    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 237.6k Views 39 Watching
      sdetweil
      I submitted a PR for jast to improve the form for the stocks list
        mweth
        Great module and I think this is a simple request. I would like for the ticker to only change to red or green if the stock moves by more than 5%. In VerticalStockList.njk, I changed the code as follows (and added a “same” color in the CSS, but it did not do anything. Super bonus points if I can make a movement of more than 7% show an image.
        {{ utils.getStockName(stock) }}: {% if utils.getStockChange(stock) > 3 %} {% set colorClass = “high” %} {% elif utils.getStockChange(stock) < 3 %} {% set colorClass = "low " %} {% else %} {% set colorClass = “same” %}
          MasonR1209
          Hey, I wanted to know if it’s possible to make a static always there Portfolio Value… that changes as the stocks listed change in price, but is always shown, and have the stocks ticker above / below the portfolio value, and not scroll to the portfolio value as it would be permanently shown… e.g
          Scrolling stocks ticker
          Portfolio Value: xxxx
          Possibly also add a static always shown portfolio change value / change percentage that isn’t included in the scroll.
          I would opt for the Static option for all as you can in the config but it takes up too much room on the mirror and I was wondering if what i’ve stated is configurable? Thanks
          ALSO. Having issues with the default module of ‘currentweather’. This MMM-Jast module makes my currentweather module disappear. It loads, then as soon as MMM-Jast loads, currentweather disappears. As soon as I remove MMM-Jast from the config, then currentweather works again.
          JalibuJ 1 Reply Last reply Reply Quote 0
          • JalibuJ Offline
            Jalibu Module Developer @MasonR1209
            @masonr1209 please open two issues on GitHub on that. I’ll check them when I have more time again
              Jo 0
              how can I format the Output Numbers?
              like 34,265.37$ or
              34.265,37$ according the settings.
              • JalibuJ Offline
                Jalibu Module Developer @Jo 0
                Hi @jo-0,
                MMM-JaST follows the formatting rules for your locale which is set in your config.js
                The comma as decimal separator is common for German locale for example (de-DE) where the dot as decimal separator is common for English locales (en-GB)
                var config = {
                 language: "de",
                 locale: "de-DE",
                 timeFormat: 24,
                 units: "metric",
                 modules:
                Keep in mind that locale settings can affect all modules. MMM-JaST has an option to override global platform locale settings. Just add the following to your Jast module config:
                    module: "MMM-Jast",
                     locale: "de-DE", // or any other desired locale for number formatting
                  Jo 0 @Jalibu
                  @jalibu thanks for fast answering,
                  Doesn’t work the way I want it to.
                  I just want the separator for the thousands.
                  modules locale: “de-DE”,
                  Jast lokale:
                  de-DE gives 14170,85$
                  en-GB gives US$14170.85
                  What I want is 14.170,85$
                  • JalibuJ Offline
                    @jo-0 add
                    useGrouping: true,
                    to your module configuration.
                      Jo 0 @Jalibu
                      @jalibu said in [MMM-JaST] Just another Stock Ticker (new: version 2.x):
                      useGrouping: true,
                      it does not work.
                      I run scroll: “none”
                      J JalibuJ 2 Replies Last reply Reply Quote 0
                        Jo 0 @Jo 0
                        @jo-0
                        Btw. I’m new in MMM.
                        I got the message that there is an update for JaST.
                        How can I get this
                        git pull
                        npm install --only=production
                        does not help
                          sdetweil @Jo 0
                          @jo-0 in the module folder, right?
                          • JalibuJ Offline
                            @jo-0 said in [MMM-JaST] Just another Stock Ticker (new: version 2.x):
                            useGrouping: true,
                            it does not work.
                            please PN me your module config
                              Jo 0 @Jalibu
                              @jalibu don’t know how to PN
                              therefore here:
                              module: “MMM-Jast”,
                              position: “bottom_right”, //“bottom_center”,
                              locale: “de-DE”,
                              useGrouping: true,
                              stocks: [
                              { name: “DOW 30”, symbol: “^DJI”, quantity: 10 },
                              //{ name: “S&P 500”, symbol: “^GSPC”, quantity: 15 },
                              { name: “Nasdaq 100”, symbol: “^NDX” },
                              //{ name: “DAX 30”, symbol: “^GDAXI” },
                              { name: “EUR/USD”, symbol: “EURUSD=X”}
                              maxWidth: “100%”,
                              updateIntervalInSeconds: 300,
                              fadeSpeedInSeconds: 15, //3.5,
                              scroll: “none”, // One of [“none”, “vertical”, “horizontal”]
                              useGrouping: false,
                              currencyStyle: “symbol”, // One of [“code”, “symbol”, “name”]
                              lastUpdateFormat: “HH:mm”,
                              showColors: true,
                              showCurrency: true,
                              showChangePercent: true,
                              showChangeValue: false,
                              showChangeValueCurrency: false,
                              showLastUpdate: false,
                              showPortfolioValue: false,
                              showPortfolioGrowthPercent: false,
                              showPortfolioGrowth: false,
                              numberDecimalsValues: 2,
                              numberDecimalsPercentages: 1,
                              virtualHorizontalMultiplier: 2
                              S JalibuJ 2 Replies Last reply Reply Quote 0
                                sdetweil @Jo 0
                                @jo-0 he meant pm, private message
                                  Jo 0 @sdetweil
                                  @sdetweil I know, but where can I find the email address?
                                    sdetweil @Jo 0
                                    @jo-0 not email. chat here,
                                    click his username,
                                    then 3 dots to the right,
                                    start new chat
                                    • JalibuJ Offline
                                      @jo-0 you have useGrouping property twice in your settings. As true and as false. remove the ‚useGrouping: false‘ and it will work
                                        Jo 0 @Jalibu
                                        @jalibu Hi,
                                        workes fine now! Exactly how i wanted it.
                                        thank you.
                                        But next:
                                        how can I update the modul?
                                        ‘git pull’
                                        decline with the notice ‘please committen or stashen …’
                                        cancellation.
                                        Not sure what to do.
                                        • JalibuJ Offline
                                          @jo-0 in the modules/MMM-Jast folder try to execute git reset --hard first and continue with git pull and npm install --only=production in a second step.
                                            Jo 0 @Jalibu
                                            @jalibu
                                            thank you very much, that was the solution
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 5 / 9
