    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 97.0k Views 16 Watching
    • F Offline
      Fabaude @goedh452
      @goedh452
      moron that I am, a fresh expert’s eyes and the problem is solved.
      Big thanks
      Fab
      • G Offline
        goedh452 @Fabaude
        @fabaude
        Great! Enjoy the module!
        F 2 Replies Last reply Reply Quote 0
        • F Offline
          Fabaude @goedh452
          @goedh452
          I just have to order all that! ;-)
          • F Offline
            Fabaude @goedh452
            @goedh452
            Hello,
            Sorry to come back,
            I have 2 buttons for each “action / label” I created, is this normal?
            Fab
            • G Offline
              goedh452 @Fabaude
              @fabaude
              No, that’s not normal. In the config I see 5 buttons. Am I correct that the module displays 10?
              • F Offline
                Fabaude @goedh452
                @goedh452
                yes, when I pass “displayType: actions”, I have all the buttons in duplicate (on 2 lines) but in “all”, I have the list of devices and a line of buttons below … (can be the second line is hidden for lack of space!)
                I couldn’t go on tonight.
                Sorry.
                Fab
                • G Offline
                  goedh452 @Fabaude
                  @fabaude
                  I think this is a bug. At the moment I do not have a pi running the mirror and module, so debugging is a bit difficult. If I find some time, I’ll see if I can install it and debug. If you only want to display the actions, there should be other modules that do this.
                    Shaitan @Shaitan
                    @sdetweil Hi, I will try this after my travel, i’m not at home… Thank you !
                      Bliepie
                      Does anyone know if it is possible to show the values of a smart meter without using a Gauge?
                      I would like to show the values in a different layout, for example a room layout, I can’t manage to do this now without using a Gauge.
                      I hope someone can help me!
                      Regards, Bliepie
                        ArturB @Bliepie
                        Does anyone know if it is possible to show different gauge colors depending on the value, for example:
                        • temperature in the range of -10 to 10 degrees in blue
                        • temperature in the range of 11 to 20 degrees in green
                        • temperature in the range of 21 to 30 degrees in yellow
                          -temperature in the range of 31 to 40 degrees in red
                        Of course, it would be nice to use such color meters for other measurements.
                        Hope someone can help me!
                        I greet Arthur
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 12 / 13
