    MMM-RAIN-MAP (new: version 2.x)
    192 Posts 38 Posters 292.1k Views 41 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor @sdetweil
      Even with default weather module installed the onlyOnRain= true, does not work. Anyone else?
        sdetweil @swvalenti
        @swvalenti said in MMM-RAIN-MAP:
        onlyOnRain= true
        that might be a bug
        in the older currentWeather module it sends the icon name
        this.sendNotification("CURRENTWEATHER_TYPE", { type: this.config.iconTable[data.weather[0].icon].replace("-", "_") });
        and in the new weather , it sends the weatherType (code?)
        			this.sendNotification("CURRENTWEATHER_TYPE", { type: this.weatherProvider.currentWeather().weatherType.replace("-", "_") });
        u should be able to look at the notification in the developers window console
        u can filter on the notification 'CURRENT" is enough I think
        swvalentiS 1 Reply Last reply Reply Quote 0
          @sdetweil ok so if you don’t use default then it wont work as well then?
            sdetweil @swvalenti
            i don’t understand your question…
            the option u listed is dependent on a default module sending a notification that Rain-Map USES .
            so that means you MUST use the default module
            if its not sent, then there is nothing to receive
            if the data is wrong, then it doesn’t work.
            swvalentiS JalibuJ 2 Replies Last reply Reply Quote 0
              @sdetweil you answered my question thank you!
              • JalibuJ Offline
                Jalibu Module Developer @sdetweil
                thx @sdetweil for explaining.
                It‘s nothing but a bug. I will fix that as soon as I find the time for some maintenance on that module.
                  sdetweil @Jalibu
                  @jalibu but I think its a bug in the weather module
                  • cowboysdudeC Offline
                    cowboysdude Module Developer @sdetweil
                    I solved all my weather api issues by just installing my own weather station LOL
                    • JalibuJ Offline
                      I did some maintenance/refactorings on that module.
                      Version 2.0.0 is currently available as Feature Branch and much more lightweight.
                      I also removed GoogleMaps support because the maintenance effort for both maps was too high and the code looked very untidy as a result.
                      So far known settings like “onlyOnRain” are missing, because I developed the module from Scratch. As soon as I have first feedback if the module runs stable, I plan to transfer all features of the old version into the new one.
                      The configuration to version 1.x is completely incompatible and must be adapted.
                      Are there any volunteer users here to please look at version 2.0 and run it for 1-2 weeks for testing?
                        swvalenti Project Sponsor @Jalibu
                        @jalibu yes sir I will update shortly and run it and let you know.
                          swvalenti Project Sponsor @swvalenti
                          @Jalibu the only thing I don’t understand or see doc on is the mapUrl ??No matter what my lat/long is on markers or the mapUrl I only see frankfurt
                            Was able to get it working, you didn’t have lat and long in config only mentioned that is required on the bottom. Working now thanks I will post back
                              @Jalibu defaultZoomLevel not working changed it to 12 and map stays the same at default 8
                                Firgured it out change config to zoom instead of defaultZoomLevel
                                  change mapHeight and mapWidth to height and width in config. Doesn’t work the way you have it
                                    sdetweil @swvalenti
                                      @sdetweil said in MMM-RAIN-MAP:
                                      Well I am an idiot and here I thought I was helping. HA
                                        Bought you a beer to make up for it
                                        https://www.buymeacoffee.com/jalibu
                                        • JalibuJ Offline
                                          Hi everyone,
                                          I released version 2.0.0 of this module today. It is written 100% from scratch.
                                          Changes
                                          • The module is now much more leightweight and should consume less computing resources.
                                          • Removed GoogleMaps support because the maintenance effort for both maps was too high and the code looked very untidy as a result.
                                          • Configuration was redefined. Old module configurations are not compatible!
                                          • Much more flexible options to set markers and alternating map positions
                                          • The onlyOnRain feature was fixed and is now compatible with the MM’s default weather module and MMM-OpenWeatherForecast
                                          If you do not require GoogleMaps, I’d recommend to switch on version 2.x as version 1.x won’t be supported in the future.
                                          swvalentiS FoziF 2 Replies Last reply Reply Quote 1
                                            @jalibu I updated. Only thing that doesn’t seem to work is only on rain still. Using OWF for weather.
                                            • 10
                                            • 5 / 10
