    Can't clone from GitHub
    107 Posts 3 Posters 68.3k Views 3 Watching
      sdetweil @MMRPi1
      @MMRPi1 u recompiled the git with openssl?? then it should give the gnutils error
      sudo apt-get install -y build-essential fakeroot dpkg-dev
      sudo apt-get -y build-dep git
      sudo apt-get install -y libcurl4-openssl-dev
      mkdir git-openssl
      cd git-openssl
      apt-get source git
      cd git-*
      sed -i -e 's/libcurl4-gnutls-dev/libcurl4-openssl-dev/g'
      ./debian/control
      sed -i -- '/TEST\s*=\s*test/d' ./debian/rules
      sudo dpkg-buildpackage -rfakeroot -b
      sudo dpkg -i git_2.7.4-0ubuntu1.6_arm64.deb
      #CleanUp
      cd ../../
      sudo rm -rf git-openssl
      You can follow This Bog or You can find simple script here to do that
        MMRPi1 @sdetweil
        @sdetweil I tried that and got gnutls_handshake() failed: Close notify
        But that’s the same error as before :/
          sdetweil @MMRPi1
          @MMRPi1 then you are not running the openssl git…
          u may have to run the pi admin tool for software and updates to enable source download… I had to
          M bheplerB 2 Replies Last reply Reply Quote 0
            MMRPi1 @sdetweil
            @sdetweil How do you do that?
            • bheplerB Offline
              bhepler Module Developer @sdetweil
              “gnutls_handshake() failed: Close notify”… I’m sorry, I don’t understand this. Can you type out the exact error that you’re seeing? Including all the text after “failed”.
              M S 2 Replies Last reply Reply Quote 0
                MMRPi1 @bhepler
                @bhepler fatal: unable to access: gnutls_handshake() failed: Close notify
                  sdetweil
                  the build process above doesn’t work. too old
                    sdetweil @bhepler
                    @bhepler but he can git clone from windows on the same local network.
                    almost like an install failure or an sd card starting to fail.
                    • bheplerB Offline
                      @sdetweil - Yeah, this is all kinds of weird. He’s using what appears to be a consumer grade network router. He shouldn’t have to mess with proxy settings as he should just be behind the NAT functions. And even if he was, it should also affect his Windows installation.
                      Let’s try to reinstall git one more time, if you please:
                      sudo apt remove git --purge
                      sudo apt install git
                        sdetweil @bhepler
                        @bhepler I don’t think its a git problem… I think its a library problem
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 11
                        • 8 / 11
