    MMM-aviationwx (Aviation weather)
    111 Posts 12 Posters 139.6k Views 11 Watching
    • 3 Offline
      320fan @Mykle1
      @Mykle1 said in MMM-aviationwx (Aviation weather):
      pressure must be like xx.xx (not like xx as it is)
      Tell that to the API. That’s the data being given. I just display it.
      For example:
      https://aviationweather.gov/adds/dataserver_current/httpparam?dataSource=metars&requestType=retrieve&format=xml&stationString=UUDD&hoursBeforeNow=1
      altim_in_hg 29.911417/altim_in_hg
      I think that this API converts pressure in hPa from raw_data (like Q1013) into hg by simply dividing by coefficient.
        Mykle1 Project Sponsor Module Developer @320fan
        @320fan said in MMM-aviationwx (Aviation weather):
        Forgot I rounded this. My bad. So this should be
        29.91/hg ?
        3 1 Reply Last reply Reply Quote 0
        • 3 Offline
          320fan @Mykle1
          @Mykle1 Hi again.
          Yea, 29.91Hg.
            @320fan
            Good morning
            29.91Hg . Ok, I can work on that later. I’m getting ready for my work day right now
            • 3 Offline
              320fan @Mykle1
              @Mykle1 Okay, no problem. Thanks.
                @320fan
                Wind speed now displays as such:
                310/4KT
                Pressure added to static view and formatted for both views as such:
                29.91Hg
                Config option added for time format, Zulu or Local in both views:
                time: "Zulu", = (19:10Z)
                time: "Local", = (14:10)
                https://github.com/mykle1/MMM-PilotWX
                git pull in your PilotWX directory for update or install as usual.
                  Please move all further inquiries regarding MMM-PilotWX to this topic:
                  https://forum.magicmirror.builders/topic/5686/mmm-pilotwx
                  • H Offline
                    hawkeyepilot69 @Mykle1
                    @Mykle1 is this module no longer working?
                      sdetweil @hawkeyepilot69
                      @hawkeyepilot69 Mykle1 is not available currently.
                      did u add the missing library like I advised?
                      • H Offline
                        hawkeyepilot69 @sdetweil
                        @sdetweil Like I had said, im very new to this and dont know how to do that.
                          @hawkeyepilot69 I have u a link to the instructions on how to deal w that problem.
                          as there are multiple libraries that cause the problem, I am trying to teach you how to find the problem by yourself and how to fix it.
                          vs just giving u the answer and having you come back for the next same failure
                          • 6
                          • 6 / 6
