    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 237.7k Views 39 Watching
    • JalibuJ Offline
      Jalibu Module Developer @gpaquin
      @gpaquin please send me a PN to provide more information
        morphisto
        Hi, is it possible to increase the font size? Often I have wear no glasses if I`m in my bath room after showering - and I need a bigger font size without glasses…
        uros76U 1 Reply Last reply Reply Quote 0
        • uros76U Offline
          uros76 @morphisto
          @morphisto said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
          You can do that with CSS.
          https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works
          My magicmirror projects: https://forum.magicmirror.builders/post/79889, https://forum.magicmirror.builders/post/93241 and https://forum.magicmirror.builders/post/94586
            morphisto @uros76
            @uros76 I know how css works - but i cannot find the right class in the Jast Module to change the font size. Therefore I asked the developer if there is a chance to to it?
            S JalibuJ 2 Replies Last reply Reply Quote 0
              sdetweil @morphisto
              @morphisto see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1622084388280
              you can discover what you need to know
              • JalibuJ Offline
                Jalibu Module Developer @morphisto
                @morphisto
                you should be fine by just adding
                .jast-wrapper {
                --size: 2.0rem;
                to your custom css
                  morphisto @Jalibu
                  @jalibu said in [MMM-JaST] Just another Stock Ticker (new: version 2.0.0):
                  –size: 2.0rem;
                  Thank You!
                  • JalibuJ Offline
                    Dear user of this module,
                    so far, the wording around the portfolio function was incorrect/misleading, as I incorrectly used the German term “Depot” for that.
                    In the latest version the translation should be clearer.
                    Attention: Due to the renaming, configuration properties have also changed. Temporarily old AND new properties are supported, but in future versions I will only support the new ones. So, please update your config.
                      doscas @Jalibu
                      @Jalibu
                      Hi, Just installed this. What a great addition to my MagicMirror. Congrats!
                      I’m running on top of a background with pictures and I would like to have the letters fading when disappearing on the horizontal mode (guess it could be the same for the vertical mode).
                      Instead of “seeing” an invisible line where all the letters just disappear, I believe a little fade option would be a design touch that would elevate this module a lot.
                      I’m not sure I can achieve it with CSS only without damaging the view of the background picture.
                      Thank you.
                      • I Offline
                        ItsDonJ
                        I love the idea of that Ticker but sadly if i try to use it, i also only get an “Undefined” error message on my mirror. Any idea why so? For the moment i tried it with the BASF and SAP-Stocks like in the example.
                        JalibuJ 1 Reply Last reply Reply Quote 0
                        • JalibuJ Offline
                          Jalibu Module Developer @ItsDonJ
                          @itsdonj
                          Please check your symbols. The “undefined” error comes when there are invalid symbols in your list
                          • uros76U Offline
                            uros76
                            @Jalibu thanks for your continuos work on this module. It’s awesome and I use it on few MM deployments. Virtual beer sent your way :)
                            Perhaps you know, is there a way to pull a list of stocks into a config.js file, from a different file? I am no expert in JS but maybe there is a way to pull some of the config elements from a different file?
                            • JalibuJ Offline
                              Jalibu Module Developer @uros76
                              Hi @uros76,
                              thank you for the beer :-)
                              What do you mean with “different file”? Should that be a central/remote file which should be loaded over the internet from different mirrors or just another local file on the same system?
                              Prost!
                              uros76U S 2 Replies Last reply Reply Quote 0
                              • uros76U Offline
                                uros76 @Jalibu
                                @jalibu welcome :)
                                Preferably the other file with defined stocks would be on the same system.
                                I kind of get it how to make this work with python scripts but I have no clue if it’s possible with JS.
                                • JalibuJ Offline
                                  @uros76 either you prepare/autogenerate the config.js in a preflight with the stocks of your file before you start the mirror or I am afraid that it won’t work without programming efforts in the module.
                                  Can you explain me the use case?
                                  • uros76U Offline
                                    uros76 @Jalibu
                                    @jalibu I am making a small MM project, based on rpi 3 and a small screen. This will be used by my friends who are occasionally trading with crypto and stocks.
                                    Rather than teaching them how to edit a list of monitored stocks in the config.js (which could lead to catastrophic failure) I would prefer them to edit an independent shared file with the list of stocks only. This way we avoid breaking the core MM system and have the flexibility to change the list of stocks daily if needed.
                                    I like the idea of autogenerating the config file. Will have a look into it if I can do it with python script. If you come up with some other solution let me know.
                                    Thanks again
                                    • JalibuJ Offline
                                      @uros76 why don’t you use @sdetweil 's Config Edit Tool MMM-Config?
                                      MMM-Jast has full support for it.
                                      uros76U 1 Reply Last reply Reply Quote 1
                                      • uros76U Offline
                                        uros76 @Jalibu
                                        @jalibu I completely forgot about this one. I will disable the rest and just allow Jast module to be editable. This could also work, thanks
                                          sdetweil @Jalibu
                                          @jalibu you could pull a json list of stocks from a file, like compliments does
                                          and do it on some timed cycle, hourly, daily.
                                          @uros76 one could also try using my MMM-Config module, which presents a form for config.js, where user could + to add, - to remove
                                          see
                                          https://github.com/sdetweil/MMM-Config
                                          then the user could change via their phone or ipad/laptop…
                                          • uros76U Offline
                                            uros76 @sdetweil
                                            @sdetweil excellent, yes that’s what I am trying now. Thanks
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 4 / 9
