    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 97.0k Views 16 Watching
    • G Offline
      goedh452 @Shaitan
      @shaitan
      Hi, thanks for the compliment!
      At first glance, I do not see any reason why it doesn’t work. Could you try opening the mirror in a browser on a computer: :8080.
      Then open the monitor with F12 and see if the module generates error messages. Post the error messages here please.
        Shaitan
        This is what you want @goedh452 ? There are only these errors
        S G 2 Replies Last reply Reply Quote 0
          sdetweil @Shaitan
          @shaitan by default custom.css doesn’t exist… if you used my install script I would have created an empty one
          but u can do this
          touch ~/MagicMirror/css/custom.css
            Shaitan @sdetweil
            Hi @sdetweil
            the new file has been created, but nothing on the MM’s screen… But this errors are been vanish !
              sdetweil @Shaitan
              @shaitan cool… black screen, maybe this
                Shaitan @sdetweil
                sorry I misled you. with your command the errors have disappeared, but the display of my MM is the same as before. there is no black screen
                  sdetweil @Shaitan
                  @shaitan ok, I can’t help with the module operation… have no system like that
                    Shaitan @sdetweil
                    @sdetweil thanks anyway for this errors ! Less is the better !
                    • G Offline
                      goedh452 @Shaitan
                      @shaitan
                      Ok, so the module doesn’t produce any errors. I’ll dive into it to see what is causing the problem.
                        Shaitan @goedh452
                        @goedh452 ok thank you !
                        • 8
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 10 / 13
