    MMM-Domoticz-ext: interact with Domoticz
    121 Posts 14 Posters 92.1k Views 16 Watching
    • G Offline
      goedh452 @majsoft
      @majsoft
      I don’t think it is possible to just change the font for the first lines. All are in the same class.
        majsoft @majsoft
        @majsoft
        How to remove the lines (marked in green) I have already come.
        using this code
        hr.domoDivider {
          display: none;
        If it is not possible to change the font size of only the first three sensors, it is possible to run 2 instances of the module in config.js, but I do not know how to distinguish these instances in customs.css
        • G Offline
          goedh452 @majsoft
          @majsoft
          I think this is also not possible, but I’m not an css expert. Maybe others have soms ideas.
          You could create your own module based on the code and modify that css.
          M 3 Replies Last reply Reply Quote 0
            majsoft @goedh452
            @goedh452
            yes, I’m just trying to create a new mmm-domoticz-ext-2 module, but even if I replace the text mmm-domoticz-ext with mmm-domoticz-ext-2 in all files, it doesn’t work. then it would be easy in CSS to assign a font size to each module. I’m not a programmer either. I have to follow the trial and error method
              majsoft @goedh452
              @goedh452 said in MMM-Domoticz-ext: interact with Domoticz:
              @majsoft
              I can’t get the copied module up and running, it still reports loading. Basic methods for copying a module fail. Can you advise me how to copy the module?
                module: "MMM-Domoticz-ext",
                  position: "bottom_bar",
                  apiBase: "192.168.2.80",
                  apiPort: "8081",
                      updateInterval: 15,
              displayType: "room",
                        alwaysShowDashboard: false,
                        alwaysShowActions: false,
                        showButtons: false,
                               horizontal: true,
                        columnCount: 3,
                        dashboardColumnCount: 12,
                        maxTitleLength: 18,
               	     rooms: [
                    { idx: "1" },
              { idx: "9" },
              { idx: "8" },
                module: "MMM-Domoticz-ext2",
                  apiPort: "8081",
                      updateInterval: 20,
                        showButtons: false,
                               horizontal: true,
                        columnCount: 3,
                        maxTitleLength: 18,
               	     rooms: [
                    { idx: "11" },
              { idx: "12" },
              { idx: "13" },
                majsoft @majsoft
                @majsoft
                I found that both mmm-domoticz-ext and mmm-domoticz-ext2 work separately for both modules
                If I enter them both at once in config.js it always works only the one that is written as the last one. Can anyone help please?
                  maxs @goedh452
                  @goedh452
                  Sorry for late reaction. Here is the file you request. I think I uploaded wrong, but I hope you can do something with it.
                  “ActTime” : 1630944398,
                  “AstrTwilightEnd” : “22:12”,
                  “AstrTwilightStart” : “04:58”,
                  “CivTwilightEnd” : “20:46”,
                  “CivTwilightStart” : “06:24”,
                  “DayLength” : “13:14”,
                  “NautTwilightEnd” : “21:27”,
                  “NautTwilightStart” : “05:43”,
                  “ServerTime” : “2021-09-06 18:06:38”,
                  “SunAtSouth” : “13:35”,
                  “Sunrise” : “06:58”,
                  “Sunset” : “20:12”,
                  “app_version” : “2021.1”,
                  “result” :
                  “AddjMulti” : 1.0,
                  “AddjMulti2” : 1.0,
                  “AddjValue” : 0.0,
                  “AddjValue2” : 0.0,
                  “BatteryLevel” : 255,
                  “Counter” : “5077.807”,
                  “CounterDeliv” : “0.000”,
                  “CounterDelivToday” : “18446744073709552.000 kWh”,
                  “CounterToday” : “2.151 kWh”,
                  “CustomImage” : 0,
                  “Data” : “2794757;2283050;6;0;123;0”,
                  “Description” : “”,
                  “Favorite” : 1,
                  “HardwareDisabled” : false,
                  “HardwareID” : 2,
                  “HardwareName” : “Smart Meter”,
                  “HardwareType” : “P1 Smart Meter USB”,
                  “HardwareTypeVal” : 4,
                  “HaveTimeout” : false,
                  “ID” : “0001”,
                  “LastUpdate” : “2021-09-06 18:06:38”,
                  “Name” : “Power”,
                  “Notifications” : “false”,
                  “PlanID” : “4”,
                  “PlanIDs” :
                  “Protected” : false,
                  “ShowNotifications” : true,
                  “SignalLevel” : “-”,
                  “SubType” : “Energy”,
                  “SwitchTypeVal” : 0,
                  “Timers” : “false”,
                  “Type” : “P1 Smart Meter”,
                  “TypeImg” : “counter”,
                  “Unit” : 1,
                  “Usage” : “123 Watt”,
                  “UsageDeliv” : “0 Watt”,
                  “Used” : 1,
                  “XOffset” : “0”,
                  “YOffset” : “0”,
                  “idx” : “1”
                  “status” : “OK”,
                  “title” : “Devices”
                  • G Offline
                    goedh452 @maxs
                    @maxs
                    I see what’s the problem. For the usage per day the CounterToday and CounterDelivToday are substracted. The value for your CounterDelivToday has a very strange value. Only option would be that such values are set to 0 in the code.
                      maxs @goedh452
                      @goedh452
                      can I do that by my own? I have idee how, but maybe with some help from you? Thans for quick answer.
                      G 2 Replies Last reply Reply Quote 0
                      • G Offline
                        goedh452 @maxs
                        @maxs I’ll see what I can do and let you know when you can download the new code from GitHub.
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 8 / 13
