    Can't clone from GitHub
    107 Posts 3 Posters 68.3k Views 3 Watching
    • bheplerB Offline
      bhepler Module Developer @sdetweil
      @sdetweil - Yeah, at this point it may be easier to just back up the config.jsfile and reflash the SD card.
        MMRPi1 @bhepler
        @bhepler Didn’t work
          MMRPi1 @bhepler
          @bhepler I’d very much prefer it doesn’t come to that. I’m on a Pi 1 and I had enough (too much) trouble setting up MM in the first place (since its not officially supported), I’m kinda paranoid it won’t work this time around
            sdetweil @MMRPi1
            @MMRPi1 use my installer script
            see here https://github.com/sdetweil/MagicMirror_scripts
            read the readme for the command to issue
              MMRPi1 @sdetweil
              @sdetweil that to update?
              bheplerB S 2 Replies Last reply Reply Quote 0
              • bheplerB Offline
                bhepler Module Developer @MMRPi1
                @MMRPi1 - He has an installation script too. Use that one instead. It’s quite robust.
                If you’re really paranoid about losing your data, you can make an image of your SD card before reflashing it. If anything goes wrong, you can just flash that image back onto the card.
                The downside is that it’s going to take a fair amount of time to install Magic Mirror again. But I think at this point it’s going to be faster this way than to keep banging our heads against this TLS error.
                  sdetweil @MMRPi1
                  @MMRPi1 no. install
                  my stuff does ONLY MagicMirror related work
                  so create a new sd card, get it all working, ssh, whatever
                  and check that git clone works (U can get this repo), just don’t use it after download
                  then ssh in and execute the MM install script command
                    sdetweil @bhepler
                    @bhepler said in Can't clone from GitHub:
                    typically less than 20 minutes
                    oh, use raspian buster, not jessie or stretch… too old now
                    • bheplerB Offline
                      @sdetweil said in Can't clone from GitHub:
                      He’s on an RPI 1. That’s not typical.
                        sdetweil @bhepler
                        @bhepler still won’t be bad… take 25 on my pi0
                        • 7
                        • 8
                        • 9
                        • 10
                        • 11
                        • 9 / 11
