    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 321.3k Views 42 Watching
    • nitewing76N
      nitewing76
      How do I center the map in the middle of a region? The header is centered, but not the map. (not referring to the marker within the map, but the map itself)
      nitewing76N 1 Reply Last reply
      • nitewing76N
        nitewing76 @nitewing76
        ^^^ works by adding:
        		app.style.margin = "0 auto";
        at line 91 of util.js.
          Doudy
          How do I display two maps with different zooms?
          In config.js I encoded the module twice: “MMM-RAIN-MAP” with different zooms.
          Only the first is displayed
          For the second I only see the clock!
          :winking_face:
          JalibuJ Mykle1M 2 Replies Last reply
          • JalibuJ
            Jalibu Module Developer @Doudy
            @doudy this doesn‘t work at the moment. If you open an issue on github for that, I can try to add it.
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Doudy
              @doudy said in MMM-RAIN-MAP:
              You can try this in the meantime:
              https://forum.magicmirror.builders/topic/14724/run-two-instances-of-the-same-module-sometimes-tutorial
              D 1 Reply Last reply
                Doudy @Mykle1
                @mykle1
                I tried your solution with MMM-RAIN-MAP
                MMM-RAIN-MAP alone -> it works
                MMM-RAIN-MAP2 alone -> it works
                MMM-RAIN-MAP + MMM-RAIN-MAP2 -> it doesn’t work completly
                • Only the one is displayed (MMM-RAIN-MAP)
                • Only clock is displayed from ( MMM-RAIN-MAP2)
                :exclamation_question_mark:
                JalibuJ 1 Reply Last reply
                  Doudy @Jalibu
                  @jalibu
                  @stoffbeuteluwe said in MMM-RAIN-MAP:
                  @Jalibu Hello, the module is very good but it only shows the time that has already passed and not the time that is yet to come…
                  can I change that is showing the next 2 hours
                  With windy is it not possible to display the rain forecast?
                  History is less important for me!
                  https://embed.windy.com/embed2.html?lat=50.xxx&lon=3.xxx&zoom=5&level=surface&overlay=rain&menu=&message=&marker=&calendar=&pressure=&type=map&location=coordinates&detail=&detailLat=50.261&detailLon=3.796&metricWind=km%2Fh&metricTemp=°C&radarRange=-1
                  • JalibuJ
                    I think multiple instances don’t work due to duplicate element IDs.
                    I’ll fix that some day ;-)
                      Doudy @Jalibu
                      @jalibu :ok_hand:
                        matefits71
                        Hi guys,
                        Thanks for this module,
                        I have a little problem regarding the update time,
                        Basically the forecast are 2h old, it means it’s showing what happen and not what will happen,
                        Right now it’s 11:27 and it’s showing data from 9:20 to 11:20, i want it to show from 11:30 to 13:30
                        How do you put the forecast to update for the next 2h?
                        Also, is there any chance to add more fluidity (or fps) to the animation? For exemple the app raintoday (ios) does this perfectly. I’m not sure if we can get there API.
                        Thanks!
                        FoziF 1 Reply Last reply
                        • FoziF
                          Fozi Project Sponsor @matefits71
                          @matefits71 said in MMM-RAIN-MAP:
                          Well, MMM-RAIN_MAP is based on the FREE Rainviewer API, which allows the use the radar data of the past.
                          Forecast is a central feature of RainViewers business model. The forecast function of RainViewer requires for the iOS-app (certainly for the Android app, too) a paid subscription. Thus, I strongly doubt, that someone can use a paid function for free via their API. If I read their basic API information correctly, you don’t even get as a patron or gold member of the paid API, the forecast calculations.
                          The API provides a radar snap shot every 10 minutes- Thus, you’ll meed to interpolate the precipitation images (intensity, direction, accuracy, etc.) which is not a trivial task and needs -depending on the used method and number of interpolations- quite some computational resources. which might not be available on an RPi.
                          • cowboysdudeC
                            cowboysdude Module Developer @Fozi
                            @fozi but but but…can’t you just make it do what someone else wants? LOL
                            My answer is the same… fork the module and make all the changes you want ;)
                            • JalibuJ
                              thank you @matefits71 for your ideas and feedback and thank you @Fozi for your excellent answer about the reasons for all of the current limitations.
                              I am also not very satisfied with this module and already tried to refactor it with the windy.com API. First results looked okay but I wasn‘t able to get it to a stable state that did not hang up after a few hours on the Raspi due to its high resource consumption.
                              I am very open for any kind of contribution or ideas here and still think about a second try on the windy refactoring.
                              By now, unfortunately this module is still the best of its kind :-/
                              • FoziF
                                Fozi Project Sponsor @Jalibu
                                Word! (…and strike „unfortunately“…)
                                • swvalentiS
                                  swvalenti Project Sponsor @Fozi
                                  Awesome mod trying to use google maps and created an api key and billing but get error saying that billing needs to be enabled.
                                    sdetweil @swvalenti
                                    @swvalenti u have to provide a credit card for billing to work.
                                    google gives you limited free usage, and their design is that the using app should keep working, even when the free usage runs out… So, they demand a useful card up front.
                                    swvalentiS 1 Reply Last reply
                                    • swvalentiS
                                      swvalenti Project Sponsor @sdetweil
                                      @sdetweil Correct I have primary and backup on file but doesn’t seem to work saying I still need billing enabled.
                                        sdetweil @swvalenti
                                        @swvalenti
                                        Go to the API Console.
                                        From the projects list, select a project or create a new one.
                                        Open the console left side menu (three bars top left)  and select Billing.
                                        Click Enable billing. ( ...
                                        • swvalentiS
                                          Even with default weather module installed the onlyOnRain= true, does not work. Anyone else?
                                            sdetweil @swvalenti
                                            @swvalenti said in MMM-RAIN-MAP:
                                            onlyOnRain= true
                                            that might be a bug
                                            in the older currentWeather module it sends the icon name
                                            this.sendNotification("CURRENTWEATHER_TYPE", { type: this.config.iconTable[data.weather[0].icon].replace("-", "_") });
                                            and in the new weather , it sends the weatherType (code?)
                                            			this.sendNotification("CURRENTWEATHER_TYPE", { type: this.weatherProvider.currentWeather().weatherType.replace("-", "_") });
                                            u should be able to look at the notification in the developers window console
                                            u can filter on the notification 'CURRENT" is enough I think
                                            • 10
                                            • 4 / 10
