    MMM-TPG
    genevatpgswitzerlandpublic transport
    9 Posts 5 Posters 5.6k Views 5 Watching
      Maxzovirax
      Thank you for coming back to me so quickly. Here is the config bit for MMM-tpg:
      I should mention that I tried most of the combinations possible with commas etc. I have lots of modules running, but as soon as I uncomment this one the screen loads but I have no module. A strange side-effect is that
      MMM-remote-control returns No Module loaded… module should be loaded before MMM-sonos-
      Hope this helps
      		module: 'MMM-tpg',
      		position: 'top_right',
      		header: 'TPG - Cornavin',
      			params: {
      			stopCode: 'CVIN',  // Which stop would you like to have displayed?
      			key: 'xxxMyTokenxxx'  // Add your tpg opendata key
      Connecting socket for: MMM-horoscope
      Starting NodeHelper for MMM-horoscopemodule.
      MMM-tpg sould start here in the config.js file
      Connecting socket for: MMM-Sonos
      Sonos helper started …
      Starting module: newsfeed
      Connecting socket for: MMM-Remote-Control
      Starting node helper for: MMM-Remote-Control
        Maxzovirax
        I should add that when I uncomment the module I get the following two lines on the console after the
        Launching application line.
        ERROR! Could not find main module js file.
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Maxzovirax
          @Maxzovirax Sounds like your module is not installed in ~/MagicMirror/modules/MMM-tpg. Did you probably installed it in ~/MagicMirror/modules/default/MMM-tpg?
            Maxzovirax @strawberry 3.141
            @strawberry-3.141
            Funny you should be the one replying to me, I have the same issue (as for MMM-tpg) with MMM-soccer that I looked at for a friend, I see you are involved in that too, I was planning on looking into that after this one. …
            I will look at you suggestion this evening if possible. cheers
              Maxzovirax
              Hello again, just checked and the module is in the modules directory under MMM-tpg, so it is in the correct place…
              • W Offline
                wirdman
                How do you get your key & your stop code ? because i can’t find it on tpg website : https://www.tpg.ch/fr/open-data
                any ideas ?
