    MMM-ProfileSwitcher, A Profile/User/Layout Switching Module
    userswitchprofilelayoutmodule
    91 Posts 21 Posters 156.2k Views 23 Watching
    • F Offline
      fcornelius @Cyberdyne
      @cyberdyne I had the same idea two days ago and did some research on it. I also asked /r/smartmirrors for some advice on it and got pretty good tips. The bottom line is, if you want to have a solid, non hacky solution supporting both iOS/android go the other way round with the use of beacons.
      Thread is here
      • 3 Offline
        3squaremirror
        having issue showing MMM-Profilepicture using MMM-ModuleScheduler and MMM-ProfileSwitcher.
        I’m trying to switch a day and night time image with profilepicture. Using modulescheduler to switch the image based on the time.
        As far as I can tell, each module is running correctly, as I’m not seeing any error in the console log.
        i think the issue has to do with LockStrings, and i don’t know how to fix it
        Will not show MMM-Profilepicture. LockStrings active: module_2_MMM-ProfileSwitcher
        my configs
        //////////////////// profile ///////////////////////////
                    module: 'MMM-ProfileSwitcher',
                    disabled: false,
                    classes: 'default everyone',
                            defaultClass: 'default',
                            everyoneClass: 'everyone',
                module: 'MMM-ModuleScheduler',
                disabled: false,
                    notification_schedule: [
                        // SWITCH TO THE DAY PROFILE AT 07:30 EVERY DAY
                        {notification: 'CURRENT_PROFILE', schedule: '30 7 * * *', payload: 'day'},
                        // SWITCH TO THE NIGHT PROFILE AT 23:30 EVERY DAY
                        {notification: 'CURRENT_PROFILE', schedule: '30 18 * * *', payload: 'night'},
                    module: "MMM-Profilepicture",
                    position: "fullscreen_below",
                    classes: "day",
                    disabled: false,
                        url: "https://images.unsplash.com/photo-1623150502742-6a849aa94be4?ixlib=rb-4.0.3&ixid=MnwxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8&auto=format&fit=crop&w=1980&q=80",
                        opacity: 1,
                        maxWidth: "120%",
                        maxHeight: "120%",
                    classes: "night",
                    disabled: false,
                        url: "https://images.unsplash.com/photo-1620121692029-d088224ddc74?ixlib=rb-4.0.3&ixid=MnwxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8&auto=format&fit=crop&w=1980&q=80",
                        opacity: 1,
                        maxWidth: "140%",
                        maxHeight: "140%",
            ////////////////end profile //////////////////////////
          sdetweil @3squaremirror
          @3squaremirror don’t know, but please don’t double post.
          members with reputation below 2 have every post reviewed.
          this stops the unrelated spam we get every day (6 this morning).
            @3squaremirror yes. profileswitcher says it’s in charge of hiding and showing modules (via lockstring)
            so. can u force profile switcher to switch to that users profile?
            3 1 Reply Last reply Reply Quote 0
            • 3 Offline
              3squaremirror @sdetweil
              @sdetweil my apology about the double posting, it’s noted. i am not clear on how to force profile switcher to switch. can you elaborate that?
                @3squaremirror sorry, no idea. was just a thought. know nothing about the module
                wishmaster270W 1 Reply Last reply Reply Quote 1
                • wishmaster270W Offline
                  wishmaster270 Module Developer @sdetweil
                  @3squaremirror
                  Do you use any other modules which may hide/show modules?
                  If i copy your configuration to my test environment and add some notifications (change day/night every minute) everything works as expected.
                  • 3 Offline
                    3squaremirror @wishmaster270
                    @wishmaster270 i also use the Touch and Pages module.
                      wishmaster270 Module Developer @3squaremirror
                      @3squaremirror
                      I think the problem is the pages module. It uses lockstrings as well and may block the module of being shown.
                      Tried combining pages and profiles a view years ago and had very similar problems.
                      But you can ralize all you can do with MMM-pages and MMM-page-indicator with MMM-ProfileSwitcher and MMM-ProfileControl. So there is no need to mix Pages and Profiles.
                      • 3 Offline
                        @wishmaster270 thank you, i think you’re right. i read about forcing a module to unhide the lockstring. not sure how to get that done.
                          @3squaremirror some code needs to use the force parameter on the show() or hide() functions.
                          but I can’t tell from the log which code issued the show/hide. only that the profileswitcher had it locked
                          • 5 / 5
