    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 316.1k Views 42 Watching
    • swvalentiS
      swvalenti Project Sponsor @sdetweil
      @sdetweil Correct I have primary and backup on file but doesn’t seem to work saying I still need billing enabled.
        sdetweil @swvalenti
        @swvalenti
        Go to the API Console.
        From the projects list, select a project or create a new one.
        Open the console left side menu (three bars top left)  and select Billing.
        Click Enable billing. ( ...
        swvalentiS 1 Reply Last reply Reply Quote 0
        • swvalentiS
          Even with default weather module installed the onlyOnRain= true, does not work. Anyone else?
            sdetweil @swvalenti
            @swvalenti said in MMM-RAIN-MAP:
            onlyOnRain= true
            that might be a bug
            in the older currentWeather module it sends the icon name
            this.sendNotification("CURRENTWEATHER_TYPE", { type: this.config.iconTable[data.weather[0].icon].replace("-", "_") });
            and in the new weather , it sends the weatherType (code?)
            			this.sendNotification("CURRENTWEATHER_TYPE", { type: this.weatherProvider.currentWeather().weatherType.replace("-", "_") });
            u should be able to look at the notification in the developers window console
            u can filter on the notification 'CURRENT" is enough I think
            • swvalentiS
              @sdetweil ok so if you don’t use default then it wont work as well then?
                sdetweil @swvalenti
                i don’t understand your question…
                the option u listed is dependent on a default module sending a notification that Rain-Map USES .
                so that means you MUST use the default module
                if its not sent, then there is nothing to receive
                if the data is wrong, then it doesn’t work.
                swvalentiS JalibuJ 2 Replies Last reply Reply Quote 0
                • swvalentiS
                  @sdetweil you answered my question thank you!
                  • JalibuJ
                    Jalibu Module Developer @sdetweil
                    thx @sdetweil for explaining.
                    It‘s nothing but a bug. I will fix that as soon as I find the time for some maintenance on that module.
                      sdetweil @Jalibu
                      @jalibu but I think its a bug in the weather module
                      • cowboysdudeC
                        cowboysdude Module Developer @sdetweil
                        I solved all my weather api issues by just installing my own weather station LOL
                        • JalibuJ
                          I did some maintenance/refactorings on that module.
                          Version 2.0.0 is currently available as Feature Branch and much more lightweight.
                          I also removed GoogleMaps support because the maintenance effort for both maps was too high and the code looked very untidy as a result.
                          So far known settings like “onlyOnRain” are missing, because I developed the module from Scratch. As soon as I have first feedback if the module runs stable, I plan to transfer all features of the old version into the new one.
                          The configuration to version 1.x is completely incompatible and must be adapted.
                          Are there any volunteer users here to please look at version 2.0 and run it for 1-2 weeks for testing?
                          • swvalentiS
                            swvalenti Project Sponsor @Jalibu
                            @jalibu yes sir I will update shortly and run it and let you know.
                            • swvalentiS
                              swvalenti Project Sponsor @swvalenti
                              @Jalibu the only thing I don’t understand or see doc on is the mapUrl ??No matter what my lat/long is on markers or the mapUrl I only see frankfurt
                              • swvalentiS
                                Was able to get it working, you didn’t have lat and long in config only mentioned that is required on the bottom. Working now thanks I will post back
                                • swvalentiS
                                  @Jalibu defaultZoomLevel not working changed it to 12 and map stays the same at default 8
                                  • swvalentiS
                                    Firgured it out change config to zoom instead of defaultZoomLevel
                                    • swvalentiS
                                      change mapHeight and mapWidth to height and width in config. Doesn’t work the way you have it
                                        sdetweil @swvalenti
                                        • swvalentiS
                                          @sdetweil said in MMM-RAIN-MAP:
                                          Well I am an idiot and here I thought I was helping. HA
                                          • swvalentiS
                                            Bought you a beer to make up for it
                                            https://www.buymeacoffee.com/jalibu
                                            • 10
                                            • 5 / 10
