    Can't clone from GitHub
    107 Posts 3 Posters 71.9k Views 3 Watching
      MMRPi1 @bhepler
      @bhepler For reference on why I’m sceptical, check my other thread from a few years back
        sdetweil @MMRPi1
        @MMRPi1 its been a mess… the old installer didn’t work, and there are tons of old documents that people built 2-3 years ago, that are no mostly useless, but we can’t get rid of them.
        i wanted the installer to be THE way to get it installed, by it takes a lot of work, and it was felt that was outside the MM project objectives… so they were removed in 2.11. armv6l devices pi 0, 1 and pi2 a are not supported (ie won’t run) unless some extra work is done… my script handles all that
          MMRPi1 @sdetweil
          @sdetweil Oh alright I guess. Well I guess I’ll image the SD, flash it, try again and hope for the best. Here goes
          • bheplerB Offline
            bhepler Module Developer
            good luck
              sdetweil @MMRPi1
              @MMRPi1 do you have another sd card available?
                MMRPi1 @sdetweil
                @sdetweil Don’t think so but I’ll look around.
                  sdetweil @MMRPi1
                  @MMRPi1 ok, before you start, one thing… electron for the newer node levels is not available for armv6l devices anymore, so we run in split mode, serveronly and chrome-browser to view… takes a little longer to start up
                    MMRPi1 @sdetweil
                    @sdetweil I think I do that already. Not sure what split mode is though. Side note: I found an old SD, how much space do I need for the OS and MM and everything else?
                    S bheplerB 2 Replies Last reply Reply Quote 0
                      sdetweil @MMRPi1
                      @MMRPi1 i think 8 gig is too small
                        MMRPi1 @sdetweil
                        @sdetweil Cool /s All I’ve got is 4GB :/
                        • 7
                        • 8
                        • 9
                        • 10
                        • 11
                        • 10 / 11
