    • Search
    MagicMirror² v2.24.0 is available! For more information about this release, check out this topic.
    new tutorial pls
    Troubleshooting
    962
    • R
      raf last edited by
      can someone make a new tutorial to make for the google assistant credentials / api because the steps are very different than described in the wiki
      https://github.com/bugsounet/MMM-GoogleAssistant/wiki/Google-Assistant-Setup
      thx
      S E 2 Replies Last reply Reply Quote 0
        sdetweil @raf last edited by
        @raf well, we are all busy…
        • E
          ember1205 @raf last edited by ember1205
          @raf Are you volunteering? 🙂
          Seriously - You won’t be anywhere near as well-versed as if you can figure it out on your own. And documenting your learnings to help others is how all of this stuff grows and improves. I’ve pestered @sdetweil plenty about a lot - much of his input has been to help me understand where to look, but he has also done some coding and such on his side. I’ve offered back some things I learned along the way that he has then incorporated and I’m now going to look into helping to extend and enhance some work he has done by doing the coding myself. It take a village, as they say…
          R cowboysdude 2 Replies Last reply Reply Quote 1
          • R
            raf @ember1205 last edited by
            @ember1205 if the wiki were correct then there was no problem I’ve already made almost 30 tries
            E S 2 Replies Last reply Reply Quote 0
            • E
              @raf So, figure out what’s incorrect and help get it updated. The doc you’re trying to work from was built in that same way at one point…
              • cowboysdude
                cowboysdude Module Developer @ember1205 last edited by
                @ember1205 problem is that’s not how it works LOL in the new ‘buy me’, ‘give me’, ‘take me’ culture we live in.
                I don’t answer much because people don’t ask for help…they just want someone else to do all the work. Personally I don’t want either Alexa or Google on a mirror. If you want that you may as well just go buy an Alexa or Google…
                E C 2 Replies Last reply Reply Quote 0
                • E
                  ember1205 @cowboysdude last edited by
                  @cowboysdude I agree that most are quick to say “do this for me” and seldom say “how can I help you get this changed?” When you’re dealing with commercial products, that approach is expected because the source is closed. But, this is open-source and community-developed. We all have the ability to contribute -something-…
                  • C
                    cyberphox @cowboysdude last edited by
                    @cowboysdude Smartest thing I ever did when I wanted Alexa on my Mirror? Bought a cheap echo dot and called it a day!
                      @raf here u go, https://www.dropbox.com/s/3rug57k78murz30/gaconfig.zip?dl=0
                      unzip and open the GA-config.md with then atom editor, and press ctrl-shift-m twice
                      • R
                        raf last edited by raf
                        @sdetweil thx
                        i installed atom on my windows 10 and opened the manual but it stops halfway (the manual stops at this sentence and photo) (we also need the project ID for the plugin configuration above select the project name in the dropdown top left, and this panel will pop up copy/paste the project ID from the right hand column of this project)
                        but I’m glad you wanted to help me
