    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 97.0k Views 16 Watching
      Shaitan @goedh452
      @goedh452
      I started from zero to be sure that it is not a problem between your module and another program on my pi.
      So I did a new installation of MM on another Raspberry Pi with a clean raspian.
      Above, there is only your modules installed (I just copy my config.js from my other MM).
      Here is the MM launch screen with SSH :
      • G Offline
        goedh452 @Shaitan
        @shaitan
        The errors indicate that Domiticz cannot be reached. Would it be possible to temporarily disable the authentication in Domoticz and test it again?
          Shaitan @goedh452
          @goedh452 I don’t know how to remove the authentication on domoticz, I just added its IP to the whitelist and I got this:Nouvelle ie bitmap.png
          G S 2 Replies Last reply Reply Quote 0
          • G Offline
            goedh452 @Shaitan
            @shaitan
            Just remove the username en password and save the settings.Schermafbeelding 2021-12-06 om 13.47.23.png
              Shaitan @goedh452
              @goedh452 Same screen
                sdetweil @Shaitan
                @shaitan said in MMM-Domoticz-ext: interact with Domoticz:
                I just want to add for this and other folks…
                when integrating multiple systems , 1st thing to do is disable all ip filtering/firewalls
                in MagicMirror this is
                address:"0.0.0.0", // let any outside system connect , "localhost" means ONLY apps INSIDE this same machine can connect
                ipWhitelist:[],   // no restrictions on specific systems connecting.
                once working, then u can add back whatever u might need… ,
                and if it impacts the integration, then u will know as it is the last change…
                • F Offline
                  Fabaude
                  Hello and thank you for this great module,
                  The installation and the settings went well but I can’t see my action buttons on my touch mirror.
                  The overview change buttons work well!
                  I integrated it into a page of MMM-Caroussel and MMM-GoogleAssistant operates my devices well but I cannot control the lights and others with touch buttons!
                  I hope to be clear and in the right place.
                  If you have any ideas…
                  Fab
                  • G Offline
                    goedh452 @Fabaude
                    @fabaude
                    Could you post your config of the module please? And are buttons not displayed at all or aren’t they working when you click them?
                    • F Offline
                      Fabaude @goedh452
                      @goedh452
                      I don’t know where the buttons should be? Are these the icons on my dashboard?
                      Here is my config and thank you.
                      				    module: 'MMM-Domoticz-ext' ,
                      				    header: "DOMOTICZ" ,
                      				    position: "middle_center" ,
                      					    apiBase: "xxx.xxx.x.xx" ,
                      					    apiPort: "xxxx" ,
                      					    updateInterval: 10 ,
                      					    animationSpeed: 0 ,
                      					    displayType: "actions" ,
                      					    alwaysShowDashboard: false ,
                      					    alwaysShowActions: true ,
                      					    showButtons: true ,
                      					    showTotals: true ,
                      					    showIcons: true ,
                      					    dashboardRooms: [ "1","2","3","4","5","6","7","8","9","10","11","12","13" ],
                      					    buttonAllLabel: "Tous" ,
                      					    buttonTypeLabel: "Par Types d'appareils" ,
                      					    buttonRoomLabel: "Par Pièces" ,
                      				        buttonBothLabel: "Par Types/Pièces" ,
                      					    buttonFloorLabel: "Par Types/Niveaux" ,
                      					    buttonDashboardLabel: "Tableau de Bord" ,
                      					    horizontal: true ,
                      					    columnCount: 15 ,
                      					    dashboardColumnCount: 15 ,
                      					    maxTitleLenght: 25 ,
                      					    switchLabel: "Lumières" ,
                      					    dimmerLabel: "Interrupteurs" ,
                      					    temperatureLabel: "Température Intérieure" ,
                      					    humidityLabel: "Humidité" ,
                      					    usageLabel: "Electricité Maison" ,
                      					    rooms: [
                      						    { idx: "7" , name: "Cellier" },
                      						    { idx: "6" , name: "Buanderie" },
                      						    { idx: "1" , name: "Salon" },
                      						    { idx: "2" , name: "Salle à Manger" },
                      						    { idx: "3" , name: "Cuisine" },
                      						    { idx: "8" , name: "Ch.Parents" },
                      						    { idx: "9" , name: "Ch.Adèle" },
                      						    { idx: "10" , name: "Ch.Louis" },
                      						   	{ idx: "4" , name: "Bureau" },
                      						    { idx: "11" , name: "Salle de Bain" },
                      						    { idx: "12" , name: "Salle d'Eau" },
                      						    { idx: "13" , name: "Couloir-Entrée" },
                      						    { idx: "5" , name: "Terrasse" },
                      					    floors: [
                      						     { name: "Rez de Chaussée" ,
                      							    rooms: [ "1" , "2" , "3" , "6" , "7" , "8" , "11" , "13" ]
                      						     { name: "Etage" ,
                      							    rooms: [ "4" , "9" , "10" , "12" ]
                      						     { name: "Extérieurs" ,
                      							    rooms: [ "5" ]
                      					    utilities: {
                      						    utilityLabel: "Electricité Générale Maison" ,
                      						    showLabel: true ,
                      						    devices: [
                      						    { idx: "119" ,
                      						      deviceHeader: "Consommation Electrique" ,
                      						      useHeaderSymbol: false ,
                      						      headerSymbol: "plug" ,
                      						      counterTodayLabel: "Aujourd'hui" ,
                      						      counterTodayAppendText: "Kwh" ,
                      						      gaugeMinValue: -3000 ,
                      						      gaugeMaxValue: 3000 ,
                      						      gaugeAppendText: "Watts" ,
                      						      gaugeWidth: 190 ,
                      						      lineWidth: 20 ,
                      						      markerWidth: 20 ,
                      						      markerColor: "#F4D03F"
                      						    { idx: "121" ,
                      						      deviceHeader: "Consommation Electrique Nette" ,
                      						      gaugeWidth: 190 ,
                      						      lineWidth: 20 ,
                      						      markerWidth: 20 ,
                      						    { idx: "117" ,
                      						      deviceHeader: "Production Solaire" ,
                      						      headerSymbol: "sun" ,
                      						      gaugeMinValue: 0 ,
                      						      gaugeWidth: 190 ,
                      						      lineWidth: 20 ,
                      						      markerWidth: 20 ,
                      						      markerColor: "#70db70"
                      						    { idx: "43" ,
                      						      deviceHeader: "Production Eau Chaude" ,
                      						      headerSymbol: "faucet" ,
                      						      gaugeMinValue: 0 ,
                      						      gaugeMaxValue: 2800 ,
                      						      gaugeWidth: 190 ,
                      						      lineWidth: 20 ,
                      						      markerWidth: 20 ,
                      						      markerColor: "#1E90FF"
                      						    { idx: "46" ,
                      						      deviceHeader: "Pompe à Chaleur" ,
                      						      headerSymbol: "hot-tub" ,
                      						      gaugeMinValue: 0 ,
                      						      gaugeMaxValue: 2000 ,
                      						      gaugeWidth: 190 ,
                      						      lineWidth: 20 ,
                      						      markerWidth: 20 ,
                      						      markerColor: "#f4763f"
                      						    custonGauges: {
                      								    headerLabel: "Autres" ,
                      								    showLabel: true ,
                      								    devices: [
                      									    { idx: "25" ,
                      							  deviceHeader: "Voltage" ,
                      							  useHeaderSymbol: true ,
                      							  headerSymbol: "bolt" ,
                      							  gaugeAppendText: "volts" ,
                      							  gaugeMinValue: 210 ,
                      							  gaugeMaxValue: 260 ,
                      							  gaugeWidth: 150 ,
                      							  lineWidth: 16 ,
                      							  markerWidth: 16 ,
                      							weather: {
                      										devices: [ "140" ],
                      										weatherLabel: "Températures",
                      										gaugewidth: 60,
                      										gaugeAppendText: "°C",
                      									Actions: [
                      											{ label: "Lumiere Exter Cuisine Shelly",
                      											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=66&switchcmd=On"
                      											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=66&switchcmd=Off"
                      											{ label: "Lumiere Exter Entree Shelly",
                      											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=62&switchcmd=On"
                      											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=62&switchcmd=Off"
                      											{ label: "Prise Commandée 1",
                      											url: "http://xxx.xxx.x.xx:xxxx/json.htm?type=command&param=switchlight&idx=69&switchcmd=Toggle"
                      • G Offline
                        goedh452 @Fabaude
                        @fabaude
                        I’m not sure if this is the problem, but there are two typos in the config: custonGauges should be customGauges en Actions should be actions (lower case a).
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 11 / 13
