    My Look Ahead board
    16 Posts 4 Posters 5.8k Views 4 Watching
      @sdetweil said in My Look Ahead board:
      only so much room on that wall
      Build a bigger wall. ;-)
      • ankonaskiff17A Offline
        ankonaskiff17 @sdetweil
        @sdetweil So long as one has saved their changes in the given file, those commands will load the new file configuration? What about if you change the js file for a given module?
        What causes a module to not reload completely? I notice this primarily with the holiday calendar. Upon the aforementioned restart it will show No Upcoming Events. I’ll hit Reload again and it will populate.
          sdetweil @ankonaskiff17
          @ankonaskiff17 if u change the modulename.js or config.js, page reload on the mirror screen will reprocess those two.
          If u need the node_helper (calendar fetcher) then u need to restart mm to cause those to reload
          ankonaskiff17A 1 Reply Last reply Reply Quote 0
            @sdetweil Okay. But I have been doing restart mm and the holiday calendar will probably 50% of time not load any of the holidays. Header and no events text will load but even with restart mm I end up doing alt view reload to load holidays themselves.
            So 50% of time I end up doing a combo restart—>reload to load calendar events.
            Could that be an issue with the sequence of loading each module
              @ankonaskiff17 calendar uses a fetcher in node_helper. And the fetcher is on a refresh timer.
              Restarting mm again will ensure the fetcher is restarted.
              But if u are fiddling with other module styles and colors, who cares if cal is loaded every time. I was just giving you quicker paths to working on layouts and presentation.
              Once u get done u restart mm and let it run
              • G Offline
                gospina @sdetweil
                @sdetweil can you share what you did? I am also doing a 4k setup and love it, but trying to figure out some font sizes
