    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 308.5k Views 42 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor @swvalenti
      @Jalibu defaultZoomLevel not working changed it to 12 and map stays the same at default 8
      swvalentiS 1 Reply Last reply Reply Quote 0
        @swvalenti said in MMM-RAIN-MAP:
        Firgured it out change config to zoom instead of defaultZoomLevel
          change mapHeight and mapWidth to height and width in config. Doesn’t work the way you have it
            sdetweil @swvalenti
            @swvalenti he said
            The configuration to version 1.x is completely incompatible and must be adapted.
              swvalenti Project Sponsor @sdetweil
              @sdetweil said in MMM-RAIN-MAP:
              Well I am an idiot and here I thought I was helping. HA
                Bought you a beer to make up for it
                https://www.buymeacoffee.com/jalibu
                • JalibuJ Offline
                  Jalibu Module Developer
                  Hi everyone,
                  I released version 2.0.0 of this module today. It is written 100% from scratch.
                  Changes
                  • The module is now much more leightweight and should consume less computing resources.
                  • Removed GoogleMaps support because the maintenance effort for both maps was too high and the code looked very untidy as a result.
                  • Configuration was redefined. Old module configurations are not compatible!
                  • Much more flexible options to set markers and alternating map positions
                  • The onlyOnRain feature was fixed and is now compatible with the MM’s default weather module and MMM-OpenWeatherForecast
                  If you do not require GoogleMaps, I’d recommend to switch on version 2.x as version 1.x won’t be supported in the future.
                  swvalentiS FoziF 2 Replies Last reply Reply Quote 1
                    swvalenti Project Sponsor @Jalibu
                    @jalibu I updated. Only thing that doesn’t seem to work is only on rain still. Using OWF for weather.
                    • P Offline
                      PH1TCH @swvalenti
                      @swvalenti @Jalibu
                      In my case the opposite of what is actually intended happens: Once it starts to rain, the module will hide itself. The second the rain stops (and the icon of MMM-OpenWeatherForecast changes) the module will be showed again.
                      Does anyone have the same issue?
                      JalibuJ 1 Reply Last reply Reply Quote 0
                      • JalibuJ Offline
                        Jalibu Module Developer @PH1TCH
                        @ph1tch @swvalenti
                        woops… 🙈😇
                        My stupid mistake. This happens when you didn’t pay attention in the Boolean algebra lecture 😁
                        Please pull the latest release.
                        Thank you for your feedback.
                        • FoziF Offline
                          Fozi Project Sponsor @Jalibu
                          @jalibu Thanks for the update of the module! It works great! Also the displayOnlyOnRain option works now correctly. (just pulled the latest commit).
                            MajorC Project Sponsor
                            That sounds great. I will check it out tomorrow.
                            • karsten13K Offline
                              karsten13 @MajorC
                              @Jalibu v2 LGTM.
                              But you have still an error in the README:
                              You want beer but you’re getting only coffee ;)
                              • P Offline
                                PH1TCH @Jalibu
                                @jalibu: I noticed that the show / hide state of the module now changes correctly according to the changes of the MMM-OpenWeatherMap Module :thumbs_up:
                                However, if I restart my mirror on a sunny day, then the RAIN-Map module will be displayed until it starts and stops to rain at least once (and therefore MMM-OWM changes).
                                So, if it were not raining for a long time, the module would still be displayed until the weather changes.
                                Is this the intended behaviour of the module or did I just configure something wrong?
                                Thanks again for your help!
                                FoziF JalibuJ 2 Replies Last reply Reply Quote 0
                                • FoziF Offline
                                  Fozi Project Sponsor @PH1TCH
                                  @ph1tch Let me guess…you’re using MMM-pages, too? Then that might be the problem.
                                  I filed an issue for that on the weekend and @Jalibu provided a fix a few hours ago. I tested it and it works now as expected. Try the fix and see if it solves your issue, too.
                                  • P Offline
                                    PH1TCH @Fozi
                                    @fozi Nope, I’m not using MMM-Pages. But I am using stuff like MMM-ModuleScheduler and MMM-RemoteControl tho.
                                    Maybe they are causing similar issues …
                                    But lemme check the update!
                                    FoziF 1 Reply Last reply Reply Quote 0
                                    • FoziF Offline
                                      @ph1tch I’d assume that MMM-ModuleScheduler is the culprit…I have MMM-RemoteControl, too, and it causes no issues.
                                      Curious to see if it works.
                                      • JalibuJ Offline
                                        @ph1tch haha, the case of no rain for a long time is so hard to test in Germany this year…
                                        P 1 Reply Last reply Reply Quote 3
                                        • P Offline
                                          PH1TCH @Fozi
                                          @fozi So far the update seems to have fixed it … it hasn’t rained since, so I can not confirm it yet, but this is just a matter of hours :beaming_face_with_smiling_eyes:
                                          • P Offline
                                            PH1TCH @Jalibu
                                            Moin @jalibu, seems like we’re in the same Boat!
                                            Weirdly enough, it hasn’t rained today ¯_(ツ)_/¯
                                            I’ll have an eye on it once it starts again!
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 6 / 10
