    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 226.4k Views 39 Watching
      RIKKO14
      Hello,
      does this module work for french stocks on euronext ?
      • W Offline
        wilbur245
        Hello, what do I have to do so that the values ​​are shown up to date to some extent. It is currently only queried once a day or the value renewed.
        I sometimes have values ​​for 2 days even though they have fallen or increased
          DJ6sTep @Jalibu
          @Jalibu Is there a way to have the ticker scroll all the way across the screen? Mine gets about 85% across the screen, doesn’t show all the stocks, just 4 stocks & then restarts from the beginning again.
            DJ6sTep @DJ6sTep
            @Jalibu also, how can I increase the font size?
            • JalibuJ Offline
              Jalibu Module Developer @MisterTFM
              @MisterTFM said in [MMM-JaST] Just another Stock Ticker:
              What “symbol” should I use for the Dow Jones Industrial Average? I tried DJI and .DJI
              Hi @MisterTFM,
              as you can read here, the Alphavantage API does not provide stock indices. You could try using “DIA”.
              @RIKKO14 said in [MMM-JaST] Just another Stock Ticker:
              Hello,
              HI @RIKKO14,
              the question should better be “does the Alphavantage API work with french stocks on euronext”. To be honest: I just don’t know :-)
              I just googled that list of Symbols for Alphavantage: https://github.com/prediqtiv/alpha-vantage-cookbook/blob/master/symbol-lists.md
              You can easily test your Symbols by pasting this url in your browser and change the symbol value on its end:
              https://www.alphavantage.co/query?function=TIME_SERIES_INTRADAY&interval=5min&apikey=3JJ4NFIVSE57V6NB&symbol=YOUR_SYMBOL_HERE
              If you get a response like this, your symbol is valid and offered by the API:
              Meta Data: {
                Information: "Daily Prices (open, high, low, close) and Volumes",
                Symbol: "BAS.DE",
                Last Refreshed: "2021-01-05",
                Output Size: "Compact",
                Time Zone: "US/Eastern"
              Time Series (Daily): {
               2021-01-05: {
                open: "64.3000",
                high: "65.4700",
                low: "63.2600",
                close: "64.4000",
                volume: "2770107"
              @wilbur245 said in [MMM-JaST] Just another Stock Ticker:
              Hi @wilbur245 ,
              the module always requests the latest values from the Alphavantage API. If they are not up to date, I’m afraid there is nothing we can do ¯\(ツ)/¯
              The update interval between the MMM-Jast module and the Alphavantage API can be configured
              config{
                updateIntervalInSeconds: 1800
              @DJ6sTep said in [MMM-JaST] Just another Stock Ticker:
              Hi @DJ6sTep , perhaps that’s a bug. I’ll have a look on that.
              By modifying the modules/MMM-Jast/MMM-Jast.css
              • JalibuJ Offline
                Jalibu Module Developer @wilbur245
                Hello I have installed Jast, everything is fine.
                I just don’t see a share.
                Biontech
                FRA: 22UA
                there is zero also 22UA.DE does not work.
                how can i “https://www.stockdio.com/”
                insert as API?
                I just checked the stockdio API. It is great, but unfortunately its free plan is limited to 500 requests per month.
                  DJ6sTep @Jalibu
                  @Jalibu Thank you, editing the .css file did the trick. Please let me know when you’ve had a chance to investigate this bug. This module is exactly what I was looking for man, just need to to scroll all the way across & display all my stocks :) Appreciate your work.
                  • JalibuJ Offline
                    I have refactored this module from scratch. It now should also support DepotGrowth calculation in currencies other than EUR. A few internal and UI bugs were also fixed.
                    Please let me know if you are facing any issues with the latest version.
                    • K Offline
                      Koert 0 @Jalibu
                      @jalibu I’m facing some problems with displaying the correct value of my stocks.
                      module: "MMM-Jast",
                      position: "fullscreen_above",
                      maxWidth: "100%",
                      updateIntervalInSeconds: 0,
                      fadeSpeedInSeconds: 90.5,
                      scroll: "horizontal",
                      defaultCurrency: "EUR",
                      showDepotGrowth: false,
                      apiKey: "MY API KEY",
                      stocks: [
                      	{ name: "Porsche", symbol: "PAH3.DE" },
                      	{ name: "STS", symbol: "SF3.DE"},
                      	{ name: "Haier", symbol: "690D.DE" },
                      	{ name: "Siemens Energy", symbol: "ENR.DE" },
                      	{ name: "TUI", symbol: "TUI1.DE" },
                      	{ name: "HochTief", symbol: "HOT.DE" },
                      	{ name: "Siemens", symbol: "SIE.DE" },
                      	{ name: "Allianz", symbol: "ALV.DE" },
                      Problem 1: The ticker is showing me Values. But also a value for BTC (which isn’t mentioned in the code?!?!)
                      Problem 2: Values from the stock list are old Values from the beginning of the Day (or maybe last value of the day before)
                      maybe a Log can help you:
                      /home/pi/.pm2/logs/mm-out.log last 100 lines:
                      0|mm       | [25.03.2021 16:08.16.922] [LOG]   Sending Stock result: { symbol: 'PAH3.DE', current: 84.68, last: 87.42 }
                      0|mm       | [25.03.2021 16:08.16.936] [LOG]   Sending Stock result: { symbol: '690D.DE', current: 1.832, last: 1.9368 }
                      0|mm       | [25.03.2021 16:08.16.971] [LOG]   Sending Stock result: { symbol: 'TUI1.DE', current: 4.396, last: 4.133 }
                      0|mm       | [25.03.2021 16:09.18.891] [LOG]   Sending Stock result: { symbol: 'HOT.DE', current: 73.35, last: 73 }
                      0|mm       | [25.03.2021 16:09.18.913] [LOG]   Sending Stock result: { symbol: 'SIE.DE', current: 135.56, last: 135.98 }
                      0|mm       | [25.03.2021 16:09.18.974] [LOG]   Sending Stock result: { symbol: 'ALV.DE', current: 212.55, last: 211.45 }
                      0|mm       | [25.03.2021 16:09.19.845] [LOG]   Sending Crypto result: { symbol: 'BTC', current: 52417.17, last: 52303.65 }
                      0|mm       |
                      0|mm       | > magicmirror@2.14.0 start /home/pi/MagicMirror
                      0|mm       | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                      0|mm       |
                      0|mm       | [25.03.2021 16:26.45.698] [LOG]   Starting MagicMirror: v2.14.0
                      0|mm       | [25.03.2021 16:26.45.712] [LOG]   Loading config ...
                      0|mm       | [25.03.2021 16:26.45.733] [LOG]   Loading module helpers ...
                      0|mm       | [25.03.2021 16:26.46.100] [LOG]   Initializing new module helper ...
                      0|mm       | [25.03.2021 16:26.46.105] [LOG]   Module helper loaded: updatenotification
                      0|mm       | [25.03.2021 16:26.46.111] [LOG]   No helper found for module: helloworld.
                      0|mm       | [25.03.2021 16:26.46.112] [LOG]   All module helpers loaded.
                      0|mm       | [25.03.2021 16:26.46.305] [LOG]   Starting server on port 8080 ...
                      0|mm       | [25.03.2021 16:26.46.329] [LOG]   Server started ...
                      0|mm       | [25.03.2021 16:26.46.331] [LOG]   Connecting socket for: updatenotification
                      0|mm       | [25.03.2021 16:26.46.332] [LOG]   Sockets connected & modules started ...
                      0|mm       | [25.03.2021 16:26.46.743] [LOG]   Launching application.
                      0|mm       |
                      0|mm       |
                      0|mm       | [25.03.2021 16:27.41.491] [LOG]   Starting MagicMirror: v2.14.0
                      0|mm       | [25.03.2021 16:27.41.506] [LOG]   Loading config ...
                      0|mm       | [25.03.2021 16:27.41.519] [LOG]   Loading module helpers ...
                      0|mm       | [25.03.2021 16:27.41.524] [LOG]   No helper found for module: clock.
                      0|mm       | [25.03.2021 16:27.42.080] [LOG]   Initializing new module helper ...
                      0|mm       | [25.03.2021 16:27.42.082] [LOG]   Module helper loaded: MMM-Jast
                      0|mm       | [25.03.2021 16:27.42.084] [LOG]   All module helpers loaded.
                      0|mm       | [25.03.2021 16:27.42.238] [LOG]   Starting server on port 8080 ...
                      0|mm       | [25.03.2021 16:27.42.269] [LOG]   Server started ...
                      0|mm       | [25.03.2021 16:27.42.271] [LOG]   Connecting socket for: MMM-Jast
                      0|mm       | [25.03.2021 16:27.42.273] [LOG]   MMM-Jast helper method started...
                      0|mm       | [25.03.2021 16:27.42.274] [LOG]   Sockets connected & modules started ...
                      0|mm       | [25.03.2021 16:27.42.755] [LOG]   Launching application.
                      0|mm       | [25.03.2021 16:27.47.791] [LOG]   Sending Stock result: { symbol: 'ALV.DE', current: 212.55, last: 211.45 }
                      0|mm       | [25.03.2021 16:27.47.868] [LOG]   Sending Stock result: { symbol: 'SF3.DE', current: 7.88, last: 7.68 }
                      0|mm       | [25.03.2021 16:27.47.890] [LOG]   Sending Stock result: { symbol: 'ENR.DE', current: 29.38, last: 30.03 }
                      0|mm       | [25.03.2021 16:27.47.916] [LOG]   Sending Stock result: { symbol: '690D.DE', current: 1.832, last: 1.9368 }
                      0|mm       | [25.03.2021 16:27.47.960] [LOG]   Sending Stock result: { symbol: 'PAH3.DE', current: 84.68, last: 87.42 }
                      For Example Porsche received the same value twice
                      Greetings from BW to RP ;)
                      JalibuJ 1 Reply Last reply Reply Quote 0
                      • JalibuJ Offline
                        Jalibu Module Developer @Koert 0
                        Hi @koert-0 ,
                        thank you for your message.
                        Problem 1:
                        There was a hidden sample crypto entry in the default settings. I removed that and improved the Readme, to avoid this confusion in the future.
                        Problem 2:
                        The problem for this is more likely to be found with the data provider than with the module.
                        The module displays what it gets. If the values are not up to date, then unfortunately I can’t influence that.
                        In general, I am rather dissatisfied with Alphavantage. Unfortunately, I don’t know a free alternative. I am open for suggestions.
                        • JalibuJ Offline
                          I refactored this module again to use Yahoo’s financial API instead of Alphavantage and need some voluntary testers.
                          It should now support many more Symbols and be more accurate and much simpler.
                          Please check out this Feature Branch:
                          https://github.com/jalibu/MMM-Jast/tree/feat/useYahoo
                            BravoOscar @Jalibu
                            @jalibu
                            I will test it later today, but I need to know of this is this a upgrade or is it a new install.
                            I use the originale MMM-JaST, should this be removed before a new install?
                            • JalibuJ Offline
                              Jalibu Module Developer @BravoOscar
                              @bravooscar
                              Well, the word “install” is fuzzy…
                              You don’t need to uninstall your old one and even your configuration is compatible.
                              You can switch between them by just changing the branch.
                              In your modules/MMM-Jast folder execute
                              Switch to Yahoo test branch:
                              git fetch
                              git checkout feat/useYahoo
                              npm i
                              Switch back to stable master:
                              git checkout master
                                BravoOscar @Jalibu
                                @jalibu
                                pi@raspberrypi:~/MagicMirror/modules/MMM-Jast $ git fetch
                                From https://github.com/jalibu/MMM-Jast
                                   1cd91dc..c18758f  master        -> origin/master
                                 * [new branch]      feat/useYahoo -> origin/feat/useYahoo
                                 * [new tag]         v1.1.0        -> v1.1.0
                                 * [new tag]         v1.2.0        -> v1.2.0
                                pi@raspberrypi:~/MagicMirror/modules/MMM-Jast $ git checkout feat/useYahoo
                                error: Your local changes to the following files would be overwritten by checkout:
                                	MMM-Jast.css
                                	MMM-Jast.js
                                Please commit your changes or stash them before you switch branches.
                                Aborting
                                pi@raspberrypi:~/MagicMirror/modules/MMM-Jast $ npm i
                                > magicmirror@2.14.0 install /home/pi/MagicMirror
                                > echo "Installing vendor files ...
                                " && cd vendor && npm install --loglevel=error
                                audited 24 packages in 1.694s
                                It looks like there is a error when using “git checkout feat/useYahoo”.
                                Now the alert message on MM says there is a update for MMM-Jast
                                  BravoOscar @BravoOscar
                                  @bravooscar @jalibu
                                  Branch 'feat/useYahoo' set up to track remote branch 'feat/useYahoo' from 'origin'.
                                  Switched to a new branch 'feat/useYahoo'
                                  npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                                  added 262 packages from 267 contributors and audited 263 packages in 33.609s
                                  35 packages are looking for funding
                                    run `npm fund` for details
                                  found 0 vulnerabilities
                                  I removed MMM-Jast folder, and did a clean install of MMM-Jast.
                                  Then I did this
                                  git fetch
                                  npm i
                                  Everythink works now, and also one of my stocks that was not available before.
                                  Good work!
                                  Think is should be made as master, maby make a config option, so its possible to cange from Yahoo to the other one.
                                  • earnestrichardsE Offline
                                    earnestrichards
                                    I guess I’ve done something wrong…
                                    I copied the link, installed to my modules folder, ran the “npm i” command, and updated my config .js file
                                    			module: "MMM-Jast",
                                    				maxWidth: "100%",
                                    				updateIntervalInSeconds: 300,
                                    				fadeSpeedInSeconds: 3.5, // Higher value: vertical -> faster // horizontal -> slower
                                    				scroll:"none", // "<none, vertical, horizontal>",
                                    				showChangePercent: true,
                                    				showChangeValue: false,
                                    				showChangeValueCurrency: false,
                                    				stocks: [
                                    					{ name: "FFFEX", symbol: "FFFEX",quantity: 1},
                                    					{ name: "FFFDX", symbol: "FFFDX", quantity: 1},
                                    					{ name: "PLFJX", symbol: "PLFJX", quantity: 1}
                                    					// { name: "DJIA", symbol: "DJIA"}
                                    • JalibuJ Offline
                                      Jalibu Module Developer @earnestrichards
                                      @earnestrichards I sent you a PM.
                                      I think you are not on the feat/useYahoo branch.
                                      No matter. I have now made the feature branch the master.
                                      • K Offline
                                        Koert 0
                                        Hi @jalibu ,
                                        It works (for the most of my Stocks). The ticker is showing me the correct value but not an increase/decrease in percent (for 2 of 10 stocks).
                                        can you help me with this error message?
                                        thank you in advance!
                                        0|mm       | [31.03.2021 11:25.10.250] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:58
                                        0|mm       | 			stocks: [
                                        0|mm       | 			^^^^^^
                                        0|mm       |
                                        0|mm       | SyntaxError: Unexpected identifier
                                        0|mm       |     at Module._compile (internal/modules/cjs/loader.js:896:18)
                                        0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:986:10)
                                        0|mm       |     at Module.load (internal/modules/cjs/loader.js:816:32)
                                        0|mm       |     at Module._load (internal/modules/cjs/loader.js:728:14)
                                        0|mm       |     at Function.Module._load (electron/js2c/asar.js:748:26)
                                        0|mm       |     at Module.require (internal/modules/cjs/loader.js:853:19)
                                        0|mm       |     at require (internal/modules/cjs/helpers.js:74:18)
                                        0|mm       |     at loadConfig (/home/pi/MagicMirror/js/app.js:70:12)
                                        0|mm       |     at App.start (/home/pi/MagicMirror/js/app.js:217:3)
                                        0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:129:7)
                                        0|mm       | [31.03.2021 11:25.11.849] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
                                        0|mm       | [31.03.2021 11:28.30.123] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
                                        0|mm       | [31.03.2021 11:34.45.284] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
                                        0|mm       | [31.03.2021 11:41.15.680] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
                                          earnestrichards
                                          :man_facepalming: As I have read so many times here on the forum… Read. The. Instructions. Thanks!!!
                                            jack819
                                            I am very new to all of this but have been able to install every module so far. I had the old one working fine until the other day when it would not update the stocks. Then I discovered it was updated so I removed the old one and installed the new one as directed. I copied the config file directly to the config.js but I keep getting an error. When I run the config check it keeps coming back as below:
                                            pi@raspberrypi:~/MagicMirror $ npm run config:check
                                            > magicmirror@2.14.0 config:check /home/pi/MagicMirror
                                            > node js/check_config.js
                                            [01.04.2021 06:41.32.155] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
                                            [01.04.2021 06:41.32.210] [ERROR] Your configuration file contains syntax errors :(
                                            [01.04.2021 06:41.32.212] [ERROR] Line 109 col 3 Parsing error: Unexpected token stocks```
                                            Any ideas? Like I said, the config file is copied right from the sample. Line 109 is the stocks : [ line from the sample.
                                            S JalibuJ 2 Replies Last reply Reply Quote 0
                                            • 8
                                            • 9
                                            • 2 / 9
