    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 321.2k Views 42 Watching
      singhharry12
      Now if I could just get a dark theme going. I’m cool with the rain being in color, but it would be nice if I could figure out how to get the roads & state borders to only be outlines. 9apps cartoonhd.onl
      bheplerB 1 Reply Last reply
      • bheplerB
        bhepler Module Developer @singhharry12
        @singhharry12 - That’s exactly what I did. Add this line to your configuration: osmMapUrl: "https://cartodb-basemaps-{s}.global.ssl.fastly.net/dark_all/{z}/{x}/{y}.png"
        Looks great (actual rain on rain map today!)
        M F 2 Replies Last reply
        Reply Quote 2
          MajorC Project Sponsor @bhepler
          @bhepler is there a good way to set the opacity of the map?
          @Jalibu Thank you for this awesome module!
          C 1 Reply Last reply
            chassain 0 @MajorC
            @MajorC
            add maybe to custom.css
            .MMM Rain-Map {
            opacity: 0 //0 to 1
              Thank you,
              .MMM-RAIN-MAP {
                 opacity: 0.7;
              in the custom.css works very well.
              • StoffbeuteluweS
                Stoffbeuteluwe Project Sponsor
                Hi, is there only weather history on openstreetmap or is it possible to see two hours forecast?
                JalibuJ 1 Reply Last reply
                • JalibuJ
                  Jalibu Module Developer @Stoffbeuteluwe
                  @Stoffbeuteluwe Unfortunately the data provider only provides a weather history and no forecast :-/
                  • JalibuJ
                    Hello everyone,
                    does the module still work for all of you? I’m facing loading problems for about 2 days now, but I haven’t had the time to take a closer look at the cause yet.
                    Please give me feedback.
                    C FoziF 2 Replies Last reply
                      chassain 0 @Jalibu
                      @Jalibu same here with module mmm pages…but the module is running alone…So, with mmm pages, take this module in first page…waiting a solution
                      • FoziF
                        Fozi Project Sponsor @Jalibu
                        @Jalibu the module is still running fine. No problems whatsoever.
                        • nitewing76N
                          nitewing76
                          How do I center the map in the middle of a region? The header is centered, but not the map. (not referring to the marker within the map, but the map itself)
                          nitewing76N 1 Reply Last reply
                          • nitewing76N
                            nitewing76 @nitewing76
                            ^^^ works by adding:
                            		app.style.margin = "0 auto";
                            at line 91 of util.js.
                              Doudy
                              How do I display two maps with different zooms?
                              In config.js I encoded the module twice: “MMM-RAIN-MAP” with different zooms.
                              Only the first is displayed
                              For the second I only see the clock!
                              :winking_face:
                              JalibuJ Mykle1M 2 Replies Last reply
                              • JalibuJ
                                Jalibu Module Developer @Doudy
                                @doudy this doesn‘t work at the moment. If you open an issue on github for that, I can try to add it.
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @Doudy
                                  @doudy said in MMM-RAIN-MAP:
                                  You can try this in the meantime:
                                  https://forum.magicmirror.builders/topic/14724/run-two-instances-of-the-same-module-sometimes-tutorial
                                  D 1 Reply Last reply
                                    Doudy @Mykle1
                                    @mykle1
                                    I tried your solution with MMM-RAIN-MAP
                                    MMM-RAIN-MAP alone -> it works
                                    MMM-RAIN-MAP2 alone -> it works
                                    MMM-RAIN-MAP + MMM-RAIN-MAP2 -> it doesn’t work completly
                                    • Only the one is displayed (MMM-RAIN-MAP)
                                    • Only clock is displayed from ( MMM-RAIN-MAP2)
                                    :exclamation_question_mark:
                                      Doudy @Jalibu
                                      @jalibu
                                      @stoffbeuteluwe said in MMM-RAIN-MAP:
                                      @Jalibu Hello, the module is very good but it only shows the time that has already passed and not the time that is yet to come…
                                      can I change that is showing the next 2 hours
                                      With windy is it not possible to display the rain forecast?
                                      History is less important for me!
                                      https://embed.windy.com/embed2.html?lat=50.xxx&lon=3.xxx&zoom=5&level=surface&overlay=rain&menu=&message=&marker=&calendar=&pressure=&type=map&location=coordinates&detail=&detailLat=50.261&detailLon=3.796&metricWind=km%2Fh&metricTemp=°C&radarRange=-1
                                      • JalibuJ
                                        I think multiple instances don’t work due to duplicate element IDs.
                                        I’ll fix that some day ;-)
                                          Doudy @Jalibu
                                          @jalibu :ok_hand:
                                            matefits71
                                            Hi guys,
                                            Thanks for this module,
                                            I have a little problem regarding the update time,
                                            Basically the forecast are 2h old, it means it’s showing what happen and not what will happen,
                                            Right now it’s 11:27 and it’s showing data from 9:20 to 11:20, i want it to show from 11:30 to 13:30
                                            How do you put the forecast to update for the next 2h?
                                            Also, is there any chance to add more fluidity (or fps) to the animation? For exemple the app raintoday (ios) does this perfectly. I’m not sure if we can get there API.
                                            Thanks!
                                            FoziF 1 Reply Last reply
                                            • 10
                                            • 4 / 10
