    MMM-RAIN-MAP (new: version 2.x)
    192 Posts 38 Posters 302.8k Views 41 Watching
      bhepler Module Developer @singhharry12
      @singhharry12 - That’s exactly what I did. Add this line to your configuration: osmMapUrl: "https://cartodb-basemaps-{s}.global.ssl.fastly.net/dark_all/{z}/{x}/{y}.png"
      Looks great (actual rain on rain map today!)
      M F 2 Replies Last reply Reply Quote 2
        MajorC Project Sponsor @bhepler
        @bhepler is there a good way to set the opacity of the map?
        @Jalibu Thank you for this awesome module!
          chassain 0 @MajorC
          @MajorC
          add maybe to custom.css
          .MMM Rain-Map {
          opacity: 0 //0 to 1
            Thank you,
            .MMM-RAIN-MAP {
               opacity: 0.7;
            in the custom.css works very well.
            • StoffbeuteluweS Offline
              Stoffbeuteluwe Project Sponsor
              Hi, is there only weather history on openstreetmap or is it possible to see two hours forecast?
              JalibuJ 1 Reply Last reply Reply Quote 0
              • JalibuJ Offline
                Jalibu Module Developer @Stoffbeuteluwe
                @Stoffbeuteluwe Unfortunately the data provider only provides a weather history and no forecast :-/
                • JalibuJ Offline
                  Hello everyone,
                  does the module still work for all of you? I’m facing loading problems for about 2 days now, but I haven’t had the time to take a closer look at the cause yet.
                  Please give me feedback.
                  C FoziF 2 Replies Last reply Reply Quote 0
                    chassain 0 @Jalibu
                    @Jalibu same here with module mmm pages…but the module is running alone…So, with mmm pages, take this module in first page…waiting a solution
                    • FoziF Offline
                      Fozi Project Sponsor @Jalibu
                      @Jalibu the module is still running fine. No problems whatsoever.
                      • nitewing76N Offline
                        nitewing76
                        How do I center the map in the middle of a region? The header is centered, but not the map. (not referring to the marker within the map, but the map itself)
                        nitewing76N 1 Reply Last reply Reply Quote 0
                          nitewing76 @nitewing76
                          ^^^ works by adding:
                          		app.style.margin = "0 auto";
                          at line 91 of util.js.
                            Doudy
                            How do I display two maps with different zooms?
                            In config.js I encoded the module twice: “MMM-RAIN-MAP” with different zooms.
                            Only the first is displayed
                            For the second I only see the clock!
                            :winking_face:
                            JalibuJ Mykle1M 2 Replies Last reply Reply Quote 0
                            • JalibuJ Offline
                              Jalibu Module Developer @Doudy
                              @doudy this doesn‘t work at the moment. If you open an issue on github for that, I can try to add it.
                                Mykle1 Project Sponsor Module Developer @Doudy
                                @doudy said in MMM-RAIN-MAP:
                                You can try this in the meantime:
                                https://forum.magicmirror.builders/topic/14724/run-two-instances-of-the-same-module-sometimes-tutorial
                                  Doudy @Mykle1
                                  @mykle1
                                  I tried your solution with MMM-RAIN-MAP
                                  MMM-RAIN-MAP alone -> it works
                                  MMM-RAIN-MAP2 alone -> it works
                                  MMM-RAIN-MAP + MMM-RAIN-MAP2 -> it doesn’t work completly
                                  • Only the one is displayed (MMM-RAIN-MAP)
                                  • Only clock is displayed from ( MMM-RAIN-MAP2)
                                  :exclamation_question_mark:
                                    Doudy @Jalibu
                                    @jalibu
                                    @stoffbeuteluwe said in MMM-RAIN-MAP:
                                    @Jalibu Hello, the module is very good but it only shows the time that has already passed and not the time that is yet to come…
                                    can I change that is showing the next 2 hours
                                    With windy is it not possible to display the rain forecast?
                                    History is less important for me!
                                    https://embed.windy.com/embed2.html?lat=50.xxx&lon=3.xxx&zoom=5&level=surface&overlay=rain&menu=&message=&marker=&calendar=&pressure=&type=map&location=coordinates&detail=&detailLat=50.261&detailLon=3.796&metricWind=km%2Fh&metricTemp=°C&radarRange=-1
                                    • JalibuJ Offline
                                      I think multiple instances don’t work due to duplicate element IDs.
                                      I’ll fix that some day ;-)
                                        Doudy @Jalibu
                                        @jalibu :ok_hand:
                                          matefits71
                                          Hi guys,
                                          Thanks for this module,
                                          I have a little problem regarding the update time,
                                          Basically the forecast are 2h old, it means it’s showing what happen and not what will happen,
                                          Right now it’s 11:27 and it’s showing data from 9:20 to 11:20, i want it to show from 11:30 to 13:30
                                          How do you put the forecast to update for the next 2h?
                                          Also, is there any chance to add more fluidity (or fps) to the animation? For exemple the app raintoday (ios) does this perfectly. I’m not sure if we can get there API.
                                          Thanks!
                                          • FoziF Offline
                                            Fozi Project Sponsor @matefits71
                                            @matefits71 said in MMM-RAIN-MAP:
                                            Well, MMM-RAIN_MAP is based on the FREE Rainviewer API, which allows the use the radar data of the past.
                                            Forecast is a central feature of RainViewers business model. The forecast function of RainViewer requires for the iOS-app (certainly for the Android app, too) a paid subscription. Thus, I strongly doubt, that someone can use a paid function for free via their API. If I read their basic API information correctly, you don’t even get as a patron or gold member of the paid API, the forecast calculations.
                                            The API provides a radar snap shot every 10 minutes- Thus, you’ll meed to interpolate the precipitation images (intensity, direction, accuracy, etc.) which is not a trivial task and needs -depending on the used method and number of interpolations- quite some computational resources. which might not be available on an RPi.
                                            • 10
                                            • 4 / 10
