    MMM-Netatmo updated
    56 Posts 15 Posters 34.6k Views 16 Watching
      Miller @zdenek
      @zdenek I updated the module, now it’s possible to have your Netatmo-Modules (Rooms) in one row.
      For this set “horizontal” to true on your config.js
      This will only display rooms on one row as long as there is allowed space from MM-Module.
      The rooms that don’t fit, will continue on the next row.
      However, you can “Force” everything to stay on one row.
      Then set “horizontalOverflow” to true.
      This forces everything to stay on one row, but of course with the chance it will overflow your other Modules on the mirror.
      Updated Images are in included in my Github-repository (look at the bottom of the Reame.md)
      zdenekZ 1 Reply Last reply Reply Quote 0
      • T Offline
        torte22
        This is pretty cool, many thanks!!
        • zdenekZ Offline
          zdenek @Miller
          @Miller great, thanks, I’m going to test.
          Zdeněk
          • zdenekZ Offline
            zdenek @zdenek
            @Miller so, it works almost perfect, Just:
            • I would recomment to add comma (,) next to last bracket on git-hub. Like this:
              when someone copy settings somewhere in the middle of config, he/she has to remember to add comma…
            • for me doesn’t in hotizontal mode works “horizontalOverflow” or I didn’t get the meaning. I’ve set it false and the row of MMM-Netatmo writes values over modules in “right” column". And cause the size is too big for me, I had to remove one of sensors (1 external + 3 internals)
            anyway, thanks a lot - great job
              Miller @zdenek
              @zdenek Thank you for your comments.
              I’ll see if i can improve it later
              • zdenekZ Offline
                zdenek @Miller
                @Miller no problem, I’ll reorganize modules a little bit…
                thanks
                  airart
                  there is also a netatmo mudule for thermostat ?
                    Miller
                    Here you can find many available modules.
                    For the thermostat there is this Module
                    For me that one is not suitable, because it is only for the thermostat, not for the valves.
                    Since I didn’t find a module for the valves, I will maybe try to make it myself, but will take some time
                    • zdenekZ Offline
                      zdenek @Miller
                      @Miller it will be great. I’ve the one form thermostat, but it only show temp and off/on. Will be great to see “plan”, also the status of valves (actual temp, open/closed, temp by plan…)
                      thanks
                      • zdenekZ Offline
                        zdenek
                        @Miller can u plz help me to customize CSS? I need to “somehow” add to my CSS
                        MMM-netatmo . modules bubbles horizontal . module .secondary .displayAQI .AQI .medium light
                        font-size:15px;
                        MMM-netattmo . modules bubbles horizontal . module .primary . displayTemp . Temperature . data_container . data_left large light bright
                        font-size: 40px;
                        and also overide the module css value
                        .x-medium {
                          font-size:170%;
                        to
                        .x-medium {
                          font-size:100%;
                        the task is decrease the size of font of mentioned DIVs to own defined size (the actual is too big for me)
                        I’ve tried
                        .x-medium {
                          font-size:100%;
                        .MMM-netatmo .bubbles.horizontal .module .primary .displayTemp .data_container .data_left {
                          font-size: 40px;
                        .MMM-netatmo .bubbles.horizontal .module .secondary .displayAQI .AQI {
                          font-size: 15px;
                        thanks a lot - I’m lost :-(
                        • 6
                        • 2 / 6
