    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 321.3k Views 42 Watching
    • JalibuJ
      Jalibu Module Developer @sdetweil
      thx @sdetweil for explaining.
      It‘s nothing but a bug. I will fix that as soon as I find the time for some maintenance on that module.
        sdetweil @Jalibu
        @jalibu but I think its a bug in the weather module
        • cowboysdudeC
          cowboysdude Module Developer @sdetweil
          I solved all my weather api issues by just installing my own weather station LOL
          Reply Quote 2
          • JalibuJ
            I did some maintenance/refactorings on that module.
            Version 2.0.0 is currently available as Feature Branch and much more lightweight.
            I also removed GoogleMaps support because the maintenance effort for both maps was too high and the code looked very untidy as a result.
            So far known settings like “onlyOnRain” are missing, because I developed the module from Scratch. As soon as I have first feedback if the module runs stable, I plan to transfer all features of the old version into the new one.
            The configuration to version 1.x is completely incompatible and must be adapted.
            Are there any volunteer users here to please look at version 2.0 and run it for 1-2 weeks for testing?
            swvalentiS 1 Reply Last reply
            • swvalentiS
              swvalenti Project Sponsor @Jalibu
              @jalibu yes sir I will update shortly and run it and let you know.
              • swvalentiS
                swvalenti Project Sponsor @swvalenti
                @Jalibu the only thing I don’t understand or see doc on is the mapUrl ??No matter what my lat/long is on markers or the mapUrl I only see frankfurt
                • swvalentiS
                  @swvalenti said in MMM-RAIN-MAP:
                  Was able to get it working, you didn’t have lat and long in config only mentioned that is required on the bottom. Working now thanks I will post back
                  • swvalentiS
                    @Jalibu defaultZoomLevel not working changed it to 12 and map stays the same at default 8
                    • swvalentiS
                      Firgured it out change config to zoom instead of defaultZoomLevel
                      • swvalentiS
                        change mapHeight and mapWidth to height and width in config. Doesn’t work the way you have it
                          sdetweil @swvalenti
                          • swvalentiS
                            swvalenti Project Sponsor @sdetweil
                            @sdetweil said in MMM-RAIN-MAP:
                            Well I am an idiot and here I thought I was helping. HA
                            • swvalentiS
                              Bought you a beer to make up for it
                              https://www.buymeacoffee.com/jalibu
                              • JalibuJ
                                Hi everyone,
                                I released version 2.0.0 of this module today. It is written 100% from scratch.
                                Changes
                                • The module is now much more leightweight and should consume less computing resources.
                                • Removed GoogleMaps support because the maintenance effort for both maps was too high and the code looked very untidy as a result.
                                • Configuration was redefined. Old module configurations are not compatible!
                                • Much more flexible options to set markers and alternating map positions
                                • The onlyOnRain feature was fixed and is now compatible with the MM’s default weather module and MMM-OpenWeatherForecast
                                If you do not require GoogleMaps, I’d recommend to switch on version 2.x as version 1.x won’t be supported in the future.
                                swvalentiS FoziF 2 Replies Last reply
                                • swvalentiS
                                  @jalibu I updated. Only thing that doesn’t seem to work is only on rain still. Using OWF for weather.
                                  P 1 Reply Last reply
                                    PH1TCH @swvalenti
                                    @swvalenti @Jalibu
                                    In my case the opposite of what is actually intended happens: Once it starts to rain, the module will hide itself. The second the rain stops (and the icon of MMM-OpenWeatherForecast changes) the module will be showed again.
                                    Does anyone have the same issue?
                                    JalibuJ 1 Reply Last reply
                                    • JalibuJ
                                      Jalibu Module Developer @PH1TCH
                                      @ph1tch @swvalenti
                                      woops… 🙈😇
                                      My stupid mistake. This happens when you didn’t pay attention in the Boolean algebra lecture 😁
                                      Please pull the latest release.
                                      Thank you for your feedback.
                                      • FoziF
                                        Fozi Project Sponsor @Jalibu
                                        @jalibu Thanks for the update of the module! It works great! Also the displayOnlyOnRain option works now correctly. (just pulled the latest commit).
                                          MajorC Project Sponsor
                                          That sounds great. I will check it out tomorrow.
                                          karsten13K 1 Reply Last reply
                                          • karsten13K
                                            karsten13 @MajorC
                                            @Jalibu v2 LGTM.
                                            But you have still an error in the README:
                                            You want beer but you’re getting only coffee ;)
                                            • 10
                                            • 6 / 10
