    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 97.0k Views 16 Watching
      maxs @goedh452
      @goedh452
      Thanks, that would be nice. I really like your module.
      • G Offline
        goedh452 @maxs
        @maxs
        I made some changes in the code. Can you download the latest version from GitHub and add the option enableReturn to the utility device? When set to false the return values are ignored and the correct value should be displayed. I’m unable to test properly since my device doesn’t generate this strange value.
        enableReturn: false,
        My config example looks like this:
        devices: [
                        idx: "304",
                        deviceHeader: "Elektriciteit",
                        useHeaderSymbol: true,
                        headerSymbol: "plug",
                        counterTodayLabel: "Vandaag",
                        counterTodayAppendText: "kWh",
                        gaugeMinValue: -3000,
                        gaugeMaxValue: 3000,
                        gaugeAppendText: "watt",
                        gaugeWidth: 200,
                        lineWidth: 16,
                        markerWidth: 16,
                        markerColor: "#F4D03F"
          maxs @goedh452
          @goedh452
          Thanks for quick reply. Test it and works like a charm.
          :thumbs_up:
          Thanks.
            majsoft @goedh452
            @goedh452 said in MMM-Domoticz-ext: interact with Domoticz:
            You could create your own module based on the code and modify that css.
            I found that both mmm-domoticz-ext and mmm-domoticz-ext2 work separately for both modules
            If I enter them both at once in config.js it always works only the one that is written as the last one. Can anyone help please?
              Manu663
              Hi all, I’m an old geek who’s trying to keep up but learning by doing without initial training is long, difficult and the age of my brain cells doesn’t help me much.
              Could you please post some examples of your MMM-Domoticz-ext config? (from the simplest to the most elaborate, I’ll take anything that comes along!)
              It would help me to test different configurations and customize mine.
              Thanks in advance !
              • G Offline
                goedh452 @Manu663
                @manu663
                Please see the GitHub-page for some examples: MMM-Domoticz-ext
                  Manu663 @goedh452
                  @goedh452 Thank you for your quick reply, it’s much appreciated!
                  I have read the whole github unfortunately, I don’t manage to get a convincing result. It doesn’t matter, I’ll calm down and read the github again over a cup of coffee and start all over again.
                  But if others have examples, I’ll take them anyway ;-)
                    Manu663 @Manu663
                    Once I calmed down and reread everything from the beginning I finally managed to get a nice result.
                    I feel ashamed that I called for help when it was just a silly syntax error. :sad_but_relieved_face:
                    Anyway, thank you for the marvelous job done there !
                    • G Offline
                      goedh452 @Manu663
                      @manu663
                      No problem at all! The module became a bit complex during the build :-)
                        Shaitan
                        Hi @goedh452,
                        Your mod is so great, but I think you already know that ;-).
                        Like the others, this is exactly what I was looking for.
                        But after installing it, it doesn’t display anything, just the title on my MM. I notice in the domoticz log that he contacts him but I do not know if it is a problem of connection or reception of data…
                        Thank a lot for your help
                        Here are the informations and screenshots :
                        Domoticz ip : 192.168.1.3
                        MM’s ip : 192.168.1.40
                        My Config.js
                        			module: "MMM-Domoticz-ext",
                        			header: "Domoticz",
                        			  apiBase: "192.168.1.3",
                        			  apiPort: "8080",
                        			  updateInterval: 5,
                        			  animationSpeed: 0,
                        			  displayType: "all",
                        			  horizontal: true,
                        			  dashboardColumnCount: 2,
                        			  showTotals: true,
                        			  dashboardRooms: [ "1", "2" ],
                        My json for IDX 1
                        	"ActTime" : xxxxxx,
                        	"AstrTwilightEnd" : "xxxxx",
                        	"AstrTwilightStart" : "xxxxx",
                        	"CivTwilightEnd" : "xxxxxx",
                        	"CivTwilightStart" : "xxxxx",
                        	"DayLength" : "xxxxxx",
                        	"NautTwilightEnd" : "xxxxx",
                        	"NautTwilightStart" : "xxxxx",
                        	"ServerTime" : "xxxxxxxxx",
                        	"SunAtSouth" : "xxxxx",
                        	"Sunrise" : "xxxxx",
                        	"Sunset" : "xxxxx",
                        	"app_version" : "2021.1",
                        	"result" :
                        			"AddjMulti" : 1.0,
                        			"AddjMulti2" : 1.0,
                        			"AddjValue" : 0.0,
                        			"AddjValue2" : 0.0,
                        			"BatteryLevel" : 255,
                        			"CustomImage" : 0,
                        			"Data" : "21.4 C, 56 %",
                        			"Description" : "",
                        			"DewPoint" : "12.26",
                        			"Favorite" : 0,
                        			"HardwareDisabled" : false,
                        			"HardwareID" : 2,
                        			"HardwareName" : "DHT 22 ext",
                        			"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
                        			"HardwareTypeVal" : 15,
                        			"HaveTimeout" : false,
                        			"Humidity" : 56,
                        			"HumidityStatus" : "Comfortable",
                        			"ID" : "14051",
                        			"LastUpdate" : "2021-11-29 15:03:03",
                        			"Name" : "DHT22 ext",
                        			"Notifications" : "false",
                        			"PlanID" : "0",
                        			"PlanIDs" :
                        			"Protected" : false,
                        			"ShowNotifications" : true,
                        			"SignalLevel" : 3,
                        			"SubType" : "THGN122/123/132, THGR122/228/238/268",
                        			"Temp" : 21.399999999999999,
                        			"Timers" : "false",
                        			"Type" : "Temp + Humidity",
                        			"TypeImg" : "temperature",
                        			"Unit" : 1,
                        			"Used" : 1,
                        			"XOffset" : "0",
                        			"YOffset" : "0",
                        			"idx" : "1",
                        			"trend" : 2
                        	"status" : "OK",
                        	"title" : "Devices"
                        My Setting on Domoticz
                        Log domoticz
                        My MM
                        • 7
                        • 8
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 9 / 13
