',  // Which stop would you like to have displayed?
            			key: 'xxxMyTokenxxx'  // Add your tpg opendata key
            Connecting socket for: MMM-horoscope
            Starting NodeHelper for MMM-horoscopemodule.
            MMM-tpg sould start here in the config.js file
            Connecting socket for: MMM-Sonos
            Sonos helper started …
            Starting module: newsfeed
            Connecting socket for: MMM-Remote-Control
            Starting node helper for: MMM-Remote-Control
              Maxzovirax
              I should add that when I uncomment the module I get the following two lines on the console after the
              Launching application line.
              ERROR! Could not find main module js file.
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @Maxzovirax
                @Maxzovirax Sounds like your module is not installed in ~/MagicMirror/modules/MMM-tpg. Did you probably installed it in ~/MagicMirror/modules/default/MMM-tpg?
                  Maxzovirax @strawberry 3.141
                  @strawberry-3.141
                  Funny you should be the one replying to me, I have the same issue (as for MMM-tpg) with MMM-soccer that I looked at for a friend, I see you are involved in that too, I was planning on looking into that after this one. …
                  I will look at you suggestion this evening if possible. cheers
                    Maxzovirax
                    Hello again, just checked and the module is in the modules directory under MMM-tpg, so it is in the correct place…
                    • W Offline
                      wirdman
                      How do you get your key & your stop code ? because i can’t find it on tpg website : https://www.tpg.ch/fr/open-data
                      any ideas ?
